Advice on straightening hardbodies
7 replies to this topic
#1 team burrito
team burrito
  • 2,204 posts
Posted 11 April 2023 - 12:21 PM
What's the best way to fix a warped plastic body? I'm working on a hardbody and it is slightly warped. I heard you can use hot water.
What temperature do I use - boiling hot, hot, warm? I just got the body where I want iand & don't want to screw it up.
Russ Toy (not Troy)
#2 Alchemist
  • 2,723 posts
Posted 11 April 2023 - 12:26 PM
Hi Russ,
Maybe this might be of help:
  • team burrito likes this
#3 Tim Neja
  • 6,847 posts
Posted 11 April 2023 - 02:05 PM
I"ve used a hair dryer with good results.  You DO have to be careful to monitor the temperature of the plastic--But I've straightened the sides and put small wheel well flares with the use of a hair dryer
#4 Martin
  • 4,328 posts
Posted 11 April 2023 - 11:34 PM
Yep, hot water works every time ( I would guess around 200f ) . Don't forget to hold where you want it to stay then dunk in cold water to set. Works on clear bodies too.
  • team burrito and Tim Neja like this
#5 NSwanberg
NSwanberg
  • 2,052 posts
Posted 12 April 2023 - 05:29 AM
I can tell you what not to do. Don't put it in a toaster oven.
  • team burrito, Tim Neja, Eddie Fleming and 1 other like this
SUPPORT YOUR LOCAL RACEWAY!!
Nelson Swanberg 5618
#6 team burrito
team burrito
  • 2,204 posts
Posted 12 April 2023 - 11:31 PM
i made the mistake of putting a freshly painted body in the back of my car at work. when i came back to check on it, the body was melted on the stand. whoops!
  • Tim Neja and NSwanberg like this
Russ Toy (not Troy)
#7 Mark Onofri
  • 2,535 posts
Posted 29 April 2023 - 01:15 PM
I've been building styrene models for ever. The best way is a light bulb, unless you've totally screwed it up. In that case, lighter fluid is a sure fire(lol) way to rectify the situation.
#8 Mark Onofri
  • 2,535 posts
Posted 29 April 2023 - 01:17 PM
PS: ware gloves!
