Slotblog: Scratchbuilt chassis gallery - Slotblog
  • (24 Pages)
  • 1
  • 2
  • 3
  • Last »
  • You cannot start a new topic
  • You cannot reply to this topic
Scratchbuilt chassis gallery A "Show & Tell" thread for retro chassis builders
#1 User is offline   cheater
  • The Dokktor's Assistant
  • Group: Root Admin
Post icon  Posted 16 April 2008 - 12:18 PM
At the suggestion of a Slotblog member, this thread is being created so the many talented retro chassis builders here can have a place to showcase and to explain the design principles underlying their scratchbuilt chassis. The idea behind this gallery thread (and its posting restriction) is to create one place where retro chassis designs can be seen, compared, and contrasted.
All questions and discussion related to any chassis showcased here are to be posted to the other pinned thread in this forum: Chassis Gallery Discussion.
Please note that posts to this thread are to be made ONLY by the builders of the chassis being shown.
Posts that do not comply with this restriction will be moved to the Discussion thread without notification.
One more point: the hope is that this gallery will become a reference for scratchbuilt retro racing chassis designs. It is not meant to be a catch-all for all types of scratchbuilt chassis nor was it created to replace the other venues on Slotblog where scratchbuilt chassis are shown and discussed, i.e. the Scratchbuilt forum, the Pro Racing Cars & Replicas forum, etc.
Now, who is going to make the first post showcasing their chassis?
#2 User is offline   Ron Hershman
  • Grand Champion Poster
  • Group: Subscriber
Posted 16 April 2008 - 10:15 PM
Can I be first???
Attached File  ron1a.jpg (144.69K)
My R4 Coupe winner. Warmack kit built by Rande "RPM" Marshall. More or less a stock build.
#3 User is offline   Josh Crutchfield
  • On The Lead Lap
  • Group: Full Member
Posted 16 April 2008 - 11:05 PM
My new F1 chassis built for an original blue King.
Mostly all brass construction using .062" brass rod, .064" center, and .032" pans. R-Geo motor bracket. The pans are hinged on the opposite sides for better pan movement. 4" wheelbase with a 5" guide lead.
#4 User is offline   4laneron
  • On The Lead Lap
Posted 17 April 2008 - 12:02 AM
My new D3 chassis:
Attached File  4lane_a.jpg (89.78K)
#5 User is offline   cheater
  • Group: Root Admin
Posted 17 April 2008 - 11:17 AM
Here's the chassis I used at the R4. I posted a pic of the cut-down pan some weeks back and this is the completed chassis. I figured I'd better post these pics now, as further mods are planned based on the chassis' performance at the R4 and a couple of SERRA races.
The whole idea with this chassis was to use the Warmack kit as a starting point. I wanted to remove as much weight as I could (from places where I feel it doesn't do much good), not so much to lighten the car, but to allow me to place weight where it would do more good, handling-wise.
Attached File  top.jpg (74.93K)
I removed a lot of material from the basic Warmack pan (using a nibbler for much of it and a Dremel and files for the rest): from the inner edges of the pans, the front wings, the front axle uprights, the guide tongue, and from the center "tongue" of the nosepiece. The middle body mount tabs on the pans were hammered flat and then trimmed off. IIRC the unmodified pan weighed 41.15 grams and once I was done chopping on it, it weighed 28.85 grams or thereabouts.
Attached File  bot.jpg (77.35K)
What I wanted to do with the pan hinge mods was to push the hinges forward and aft to give more flexibility to the main rails. The front hinge tubes (3/32" square tubing) were pushed well up into the nosepiece and the rear hinge tubes (3/32" round tubing) were pushed back under the motor bracket. Additionally, I wanted to get the hinge arms off the tops of the pans, thus they are soldered to the edges. Hinge pin material is .055' piano wire. The wetted surface of the front hinge to pan joints seemed a little small, so the additional .032" braces were added for more strength.
The motor bracket was spread into a V for two purposes: to move the motor closer to the rear axle and to give a wider bushing "stance" without having to add tubing chunks for mounts. Additionally, the spread bracket allowed soldering the bottoms of its "arms" onto the main rails, helping to stiffen the bracket assembly and giving a better attachment of the bracket to the main rails. This worked really well...
Attached File  bracket.jpg (85.53K)
Here's my possibly-excessive bracket bracing. My feeling is that many builders don't realize the magnitude of the forces generated at the gear interface. I don't think it is possible to make a motor cage assembly too strong, but it sure is possible to make one too weak! The straight upper brace on the motor bracket is 1/16" tubing; everything else is piano wire.
Attached File  brkt_bot.jpg (83.95K)
Here you can see the sloppy results of building in a hurry: the lefthand rail in this pic is about 1/16" longer than the righthand rail, and I'll fix this when I revise the chassis. Note how the gear guard plugs into the rear of the pan hinge tubes.
