1969 Gorski Lola build-up
20 replies to this topic
#1 Jairus
  • 10,174 posts
Posted 14 July 2023 - 11:58 AM
A customer wanted me to replicate this chassis once ran by John Gorski in '69.  Right away I realized the difficulty being not having a Team Nuttley drop arm, .050 brass nore any square steel wire.  .062 Steel wire rod wouid have to suffice in a pinch.  The chassis is this one.
And parts collected include vintage wheels and tires, 1/8" axles, bearings, Jet flag and other bits.
The motor is a Champion 517 I believe with a rewound arm and very strong white dot magnets.
And the body which is a beautiful very thin boxed Dynamic Lola.
And the cut brass...
Time to set up the jig. :)
  • mjsh, Jencar17, Tex and 7 others like this
Jairus H. Watson
3/12/59-5/19/25
  • 14,991 posts
Posted 14 July 2023 - 04:15 PM
Looks like a nice project Jairus. I don't know when John started chassis building. In the early '70s Gorski was selling Tony P's.
#3 Martin
  • 4,420 posts
Posted 14 July 2023 - 05:14 PM
I'm In :good:
Are you going to use flat wire like the pic ? Can you still buy that stuff?
#4 Bill from NH
  • 14,991 posts
Posted 14 July 2023 - 05:33 PM
REHCO was still selling a drawn flat wire as of a few years ago. Not as consistent as ground flat wire, like Champion once sold.
#5 Jairus
  • 10,174 posts
Posted 14 July 2023 - 06:25 PM
The way John describes the build is .62 wire was flattened to .045.
Pretty sure he didn't use a hammer but a roller, which I do not have.  Besides the steel wire is realllllly hard stuff.
Jairus H. Watson
3/12/59-5/19/25
#6 Bill from NH
  • 14,991 posts
Posted 14 July 2023 - 07:13 PM
Have any machine shop friends who could grind it flat? You could roll or hammer on piano wire all day long & not change its diameter. Annealing may help, but that's too much work to build one slot car chassis. Stick to your original plan to use round wire.
#7 Martin
  • 4,420 posts
Posted 15 July 2023 - 12:35 AM
Sorry Jairus, I should of read your build statement closer. When you clearly said ''.........nore any square steel wire''.
I am sure it was laid out side by side and magnetly stuck to a surface grinder and then ground to size. As Bill suggests any one with a surface grinder and the time, could do it.
#8 Jairus
  • 10,174 posts
Posted 15 July 2023 - 06:49 PM
Well, Slot Car Saturday was a great success.  I built a center section.
Architecture is same as Gorski except not using the square rod.  Turned out pretty well with .62 outside rails and .55 inside rails.
Wheel base is 3 and 3/4" which is maximum for that Dynamic Lola.
I also received a color photo of a Gorski car so now I know how to paint it.
B:)
  • Jencar17, Tex, Tim Neja and 5 others like this
Jairus H. Watson
3/12/59-5/19/25
#9 Jairus
  • 10,174 posts
Posted 17 July 2023 - 02:54 PM
Got a tongue constructed and installed in the frame.  Next up is the plumber then pans and stops.
:heat:
  • Pablo and Larry Horner like this
Jairus H. Watson
3/12/59-5/19/25
#10 Jairus
  • 10,174 posts
Posted 19 July 2023 - 11:28 AM
Well, yesterday I finished the plumber and pan hinges.  Next step is to install all the limiters and stops.
B:)
  • Tex, team burrito, Bill from NH and 3 others like this
Jairus H. Watson
3/12/59-5/19/25
#11 Martin
  • 4,420 posts
Posted 19 July 2023 - 08:10 PM
Great progress Jairus. Looking forward to the body paint too.
  • olescratch likes this
#12 Jairus
  • 10,174 posts
Posted 20 July 2023 - 01:40 PM
Pan stops, plumber stops and some  springs installed now.  Next we start hanging on all the parts and lead wires.
Can paint be very far behind? :)
B:)
  • Tex, NY Nick, Slot Car Rod and 2 others like this
Jairus H. Watson
3/12/59-5/19/25
#13 Jairus
  • 10,174 posts
Posted 26 July 2023 - 05:36 PM
Finally got the chassis together and the body mounted.
Also painted up the interior, but did that about a week ago.
Gear mesh is smooth with ball bearing races.  Didn't have any Marklin wire so just went with some cool colored silicon wire for the time being.
B:)  Time for more paint....
  • Tex, NSwanberg, Regis4446 and 1 other like this
Jairus H. Watson
3/12/59-5/19/25
#14 Jairus
  • 10,174 posts
Posted 28 July 2023 - 10:39 AM
Painted finally.  Hopefully I captured the original.
  • Jencar17, Bill from NH, NSwanberg and 3 others like this
Jairus H. Watson
3/12/59-5/19/25
#15 Larry Horner
Larry Horner
  • 489 posts
Posted 28 July 2023 - 11:15 AM
Gorgeous as usual Jairus! I have a question I should have asked before: How did you cut the brass and specifically the opening in the drop arm? I know of various ways it could be done but the pieces you show above have very clean lines. I know if I was to attempt it, I would probably just skip doing it myself and have it laser cut.
#16 Jairus
  • 10,174 posts
Posted 28 July 2023 - 12:09 PM
Drill the corners, then cut the straight lines with a dremel disc.  File and sandpaper last.
It takes time, but the results are worth it.
  • NSwanberg, Eddie Fleming and Larry Horner like this
Jairus H. Watson
3/12/59-5/19/25
#17 Jairus
  • 10,174 posts
Posted 29 July 2023 - 11:02 AM
Well, finally finished this Lola this morning.  One change by the customer was to replace my sig with that of Dave Bloom's.
And there we have it.....
Oops, forgot the spoiler.  (sigh)
Respectfully submitted, B:)
  • Jencar17, Tex, team burrito and 7 others like this
Jairus H. Watson
3/12/59-5/19/25
#18 Dominator
Dominator
  • 2,999 posts
Posted 29 July 2023 - 11:55 AM
Another masterpiece!
Dominic Luongo
NERR photos from 2016 to now
#19 Jens Scale Racing
Jens Scale Racing
  • 181 posts
Posted 29 September 2023 - 02:40 AM
Wonderful!
Dieter "DJ" Jens
JSR gallery
#20 Regis4446
Regis4446
  • 455 posts
Posted 30 September 2023 - 04:02 PM
:good:  :good:  Superb
Regis Baron
#21 Don Weaver
Don Weaver
  • 1,870 posts
Posted 01 August 2024 - 06:07 AM
Well, it's been a year since your last build here on SlotBlog.  Always enjoyed looking over your shoulder and sure would like to see more...
  • mjsh and Jencar17 like this
Don Weaver
L.H. Lapham
it will starve to death...
