A number of 0.530 diam S16D's arms have come into my possesion. Do I shim a rotor setup or just run with a large air gap?
I have noted here that 16D arms like a bit of breathing space, but how much is too much?
Thanks in advance, PC-S
Posted 24 September 2023 - 03:51 PM
Posted 25 September 2023 - 05:09 PM
Standard diameter for 16D arms is .520. Some of the 16D setups with .150 thick magnets have enough room for at least a .540 arm and in some cases a .560. Personally, I don't like running a .520 arm in these setups, and opt for replacing the magnets to drop the "hole" down to .540. S16D's especially seem to like that. Otherwise, I run a larger diameter arm. So, if you have setups with .150 magnets and the larger "hole", running a .530 arm shouldn't be a problem. You'll get a little more torque and brakes.
Posted 25 September 2023 - 05:56 PM
You can run them that way.A number of 0.530 diam S16D's arms have come into my possesion. Do I shim a rotor setup or just run with a large air gap?
Posted 25 September 2023 - 06:30 PM
And get gobs of RPMs Danny?
Posted 25 September 2023 - 07:38 PM
Probably but I can't say for sure except the the lap times were faster.And get gobs of RPMs Danny?
Posted 29 September 2023 - 04:45 PM
Many thanks for your helpful comments. I measured the airgap in a new PS S16D motor at 32thou, so there you go. These motors should all run cooler if correctly geared I think.
My experience with newer motors is growing thanks to you guys and this forum.
PC-S