Attached File  frontend.jpg (78.02K)
A different front axle mounting arrangement, what I call a torsion bar set-up. The .032" brass pan material is simply not strong enough for front wings (at least on my cars, where wall contact is a fairly frequent occurrence!) and the .055" piano wire is run along the top of the front wings to stiffen them. I wanted to revise the stock Warmack front axle mounting arrangement, as I felt there was too much material in the front uprights to suit me. Note that the front axle is not soldered to the uprights; the 3/32" collars soldered to the axle actually spigot into the upright holes, which are now small slots. I finished this chassis at the R4 and didn't have any decent copper tie-wire in my box, so I used some braided silver shunt wire I did have. I figured if I hadn't used the stuff for brush shunts in the last 20 years, I might as well use it here.
After racing this chassis a few times, I have decided I went too far and made the chassis too flexible, because it has so much bite I can't get it to slide as much as I want it to, even with hard tires. So I will be making some mods to stiffen it up a bit.
The plan is to lengthen the rear pan hinge tubes and to solder the rear pan hinge arms to the angled cut-outs as with the front hinges. I'll also add .032" joint braces to the rear hinge to pan joints, as with the front ones, and will extend them touch the front .032" braces to stiffen the pans themselves a bit. I may also lengthen the L-shaped bracket braces that tie the corners of the bracket to the main rails so that the horizontal legs of the braces extend farther forward alongside the motor. In the front, I will reverse the U-shaped brace (that carries the ear-ring back) so that the open side of the U points forward.
In the front, I plan to shorten the joint where the front axle attaches to the torsion bars; with wire-tying, these two joints don't need to be as long and heavy as they are now.
These modifications should add some beam stiffness, as the main rails will have a shorter unsupported length. If the car still has too much bite after these changes, I'll make a longer front U-brace and extend the rear bracket L-braces even more.
BTW, IIRC this chassis ready-to-race weighed roughly 115 grams with a TSR D3 motor and an Eddie Mac-painted Lola body I bought at the Sano. That's with no added lead, though it does usually carry a little when it is raced.
And it dosn't really look as nasty in appearance as the pics seem to suggest. I call it racing quality, not presentation grade like the gorgeous chassis Rick and Steve create.
Now don't forget! If you wanna tell me what a POS this is, do it in the "Discussion" thread, not here. :rolleyes:
#6 User is offline   tonyp
Posted 17 April 2008 - 12:06 PM
I am sure most of you have seen this chassis in the East Coast race reports and the short post I did showing how it evolved.
I thought you may be interested in seeing the second version.
I built this one based on a Warmack kit and used a BWA rear bracket, my favorite. I made this a 4" WB instead of 3.9" and went with an .850" GL instead of .90". Rails are .078" piano wire on both cars. The outer pans on version 2 are 3/16" instead of 1/4" to save weight as well as the rear split pans.
The "aero" pans on both chassis are .016" brass and support the body mounts. The new version has a more pronounced wing profile to the pans.
So far I have run this at Sonny's on the King and it was fast but I went with the original simply because I am used to it. I also tried it at Liquid Lou's 220' track and it ran well there also, just not as smooth as my original.
I ground on the spring between the pans to make it softer and went to a pair of Sonic fronts. I will take it as my race back-up car for the race this weekend. I need to get more laps on it to break everything in...
Both chassis when testing ran the best with the O/S long Ti22.
#7 User is offline   Jay Guard
  • On The Lead Lap
  • Group: Administrator
Posted 23 April 2008 - 09:00 PM
Here's a few shots of the chassis I made for the Sano and SERRA Series.
Although I've been scratchbuilding for a long time these are the first inlines I've built in 40 years! I really learned a lot about inline chassis dynamics with these first two and have had to make quite a few mods (motor bracket stiffening and increased chassis torsional stiffness) since these pictures but hopefully these will inspire a few new designs.
I've got a couple of new designs on the drawing board and should have something new to show in about a month. I promise they will be quite a bit different from these!
Attached File  jay1a.jpg (86.89K)
Attached File  jay2a.jpg (108.5K)
Attached File  jay3a.jpg (110.29K)
Attached File  jay4a.jpg (118K)
#8 User is offline   Rick
  • Posting Leader
Posted 28 April 2008 - 07:32 PM
Something a little different using some old and new ideas: 5" guide lead, 4+" wheelbase. Reverse pans and switchback main rails.
Built with roadcourse in mind, will test at Mac's...
Attached File  rick1a.jpg (102.15K)
Attached File  rick2a.jpg (90.47K)
#9 User is offline   Rick
  • Posting Leader
Posted 03 May 2008 - 12:33 PM
The X goes F1... similar to the Can-Am but for F1. Front axle has not been installed yet to make for easier viewing.
