Brass cutting
Posted 11 July 2022 - 04:12 PM
Wasn't sure to post this in the "scratchbuilding" section or here, so, shooting from the hip.
Thanks
Ray
Wichita, KS
Retro Can-Am & drag racer
Posted 11 July 2022 - 04:44 PM
For thin brass sheet up to 1/32" thick I'll just use my Dremel with a #409 cut-off wheel. For thicker sheet I'll use a fine blade hacksaw to rough out the part. Then to get the parts (thick or thin) right to the scribe line I will use a disk sander for outside cuts and the Dremel and/or a file for the inside cuts where the disk sander can't get. I don't use tin snips as they tend to warp the material and of course a metal shear is perfect for this but generally overkill (and too expensive) for the limited number of parts you will probably be making. I've never really tried using a nibbler but I think some do use them.
- Eddie Fleming likes this
Gator Region Retro Racing Co-Director (2021-Present)
Posted 11 July 2022 - 06:37 PM
Also band saw and hand files
Posted 12 July 2022 - 11:08 AM
- MSwiss likes this
Posted 12 July 2022 - 05:37 PM
I've been known to use a chop saw, but mostly use my Dremel.
South Carolina, USA
- Pat Paulsen, 1968
- Steven Wright ca. 1983
Posted 12 July 2022 - 10:00 PM
A micro bandsaw works great but they are not cheap (usually $200+).
Going slow and looking good since '92
