Front engine Indy car bodies
9 replies to this topic
#1 Martin
  • 4,234 posts
Posted 21 August 2022 - 12:49 PM
While doing a bit of organizing I found these Indy car bodies.
I believe the Pactra bodies are labeled correctly? But the Lancers I am not sure about.
The body on the left has a labeled Lancer #124 Novi 1/24
Next body Lancer #85 Indy STP Special 1/24
then Pactra #52 Kurtis Indy Roadster 1/24
Last on the right Pactra #53 Kurtis Indy Roadster 1/24
Are these labeled correctly?
Identification would be appreciated. Thanks.
  • Tex likes this
#2 dc-65x
  • 6,992 posts
Posted 21 August 2022 - 02:28 PM
The body with the Kurtis Indy Roadster label is actually a  #124 Lancer Novi
#3 dc-65x
  • 6,992 posts
Posted 21 August 2022 - 02:30 PM
The body second from the left has the wrong label too. That label belongs with the Lancer Indy STP Special on the left.
#4 Martin
  • 4,234 posts
Posted 21 August 2022 - 02:35 PM
Thank you Rick. There are two Kurtis Indy Roadster Lables can you tell me which one is wrong? # 52 or #53.
Is one of the two bodies on the left the Kurtis Indy Roadster?
#5 Martin
  • 4,234 posts
Posted 21 August 2022 - 03:42 PM
I will follow your instructions and take another pic.
The  bodies will be in the same place and will move the labels. Strange Pactra called 2 bodies the same name. The orange label is #52
the blue # 53. But both called KURTIS INDY ROADSTER.
#6 dc-65x
  • 6,992 posts
Posted 21 August 2022 - 03:47 PM
Almost. The body 3rd from the left is the #124 Lancer Novi
#7 Martin
  • 4,234 posts
Posted 21 August 2022 - 03:53 PM
Is the orange labeled Pactra Kurtis correct?
left to right.
INDY STP SPECIAL , KURTIS #52,   NOVI,  and KURTIS # 53.
#8 dc-65x
  • 6,992 posts
Posted 21 August 2022 - 03:55 PM
Sorry, I'm not that famaliar with the front engine Indy bodies.........just the Lancer Novi's which make great twin engine 4WD slot cars.   :D
#9 Martin
  • 4,234 posts
Posted 21 August 2022 - 04:25 PM
So this makes sense to me. Both Pactra bodies are Kurtis's, they are almost identical except one has a side tank.
Thanks for identifying the the Lancer Novi. Nice build BTW.
I still not sure about the Lancer #85 INDY STP SPECIAL? I will do a bit of searching.
#10 Martin
  • 4,234 posts
Posted 21 August 2022 - 04:32 PM
This is a good candidate for the Lancer #85 INDY STP SPECIAL.
Remeber #85 is an early Lancer number so maybe a 1965 car which I believe these pics are?