#10 User is offline   flea
  • Backmarker
Posted 04 May 2008 - 09:29 AM
Here's my latest retro style chassis, all steel nose and pans. Yes, I know that steel isn't "legal" for use under IRRA rules, but it is legal where I run.
It features:
Three rail main frame: .062" center and .055" outer.
WB 4.00"
GL .935"
.028" steel nose and pans
Weight (as pictured): 57.5 grams
Can't wait to try it out!! :D
#11 User is offline   team burrito
  • Race Leader
Posted 04 May 2008 - 11:04 AM
All right, here's my latest chassis:
And here's my new jig block:
I got the block from eBay for $10.00 with some extra machining at no charge (I added the jig holes). The tech block is made out of Corian and it's the flattest block I've ever bought. Look for "precision-slot-cars" for more of his tech blocks.
#12 User is offline   Josh Crutchfield
  • On The Lead Lap
Posted 07 May 2008 - 09:44 PM
Another F1. 4" wheelbase with a 5" GL. The mainrails are .078", The lower pans are .064" and the upper pans are .032". I also used an REH motor bracket widened to 1-1/4".
#13 User is offline   Rick
  • Posting Leader
Posted 10 May 2008 - 01:28 PM
Solved the hinge debate... there ain't any, LOL. There no hinges, it's a torsion chassis, rear pans are free to move around in the tubing. Rather soft on flex to aide in this idea. Solid pin tubes, although shakers would probably be better, but I don't have material here to make them. 41 grams as shown, should come in well under 100.
New try. Yeti nose piece, new design hypoid motor box, extra light pans, low profile guide required. If there is anybody that lives close to a track and wants to test it out before next Saturday, give me a PM, I will send right out, and you gotta be going to Mac's for the race too. :)
Another similar to this coming tomorrow. Same parts... stay tuned.
#14 User is offline   Rick
  • Posting Leader
Posted 10 May 2008 - 09:28 PM
Second tripod. No hinges again, just jiggle in the tubes. Will try this way then with a stiffening wire between the frame rails, time permitting...
#15 User is offline   team burrito
  • Race Leader
Posted 11 May 2008 - 12:27 PM
Here's my latest F1 design JK can market:
#16 User is offline   Rick
  • Posting Leader
Posted 11 May 2008 - 01:32 PM
Oh well, it's raining and the grass needs to be cut.
Here is something I have been thinking of for some time. REALLY soft!! 5" X 4-1/8" X 7/8", 49 grams. Mains go thru a tube to probably be just too bitey. Pans are welding rod. Low profile guide tongue.
#17 User is offline   MantaRay
  • Simply Addicted
  • Group: Subscriber
Posted 13 May 2008 - 07:16 AM
Here is my latest build. Pretty straightforward. Single .078" rail. Pans are .025". BWA bracket on a diet with a little weight added down low.
I tried something a little different for the pan stops. The gussets should give them more strength without tying the rails together. I tried some 1/4" .032" for body mounts.
Attached File  ray1a.jpg (72.39K)
Attached File  ray2a.jpg (72.74K)
Attached File  ray3a.jpg (64.69K)
Attached File  ray4a.jpg (76.91K)
#18 User is offline   Mike Patterson
  • Chief Cook and Bottle Washer
  • Group: Subscriber
Post icon  Posted 20 May 2008 - 08:42 PM
This is the fourth retro-style chassis I have constructed, all of which have been variations on the same theme. Since this will probably be the last variation, I will attempt to explain my design criteria and construction.
Attached File  BOZO_R4_A.jpg (58.12K)
This shows the top view of chassis number R4. Some specs:
2 x 0.078" main rails
1" x 1-1/8" 0.062" brass nosepiece
0.032" brass pans
R-Geo motor bracket
Slick 7 guide tongue
Sonic front wheels
Zap earring back
4.062" wheelbase
5.0" guide lead
69.9 grams
Attached File  BOZO_R4_B.jpg (60.08K)
This is a close-up of my front end construction, The purpose of having the front hinge tubes so far forward is to provide a plumber effect under braking, i.e. more weight on the nose. I like using square hinge tubing. It provides more surface area on the nosepiece for the solder joint. That, combined with the 0.062" hinge wire, is hopefully strong enough to survive a few wall hits. The square tubing also provides more solder area for the front axle uprights, again, theoretically adding some strength in this critical area. I use a piece of 0.093" wire for the front axle, with independently-rotating front wheels. The front upright/axle joint is reinforced with 0.062" brass rod, bent over the axle and soldered to the uprights.
