Mossetti chassis variants
Posted 29 August 2023 - 07:26 PM
- dave burch likes this
Posted 29 August 2023 - 09:39 PM
Adam .... welcome to my confusion when I resumed racing last year after a long hiatus. It was quickly obvious that my JK Cheetah X25 and JK Aeolus chassis were too heavy for the Florida Slot Car Series (FSCS) LMP and GTP classes. .... So, I created a table that would - hopefully - let me pair the right components. My budget doesn't allow for just throwing money at different components just to test a theory.
I don't drive well enough to use Aluminum pans ... but the Mossetti Aluminum pans seem to be WAY more durable than the JK Aluminum pans.
From my VERY brief exposure to the Mossetti line of chassis components .... here's my observation.
The original Avenger and Defender center sections are the ones with the "horns" in the front. Both have been discontinued ... but some are probably still hanging around some track walls. From talking with racers who have ran these longer than I have, these center sections handle really well ... but those horns are prone to getting bent and tend to damage bodies.
The Avenger Air center section works pretty good ... but can only take the "stock" Heavy pan or the Insane pan. That limits its versatility. I had one ... and sold it.
The Avenger 2 center section is compatible with all of the Mossetti pans and seems to build into a car that's consistent and perhaps more forgiving. Makes it very suitable for a track that's not super smooth.
The Defender 2 center section is compatible with all of the pans and I think it builds into a car that might be a tick faster ... in the hands of a racer who has the skill to drive a car on the edge. And, I think it's a better choice on smooth tracks and ones that have more banking.
My solution was to gradually build cars with each center for the LMP and GTP classes in the Florida Slot Car Series (FSCS).
In FSCS, our Stock Car class (CR-102 motors geared 13:35 or 14:35 or Mid America Retro Eagle motors geared 13:35) has a 92 gram minimum weight limit, so I have an Avenger 2 Center (#3013) with the Heavy Weight Steel Pan (#3122) and one with a Heavy Oval Track Pan (#2034) to use when we race at Fast Eddie's in Pinellas Park. My other Stock Car is a JK C43 Aeolus which is right at the weight limit and is also very competitive.
Our LMP class (same motor rules as Stock Cars) has a 82 gram minimum weight limit, so I have an Avenger 1 Center (#3012) with an Ultra Light Steel Pan (#2024) which then needs just a couple of strategically placed weights to make the minimum. And, I have a Defender 2 Center (#2015) with an Ultra Light Steel Pan (#2024) that also needs just a little weight added to it. I find that I run the Defender 2 more often than the Avenger in this class. Though ... I might have better finishes if I drove the more comfortable car (Avenger) that fits my diminished reflexes rather than the faster car.
Our GTP class (Ralph Thorne Raptor Pro or Mid America Enforcer motor geared as you please) doesn't have a weight limit so I have an Avenger 2 (#3013) and a Defender 2 (#2015) each setup with the Mega Ultra Light "Insane" Steel Pan (#2039). However ... I know a couple of really fast guys use the Ultra Light Extreme (#2035) as they feel like it builds a more balanced car. My eyesight has a little trouble with these cars so I tend to use the more comfortable Avenger 2 car .... though my Defender 2 car is faster.
Here's the table
Mossetti Chassis Components - 082923 PDF.pdf 74.8KB
235 downloads
- dave burch and AB75 like this
Rollin Isbell
Posted 31 August 2023 - 10:05 AM
I got the following January 2023 order form (product list) from Ernie:
Posted 31 August 2023 - 03:50 PM
I still haven't found a clear, concise explanation of the different variations of their chassis.
To get you to buy them.
- Eddie Fleming likes this
Posted 31 August 2023 - 05:22 PM
Lighter pans bring reliability issues as well, i stick with the steel pans.
