Hawk 7 motor
#1 Dave_12
Dave_12
  • 113 posts
Posted 24 June 2024 - 04:15 AM
What is the recommended maximum voltage for a Hawk 7 motor?
David Rees
#2 MSwiss
  • 25,929 posts
Posted 24 June 2024 - 12:48 PM
It's no different than any other slot car motor.
Gear it for the power level for the track you race on, which is most likely somewhere between 12-14.3V.
FWIW,  the Hawk 7 is a popular drag motor.
Drag strips will regularly run 16-16.5V, but of course, for just a split second.
  • Dave_12 likes this
#3 Bill Seitz
  • 589 posts
Posted 24 June 2024 - 07:25 PM
Some motors of this type say on the package "12 volts". I've seen a few that indicate "12 volts maximum". I've never seen anyone anywhere really adhere to such voltage recommendations, and they're often run to 13.5 or more volts. In practice, the maximum voltage is usually whatever they don't fail at. Higher voltage makes faster cars, but it also shortens motor life. It's best to use the lowest voltage that's fast enough. When slot car tracks were auto battery powered, unless the charger was running and the batteries were fully peaked (not often once cars start running), the voltage tended to be around 13.2 volts down to 12.6. Now many tracks are at least 13.5 and stay there indefinitely.