Attached File  BOZO_R4_C.jpg (34.91K)
This is a photo of the rear end assembly. I again used the 0.062" brass rod to reinforce the axle tube/motor bracket area. After attempting to bend a rear brace out of 0.062" wire six times, I finally cut one of my attempts in two, and put it back together with a piece of tubing. Unfortunately, this limits me to a 28 tooth gear, a 29 won't fit! Sucker shouldn't bend, though. At least, not very easily.
Attached File  BOZO_R4_D.jpg (41.46K)
This is a close-up of the rear pan hinge, again using square tubing. This serves as an additional stiffener of the bracket/main rail solder joint. You can also see the chunk of tubing that controls the pan movement. This is 1/8" square with an 0.062" bite bar, with an 0.062" U-brace on the main rails.
Attached File  BOZO_R4_E.jpg (54.28K)
And last, a look at the bottom. I just noticed I haven't numbered this one yet.
I usually design and layout my chassis in Macromedia FreeHand, and then print a couple of copies. One, to check how what I'm building matches what I designed, and the second to cut up to use as a pattern for cutting out the pans.
#19 User is offline   dougmatthes
  • Race Leader
Posted 21 May 2008 - 12:48 AM
This car was designed for a high-speed, highly-banked King track, like BPR's King. The car's primary design constraints were:
  • light weight and aerodynamic.
  • light weight rear motor box
  • low CG
  • stiff flex
  • perimeter pan weight
  • not fragile
1) The car's total weight is 96 grams. The weight of the body is 4.9 grams, using lightweight interior and minimizing paint. The Lola body is used with cut-out back, and air dams cut out behind front fenders. Body was cut high in rear and low in front, with minimum spoiler. Note the spoiler is not up, but I like it there as a safety net. Lightweight lead wires. Lightweight JK8783P tires. No front axle tubing. Narrow front tires. Lightweight Kelly fronts were made from Kelly blue tires, (also, Kelly's have less wobble due to longer axle shafts). Use bearings in rear and make sure your front tires spin freely without wobble.
2) The motor box was made very light, but stiff as a rock. I added stiffness with a cross bar soldered across the bottom on the back side of the motor through the bracket connecting to the rails; four .063" rails along the outside; two .063" axle posts completely soldered to the box; .063" rear rail to protect and stiffen up the back of the motor box. The box is stiff and solid, and the strengthing was done low to keep the CG down in the back of the chassis.
3) Everything was designed to have low CG: The motor box as described in 2). Only two front axle posts per side out wide. The motor is set hypoid. Light .047" crossbeam to adjust flex and pan stops. The body pinning was kept low and the side stops were made with .032" steel. Definitely get the rear as low as possible, 50 mil clearance and 15 mil on the front.
4) The King car chassis is very stiff using two .063" steel rails soldered together along the their entire length, with wide rail spacing. The rear and front are very stiff. Note, the four rails of .063" steel in the rear. 4 inch wheel base with 0.9 inch guide.
5) Perimeter pan weight is used for this high-speed car. The pans are as low as possible without dragging.
6) Most of the steel was .063" with longer solder joints. The side pan were .063" thick. The front was near all steel .063" rails. The axle posts were .063". The front bumper was .063", but I'm replacing with .078" steel. The motor box was solidly supported with .063" steel as discribed in 2). The body was reinforced at the pins with body armor and packing tape, but using very small pieces to keep the weight down. The lead wires were lightweight, but not too thin, and definitely soldered to the motor.
Attached File  KingCanAm.jpg (54.57K)
Attached File  KingCanAm1.jpg (53.7K)
More pics are at Keith Tanaka's SoCal D3 albums in the F1/Can-Am races 4/12/2008 section.
#20 User is offline   JimF
  • On The Lead Lap
Posted 23 May 2008 - 04:32 PM
Here are couple of pics of a new build specifically for the Buena Park flat track. (I suspect good results on other tracks too with some simple mods).
All flat brass is .032". Bracket is a RICK hypoid. Guide tongue is a Warmack. Main frame rails are .063" bronze. The two inner frame rails are .062" wire but are not soldered solid. Those rails are free inside of a tube thus providing some longitudinal stiffness and protection for the bronze without adding much torsional stiffness. The inner rails can easily be dropped out completely, or changed for bigger or smaller rails. Those could either be within tubes as shown here or just soldered in solidly. Ideally, this will allow fairly simple trackside flex tuning without a full rebuild.
This version has a 4.650" axle to post length. This is relatively short for me as most of my stuff has been 4.800"-5.000" Running weight without body will be about 114 grams and I expect to add a bit of lead for the BP flat track. This chassis could easily be built down to 105 grams or so.
A little clean-up and off to the tumbler. May hit the track with it tonight or tomorrow.
Share this topic:
  • (24 Pages)
  • 1
  • 2
  • 3
  • Last »
