Slot car tire truing machines - past, present, & future
17 replies to this topic
#1 MrFlippant
MrFlippant
  • 308 posts
Posted 22 March 2024 - 01:20 PM
Slot Car Tire Truing Machines Past/Present/Future
This is intended to be a reasonably comprehensive list of "commercially" made tire truing machines. That means a machine was made in some quantity to be sold to other people than it's creator. This does not include every DIY machine ever made, though some are included at the end if they have appropriate models/instructions to follow. It also does not include any machine that does not hold the wheels/tires at a set and adjustable distance from the sanding medium. Sandpaper-on-a-track type devices do not qualify as truing machines, no matter how steady your hands are. I'm sure I'll have missed some, and some machines will be forthcoming, so please post any I missed and any upcoming machines yet to be listed. It's also worth noting that there are lots of RC machines out there, but without confirmation that they work with common slot car axle and wheel/tire sizes, I chose not to list them, even the Mini-Z ones. If you know of a machine sold to RC racers that definitely works for some kind(s) of slot car wheels, please mention it.
The list is divided into machines designed for metal wheels, usually only truing one wheel/tire at a time, and machines that are designed to hold the whole axle of the car with both wheels still attached and being trued at the same time. Each list is then divided by whether the machine is still available on the retail market in some capacity (even if out of stock, assuming more are being made), and those which are no longer being manufactured by anyone. The order in which any machine appears in the list is NOT an indication of quality or rating. No subjective assessment of any machine has been made. They are in no particular order aside from those mentioned above. Links and images are what I could find while writing this list and may be out of date or no longer accessible in the future. Updated or better links are welcome. Prices listed are retail prices in USD at the time of writing and does not include accessories, taxes, or shipping.
Removable/Metal Wheel Machines
Currently Available
Mid America Precision Diamond Tire Truer
- Single wheel at a time, counter-rotating sanding drum
Hudy - $300
TWP Products - $200
PN Racing - $240
- Single wheel (maybe two) at a time, counter-rotating sanding drum
Backtrack - $500
- two wheels at a time, counter-rotating sanding drum
ILPE TTM-2 Reifenschleifmaschine
- single wheel, spinning sanding disk
Hot Grinder Pro
- two wheels or whole axle, counter-rotating drum
Eben Brand's Slot Car Tyre Truer - $480
- Single wheel, 3d printed, detailed electronic controls
Secondary Market Only (no longer manufactured)
WrightWay tire truer - $??
- Single wheel, counter rotating drum
NSR 4401 - $300
- single wheel, spinning sanding disk, tire treatment applicator
ScaleAuto - $??
- Single wheel (can do two), counter-rotating sanding drum
Frankenslot RSM
S&K Tire Truer
- Single wheel at a time, lathe style
BSV Tire Truer
- Single Wheel at a time, lathe style
Werner Lange tire truer
Slotcars Technology (slotcars.it)
- unable to find functional link for more info or photos
Whole Axle Machines (both wheels at the same time)
Currently Available
Overdrive RSM
- Sliding Plate. 3rd party reciprocator available.
Main Street Racing MSR - $250
CG Slotcars - $190
- Sliding Plate. OEM reciprocator available.
G&S Tire Grinder - $150
- Dual counter-rotating sanding drums
Rob Bush Swift Sixteen - $160
- Sliding plate.
Tire Razor - $145
Tyre True (Area3 or Professor Motor) - $240
Do It Yourself
JMay Simple 3dp Tyre Grinder
- Fixed sanding plate, powered by slot car motor and gears, two wheels at a time, but removable wheels only.
Johnnie Hobby's 3DP machine
- whole axle (two wheels at a time), Sliding Plate
Tyre Truer MKIII for slot cars 1/32
G&S Tire Grinder
- whole axle (two wheels at a time), Dual counter-rotating sanding drums
Tyre & Wheel Trimmer for 1:32 Axles
- whole axle (two wheels at a time), Sliding Plate.
SSR Tire truer
Slottolution Reifenschleifmaschine Tire Truer 3mm
KOMPLETTACHSENSCHLEIFMASCHINE SLOTCAR CARRERA DIGITAL 132 /124
SlotCar 3D
- Dual counter-rotating sanding drums, Carrera 1/24 only.
  • Cheater, team burrito and Steve Deiters like this
#2 Martin
  • 4,315 posts
Posted 22 March 2024 - 07:55 PM
Well you did say "past" here is one that I restored some time ago. Hope this adds to the extensive list you compiled, well done  :clapping:
  • nicky 65 and MrFlippant like this
#3 old & gray
old & gray
  • 1,210 posts
Posted 22 March 2024 - 11:45 PM
1990's JK Flat sanding bar & trimer for width.
