Slick 7 kits and builds
Posted 24 August 2022 - 11:19 AM
Posted 24 August 2022 - 11:58 AM
Slick 7 made all sorts of kits, such as wing car, scale, retros, & others. What do you have? I have an old 1/24 eurosport kit & one for I-15, both unbuilt. Each came with a "how-to" sketch. I don't know if Slick 7 still produces slot car parts, but I haven't seen their ads in ages.
Posted 24 August 2022 - 12:32 PM
Always thought they were great looking. They were expensive when new/current and, they show up on evilbay often for equal amount or less. Fortunately, less , until people read this 🤣!!!
Posted 24 August 2022 - 12:52 PM
Yah, the instructions started out iffy and then got way better. I'd like to collaborate with everyone who has the ones I'm missing and post it in the history section
Posted 24 August 2022 - 03:11 PM
My Slick 7 eurosport kit cost me $10 in an eBay fire sale. Those chassis rust badly once they're built unless you coat them with an oil or an anti-rust product such as Boeshield. Ask you friends what they use on their cast iron tool beds such as table saws & jointers. If I still had a local track, I'd build the eurosport kit & put an FK motor in it.
Posted 24 August 2022 - 04:56 PM
Posted 24 August 2022 - 05:31 PM
I've seen Bill Fernald's post asking if Slick 7 was still in business and the responses which say yes, but most of the product is no longer available from distributors and there haven't been any new chassis in ages. A raceway/hobby store I visit still has some Slick 7 NOS which I've been slowly buying when I visit there. The Slick 7 chassis product was excellent, except for the rusting you've mentioned (unplated spring steel).
Posted 24 August 2022 - 08:22 PM
Posted 01 September 2022 - 08:04 PM
I forget what the instructions were that came with my partial Slick 7 kit, it's been so long since I looked at it. None of those you posted ring a bell, so I may have something different. But I'll save what you posted.
Posted 05 September 2022 - 08:48 PM
The instructions are off a little. They should be,
1)tin all areas BEFORE removing parts from the tree.
2) is ok
3) Solder ALL square tubes, and the.047 wire. Do not solder front uprights
4) omit soldering the square tube, you've done that in 3. Now, insert the front axle before soldering the front uprights*, and follow directions for rear.
5)&6) are ok.
* Note: You might also want to use some 3/32 wheel retainers.
I've got a few more suggestions but, you'll have to tune in tomorrow.
Posted 05 September 2022 - 08:50 PM
#15
Posted 06 September 2022 - 05:02 PM
Joining by use of KEYS is prohibited. Didn't even cross what's left of my mind that it applied to the bracket. On the other hand, it is part of the chassis.
I'm very relieved to hear that. I was just about to take a framing hammer to it. Really. It's a B***H to get together,on or off the chassis.
Not to push the issue but,I'd imagine if I cut the tabs/keys off...
It's for practice anyway. But....????
#16
Posted 06 September 2022 - 06:45 PM
If the tabs are difficult to go into the slots, as sometimes happens, make the slots wider. Usually plating causes this but your parts are raw brass. The keyed tabs provide strength & alignment. And you said you had 7 or 8 Slick 7 kits to build?
#17
Posted 06 September 2022 - 08:04 PM
IF (big if) I were building this kit (I have a Can Am kit), I would:
Cut the material from the outside of the slots for the struts,
Fit the width on the inside of the slots to the bracket you are using
Trim .032 (plate thickness) from the bottom of the motor mount side of the bracket
After soldering in the bracket and the rails (.062 wire) solder an "L" brace from the end of the rail to the motor mount face
#18
Posted 06 September 2022 - 10:16 PM
I think that had I not tinned the bracket assembly, it would have been ok. Another thing, as Pablo calls it, the brass "potato chips" from the heat required to solder all of the parts.
Yet another issue I had is the .063 rails. It made it tricky to solder the.047 "bite bar"? The centre square tube would have to be larger or shimmed to touch the chassis.
Overall, it's a nice kit. Very well engineered ( for the most part). How it works,IDK.
#19
Posted 06 September 2022 - 10:22 PM
After all the years of doing this, I still get toooo excited and rush instead of relaxing while doing them. Having done (almost) this one,at least I'm more acclimated to their design philosophy.
#20
Posted 06 September 2022 - 10:26 PM
#21
Posted 07 September 2022 - 05:51 AM
I have this Slick7 chassis kit - Instruction and one rear axle holder is missing - anybody interested ?? - send me a PM
- NY Nick likes this
Niels Elmholt Christensen, DK
Former Neckcheese Racing
#22
Posted 12 September 2022 - 09:14 PM
1) check the fit.
2) be careful what you tin.
3) it says,"can be assembled with out a jig". Use a jig .
4) this is the important one
BE CAREFUL HOW MUCH HEAT YOU USE
The motor bracket was so many joints that the chassis will become a brass contortionist.
#23
#24
Posted 12 September 2022 - 10:19 PM
I would have cut a wooden block to fit inside the motor bracket, then used it as a jig for soldering the pieces together. Have you got more brackets to build?
#25
Posted 13 September 2022 - 03:05 PM
