Track cleaning fluid
13 replies to this topic
#1 PCH Parts Express
PCH Parts Express
  • 2,500 posts
Posted 07 October 2022 - 11:59 AM
We use Naptha to clean commercial wood tracks.  But it's hard to purchase in our area. Besides Coleman fuel, what cleaner is good for this use?
Can mineral spirits be used?
Scott Salzberg
PCH Parts Express
#2 Bill Seitz
  • 608 posts
Posted 07 October 2022 - 07:33 PM
My experience with mineral spirits is that it leaves a sort of oily, slippery residue. I think you'd have to wipe the track down with something else to remove the residue. I have this same problem using Goo Gone which does remove the glue and rubber build-up fine, but again has a slippery residue. I use a damp towel water rinse with Goo Gone, but I'm not sure water will work with mineral spirits. You'd probably have to use alcohol. Alcohol, either metholated/denatured or isopropyl, will not remove traction glue and rubber buildup. You could try toluene or xylene/xylol (common glue/paint/lacquer removers), but I think they can attack/dissolve the finish on the track. I'd be very careful and spot test those solvents. If you have access to industrial solvents, halogenic solvents will also likely work and not harm the track finish, but getting them in California might be difficult (environmental and health impacts).
#3 Tim Neja
  • 6,847 posts
Posted 07 October 2022 - 09:37 PM
Toluene and xylene are VERY toxic!! I would stay far away from them.  Coleman fuel should be easy to find at sporting goods or trailer supply stores.
  • Half Fast likes this
#4 Dan Ebert
Dan Ebert
  • 1,218 posts
Posted 08 October 2022 - 08:05 AM
We use the Generic Coleman fuel sold at Wal-mart for Track Cleaning.  We use it on the Drag Strip for lane prep with no issues.   Coleman Fuel and Lighter Fluid are generally 99 percent Naphtha with 1% or less rust inhibitors.  So rather than using pure Naphtha at 20 bucks a gallon.  We use the Wal Mart brand Coleman at 8 bucks.   The myth is that Coleman Fuel leaves an oily residue.  But we haven't experienced that.
  • Tim Neja, Rob Voska and Hot Slots like this
GallerymanDan
#5 FastRichard
FastRichard
  • 80 posts
Posted 08 October 2022 - 12:52 PM
We have have had success using Greenworks on our routed track
Richard Sylvester
#6 parocket
parocket
    ASSCC
  • 285 posts
Posted 08 October 2022 - 01:01 PM
I use this to remove my medium spray glue. I just spray on rag and wipe. If its really bad a very light spray will remove the glue and rubber. It does not effect the clear coat I have on my track.No residue on track after cleaning. Nice citrus smell. Recommended by my paint supplier.
#7 FastRichard
FastRichard
  • 80 posts
Posted 08 October 2022 - 01:02 PM
https://www.homedepo...00450/202255942
Richard Sylvester
#8 Ramcatlarry
  • 2,956 posts
Posted 10 October 2022 - 07:40 PM
The 'citrus based' cleaners work good and are much less toxic, They also work to get that last bit of rubber off the track to make it look 'just painted' without dissolving the lane strips.  Msny brand names for them including 'Orange-u-glad' and others.
#9 Rob Voska
Rob Voska
  • 1,129 posts
Posted 10 October 2022 - 08:38 PM
I would not use anything water based.  It will get to the MFD through chips & start things expanding.
  • Tim Neja, Dan Ebert and swodem like this
#10 gotboostedvr6
  • 2,321 posts
Posted 11 October 2022 - 12:16 PM
The alternatives posted in this thread are water based and will ruin the wood.
  • Dan Ebert likes this
David Parrotta
#11 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 2,629 posts
Posted 11 October 2022 - 12:23 PM
Coleman fuel its what Port Jeff uses.
Cheers
Faster then, wiser now.
#12 Wizard Of Iz
Wizard Of Iz
    Slot Parrothead
  • 1,893 posts
Posted 12 October 2022 - 07:55 AM
I remember back in the '90s/'00s when the citrus-based Daddy-Os was the new track cleaning kid on the block.
Until long strips of braid started coming up.  ;)
  • Rob Voska and David Reed like this
Rollin Isbell
#13 parocket
parocket
    ASSCC
  • 285 posts
Posted 12 October 2022 - 10:52 AM
So far so good 7+ years using this and no issues with braid. Plus it has no water in it  to ruin track. As stated before the paint store were I bought my paint recommended it to try. Just a little on the rag does work.I used Naphtha until I switched to this do to the smell. The low voc Naphtha is no longer.
#14 swodem
swodem
  • 1,176 posts
Posted 12 October 2022 - 10:21 PM
We use the same lighter fuel to remove it that we apply it with
Methylated spirits cleans better, but removed the segments we have marked in Vivid pen
Steve Meadows