  • Rob Voska, MrFlippant, John Luongo and 1 other like this
Bob Schlain
#4 MrFlippant
MrFlippant
  • 308 posts
Posted 23 March 2024 - 09:45 AM
Nice! I had a feeling I'd get more vintage stuff when I posted this list. :) I'll get those added to the list later today.
#5 old & gray
old & gray
  • 1,210 posts
Posted 23 March 2024 - 06:37 PM
This is such a museum piece that I was using it today.
Bob Schlain
#6 Samiam
  • 4,780 posts
Posted 23 March 2024 - 07:35 PM
I have one of Rick's R-geo tire truers.
  • Rob Voska and bbr like this
#7 Rob Voska
Rob Voska
  • 1,129 posts
Posted 23 March 2024 - 08:08 PM
Kalhoza has a couple, KV, S&K, BSV
#8 Bill from NH
  • 14,869 posts
Posted 23 March 2024 - 08:11 PM
I don't recall what the RGEO tire truer looked like.
I recall when Jerry was "fire selling" those flat sander tire truers for $35. I should have bought one, but I had a Cobra.
#9 MrFlippant
MrFlippant
  • 308 posts
Posted 23 March 2024 - 09:38 PM
Apparently anything older than 20 years can be referred to as "vintage" of whatever year/decade it was made in, or popular during. :)
#10 Clyde Romero
Clyde Romero
  • 1,165 posts
Posted 25 March 2024 - 12:43 PM
I own an Eban Brand tire machine it's great.
  • MrFlippant likes this
#11 Eddie Fleming
  • 2,957 posts
Posted 26 March 2024 - 06:34 AM
Have you got a photo Clyde?
Never mind I finally made the connection to the video above.
#12 SlowBeas
SlowBeas
    Troublesome De-slotter
  • 1,011 posts
Posted 06 April 2024 - 08:10 AM
Actually, it looks just like the JK truer above. (I have one, also.)
jb
  • Bill from NH likes this
Jim Beasley
South Carolina, USA
- Pat Paulsen, 1968
- Steven Wright ca. 1983
#13 Steve Ogilvie
Steve Ogilvie
  • 633 posts
Posted 06 April 2024 - 09:46 PM
Funny I just used my 20 some odd years old ILPE tire truer to see if I could bring some older tires back to life. I used a power reducer to control the speed and it worked great. I was sure the belts would just disintigrate because they were so old. And this was the first time it had ever been used, shows how keeping something in a box  will preserve rubber that looks like old whisperjet belts. This ILPE is very similar to the 2 motor unit listed above. The tires are working close to new again, so now I can make close to new tires whenever I need them. I also have a single motor unit but the belts are toast on it.
#14 Bill from NH
  • 14,869 posts
Posted 07 April 2024 - 06:46 AM
Are ILPEs the machines with the two revolving flat disks 90 degrees to each other? one for cutting the tire surface & the other for cutting the sidewalls? I seem to recall seeing ads years ago.
#15 MrFlippant
MrFlippant
  • 308 posts
Posted 07 April 2024 - 09:52 AM
I posted a link to it.
#16 Eddie Fleming
  • 2,957 posts
Posted 07 April 2024 - 10:39 AM
I have a Hudy that I have had for years. It is the only truer I have ever owned. It works great unless you need to adjust for your tires coming out tapered. The loosen the screw and move the block adjustment is like farting in the wind. I know about clamping on a reference point and shims and all that but at best that is a pain.
Having said that how many of these truers have an adjustment to square up the tire and the grinding surface? I know the the Back track that Swiss sold has an adjustment screw. Do any of the others?
#17 MrFlippant
MrFlippant
  • 308 posts
Posted 07 April 2024 - 10:08 PM
Some do. It's something that should be engineered from the beginning, IMHO. It seems that even the most well built machine can be or get a tiny bit out of whack.
For my part, the G&S Tire Grinder I designed does have a method for tramming the sanding spindle to the axle, and I'm working on a revision that makes it much easier than it currently is. But, my machine is 3d printed, so most people disregard it when it comes to high performance truing. The closest design to mine is the Hot Grinder Pro, which is milled from billet aluminum, so usually garners more respect, but I don't know what kind of tramming it has.
#18 gotboostedvr6
  • 2,321 posts
Posted 08 April 2024 - 11:49 AM
Here is a Wrightway
David Parrotta
