Electron Raceway: True Scale NASCAR
#1 rvec
rvec
  • 1,930 posts
Posted 18 October 2022 - 09:02 AM
True Scale NASCAR is our latest addition to the Electron Raceway lineup. These feature the typical H-Bracket chassis such as the Scholer, 2Naste, Scaleauto, Slotting + or Plafit. The class uses the Deathstar or ProSlot 2002 Speed FX balanced sealed 16D motor. Again, the KISS principle is employed. All 1/25 NASCAR bodies fit on the Trans-Am/Sports car chassis with no modification. Therefore, only a body swap is required to move from one class to another. Front tires must tuck under the bodywork, however, rear track is set at 3.25 inches and tires may extend beyond the bodywork
Below are images of a typical NASCAR chassis and cars run in the class by all competitors.
Rich Vecchio
