'Huerfano' - an old Retro chassis gets rebuilt
30 replies to this topic
#1 Pablo
  • 18,454 posts
Posted 16 March 2023 - 10:58 PM
Like an abandoned baby dropped off on my doorstep, this chassis was in rough condition. But I liked the torsion plate so I took a better look.
The soft brass plate was worth salvaging and I think it's got potential. After solder removal and rough sanding, it's close to flat. I'll build it up just for fun.
  • Tex, Chris Stemman, Alchemist and 6 others like this
#2 Alchemist
  • 2,702 posts
Posted 16 March 2023 - 11:04 PM
Hi Pablo!
Hope all is well.
I'm looking forward to this buildup.
Thanks for sharing.
  • Geary Carrier likes this
#3 Bill from NH
  • 14,768 posts
Posted 17 March 2023 - 07:35 AM
I'm guessing this chassis was built using R-Geo brass pieces.
#4 Pablo
  • 18,454 posts
Posted 17 March 2023 - 10:26 AM
Thanks, Bill. If I had to guess, I'd say it's maybe from the beginnings of IRRA® ?
#5 Bill from NH
  • 14,768 posts
Posted 17 March 2023 - 10:40 AM
I have a R-Geo retro piece that might be older. It has no coined tongue but came with a separate tongue to be soldered on. It was Joe Poulin's when he was alive.
#6 Don Weaver
Don Weaver
  • 1,856 posts
Posted 17 March 2023 - 02:46 PM
WELCOME BACK, PABLO !! :clapping:
  • Tim Neja and olescratch like this
Don Weaver
L.H. Lapham
it will starve to death...
#7 dc-65x
  • 6,982 posts
Posted 17 March 2023 - 05:14 PM
:wave:  Hi Pablo.   :wave:
Looking forward to your project.
#8 Pablo
  • 18,454 posts
Posted 17 March 2023 - 09:13 PM
Thanks guys. Don, I never left, just "changed gears" a little  :)
I realized the GL is a whopping .975" !! IRRA® Can Am and GTC cars are usually about 4" WB and .9" GL.
So I hit the pause button and will be looking at that before proceeding .....
#9 slotcarone
  • 3,993 posts
Posted 17 March 2023 - 09:29 PM
That GL is fine. Many IRRA cars use 1 inch GL. That pan is similar to the JK kit that came out real early. I built a few dozen of them for customers with solid pans like that. They worked great at the time. :)
  • Pablo and Tim Neja like this
#10 Pablo
  • 18,454 posts
Posted 17 March 2023 - 10:34 PM
Thanks for coming to my "emotional rescue", Mike K.   :)  I put a flag on it and it looks like a good enough fit for a GTC body  :good:
Found a new FSF 1.4" wide motor bracket with inner brace here from Tom Thumb Raceway, looks like it will work.
#11 Pablo
  • 18,454 posts
Posted 18 March 2023 - 12:56 PM
The plate is only .032 thick so I doubled the tongue with a brass .063 Chicagoland gizmo. A hard wallshot will probably just bend it somewhere else, but at least I'm trying  :pardon:
Mini-torched on with 60/40, properly aligned and tilted
  • Tim Neja and Larry Horner like this
#12 old & gray
old & gray
  • 1,209 posts
Posted 18 March 2023 - 01:24 PM
Curse you Paul, just when I was starting to look away you bring back a worthwhile interesting thread.  :)
  • Pablo likes this
Bob Schlain
#13 Pablo
  • 18,454 posts
Posted 19 March 2023 - 08:42 PM
:crazy:
Huerfano is coming back to life slowly but surely. The FSF super wide bracket isn't a good choice for this plate - a JK 1" wide hypoid is perfect. The rail slots on the front end are set up for a .078 and a .063 rail each side, so that "drives the show"
Bracket braced with .039 wires, top end notched for motor shaft entry (the newer motors swing huge pinions), axle tubes trimmed inside with reverse counterbore gizmo. Doesn't add any speed, just looks more sano  :)
  • NSwanberg and olescratch like this
#14 Pablo
  • 18,454 posts
Posted 20 March 2023 - 11:28 PM
Split .055 bite bar: to compensate for the .078/.063 rail disparity I sliced pieces of 3/32 tube in half and soldered them to the .063 rails
I'm guessing this is what the plate was designed for
  • MSwiss, Tim Neja and NSwanberg like this
#15 NSwanberg
NSwanberg
  • 2,036 posts
Posted 21 March 2023 - 12:48 AM
Splitting the tubing! I like that.
