Parma chassis ID
18 replies to this topic
#1 Michele Bilancia
Michele Bilancia
  • 66 posts
Posted 22 January 2023 - 10:27 AM
Good morning everybody! Could you please help me identifying this old Parma chassis and motor? Thanks in advance!
#2 slotcarone
  • 4,014 posts
Posted 22 January 2023 - 10:47 AM
That's an original Parma Flexi Car commonly called a Flexi 1. Ron will know exactly. :)
#3 Paul Menkens
Paul Menkens
  • 455 posts
Posted 22 January 2023 - 12:10 PM
The great grand daddy of hundreds of flexis that came after it!
  • Samiam and Dale Tomczyk like this
#4 jokar124
jokar124
  • 113 posts
Posted 22 January 2023 - 01:19 PM
......and the motor is the Parma Super 16D
Jo Salvaterra
#5 Michele Bilancia
Michele Bilancia
  • 66 posts
Posted 22 January 2023 - 04:03 PM
Is the motor coherent with the chassis? Armature is balanced and green, not epoxy....
#6 Bill Seitz
  • 604 posts
Posted 22 January 2023 - 04:33 PM
That does look like the original Parma S16D from the same period as the first Flexi chassis.
#7 Michele Bilancia
Michele Bilancia
  • 66 posts
Posted 22 January 2023 - 04:43 PM
Ok, thanks for the info.... What about a correct body?
#8 Michele Bilancia
Michele Bilancia
  • 66 posts
Posted 22 January 2023 - 04:44 PM
#9 Bill from NH
  • 14,870 posts
Posted 22 January 2023 - 04:58 PM
Any 4" body, other than most F1s, will fit this chassis. Choices are sports cars, coupes, stockcars, trucks, & others.
#10 old & gray
old & gray
  • 1,210 posts
Posted 22 January 2023 - 05:47 PM
Parma - Intrepid GTP
Parma-1015__39153.1482276472.jpg?c=2
  • Bill from NH and John Luongo like this
Bob Schlain
#11 John Luongo
John Luongo
  • 701 posts
Posted 22 January 2023 - 06:09 PM
that intrepid body on the flexi-1 made for a decent gtp racer. until the turbo-flex came along.
  • old & gray likes this
#12 MSwiss
  • 25,957 posts
Posted 22 January 2023 - 06:35 PM
Below is Flexi talk.
http://slotblog.net/...1-release-date/
http://slotblog.net/...ent#entry725236
The kick up in the back is highly exaggerated,
but the below pic from the patent shows a common body for the original Flexi when it came out.
I'm 98% sure it was referred to as a Porsche.
  • Phil Smith, NY Nick and Slot Car Rod like this
#13 Dominator
Dominator
  • 2,985 posts
Posted 22 January 2023 - 08:56 PM
The body in Mike's diagram is a Porshe.
Dominic Luongo
NERR photos from 2016 to now
#14 Michele Bilancia
Michele Bilancia
  • 66 posts
Posted 23 January 2023 - 12:56 AM
Which color was the rear crown insert?
#15 Dominator
Dominator
  • 2,985 posts
Posted 23 January 2023 - 11:45 AM
The early flexi's used a brass pinion and cobra spur gear.  Late 80's stock gearing was 8/34.  At some point in the early 90's the pinions went to steel plated and the spur went to a 30 or 28 PSE crown.  I would have to dig up some of my slot car bulletin mags to get a better time period.
Dominic Luongo
#16 John Luongo
John Luongo
  • 701 posts
Posted 23 January 2023 - 12:08 PM
i seem to remember the cobra gears being a gray color with the later pse gears being pink. the cobra gears would sometimes loosen up on the hub, allowing them to "clock" under power. bona fortuna, michele
#17 Michele Bilancia
Michele Bilancia
  • 66 posts
Posted 23 January 2023 - 12:32 PM
Guys, thank you very much for the info!
#18 Bill Seitz
  • 604 posts
Posted 23 January 2023 - 08:02 PM
Before Parma introduced their pink spur and crown gears, they used whatever "generic" black 48P spurs that were available. I think REH was making these, and many didn't have any brand imprint or indicated Cox. The first gen Parma S16D motors I had came with brass or nickel-plated brass 9T, 48P pinions, so I expect that's the pinions that were used in the RTR cars. A 9/30 ratio might work, although from the factory I'd expect a little higher than that, maybe 32 or 34, though I never had one of the RTR cars.
  • John Luongo likes this
#19 Michele Bilancia
Michele Bilancia
  • 66 posts
Posted 25 January 2023 - 04:01 PM
Is this the correct pinion?