  • MSwiss likes this
SUPPORT YOUR LOCAL RACEWAY!!
Nelson Swanberg 5618
#16 Pablo
  • 18,454 posts
Posted 22 March 2023 - 09:56 AM
Overnight tumble got it down to fresh brass almost 100% - good enough for me.
Tops of front axle supports were sliced off a la Tony P. and pre-tinned with acid so a BB wheel/axle assembly will drop in and be soldered with paste
  • Jencar17, Dominator, NSwanberg and 3 others like this
#17 dc-65x
  • 6,982 posts
Posted 23 March 2023 - 11:35 AM
Nice work Pablo. It sure looks shiny to me. Did you bring a supply of that Mississippi water
that's worked so well for tumbling with you on your move?    :D
  • olescratch likes this
#18 Pablo
  • 18,454 posts
Posted 23 March 2023 - 04:44 PM
Thanks Rick. Tennessee tap water is very similar to MS water - pure, clean, tastes great. The catfish up here grow big as a man so I guess it's good.
Front wheels will be ARP BB's, motor CR 102, and body will be a Bill Pinch lacquer painted IRRA® legal Kelly Lola T163 Can Am with a Boogie interior  :dance3:
Like the world's luckiest orphan after a shopping trip to La Jolla   :sun_bespectacled:
#19 Pablo
  • 18,454 posts
Posted 27 March 2023 - 10:09 PM
Once you've been to a major IRRA retro race tech inspected by Joe Neumeister, it gets in your blood.
When you pass, you feel like you accomplished something good   :D
ARP fronts on tinned wire axle, 3.125" wide, washed dried and ready to drop in
  • MSwiss likes this
#20 Pablo
  • 18,454 posts
Posted 29 March 2023 - 12:32 PM
Huerfano is ready for body mounting. CR102 motor ready but not installed until pinion size is chosen. Front end clears about .025 (fudge factor) with legal rear height. Nothing fancy here, just the basics.
Lately I've been liking the James Cleave wire management style and that's how they are set up, tinned, trimmed, and ready to curl using the existing hole gizmos on the plate
  • Jencar17, Tim Neja, Slot Car Rod and 1 other like this
#21 Pablo
  • 18,454 posts
Posted 01 April 2023 - 12:08 AM
Huerfano is done, ready to test and race. Total weight as shown 107g. A pair of .032 thickness lead circles will fit nicely in the rear holes at ground zero, but we will test it first
Bill Pinch lacquered Kelly Lola T163 with Boogie interior
  • Jencar17, NSwanberg and Slot Car Rod like this
#22 Pablo
  • 18,454 posts
Posted 02 April 2023 - 11:01 PM
The relic is ready for a test this Tuesday. 11T pinion is probably too big for the flat track, but let's wring it out anyway. Some lead added
  • Jencar17, Tim Neja and Slot Car Rod like this
#23 SpeedyNH
SpeedyNH
    Old Engineer
  • 763 posts
Posted 03 April 2023 - 08:27 AM
an angled pinion?
Steve Lang
#24 Pablo
  • 18,454 posts
Posted 03 April 2023 - 09:21 AM
Of course. The bracket is hypoid
#25 slotcarone
  • 3,993 posts
Posted 03 April 2023 - 09:52 AM
Looks great Pablo! I have never found any difference using a straight or angled pinion with a hypoid bracket.
Either way after a race the teeth on the crown gear are now angled too. :)
  • brnursebmt and Tim Neja like this
