Motor springs for G12?
10 replies to this topic
#1 Dave_12
Dave_12
  • 111 posts
Posted 10 August 2024 - 11:08 PM
What motor springs are recommended for a G12 motor being raced on a high power track ( 3.8 to 14 volts)?
David Rees
#2 team burrito
team burrito
  • 2,202 posts
Posted 11 August 2024 - 12:52 AM
Champion red springs (now Pro Slot).
Russ Toy (not Troy)
#3 Dave_12
Dave_12
  • 111 posts
Posted 11 August 2024 - 01:25 AM
Russ,
Champion springs go soft and lose tension, even on a medium power track.
What springs would these be?
David Rees
#4 mreibman
mreibman
  • 635 posts
Posted 11 August 2024 - 07:07 AM
At PJ Raceway, which is pretty fast and with great power, for One Motor Cox 12, I would recommend Cahoza 3-coil springs.
  • team burrito and Dave_12 like this
Mike Reibman
Alleged amateur racer.
Faster than a speeding Womp.
More powerful than a 36D.
#5 zipper
zipper
  • 1,088 posts
Posted 11 August 2024 - 11:56 AM
I'm mostly using Camen 5-coil double overHead springs.
  • Dave_12 likes this
Pekka Sippola
#6 team burrito
team burrito
  • 2,202 posts
Posted 11 August 2024 - 05:29 PM
If that's the case, i would use shunts and spring insulation.
That would be my second choice.
The 5-coils are too much, IMHO.
Russ Toy (not Troy)
#7 Bill Seitz
  • 582 posts
Posted 11 August 2024 - 07:11 PM
I'd suggest one of the 3-coil springs. Ones I've used are Dubick and Koford, and Cahoza is another choice. Due to Camen not having made springs in quite a few years, they'll be hard to find, and the only ones suitable for a G12 will be the "Light" springs. I've encountered recent motors where the spring post isn't long enough to fully support a 5-coil spring.
#8 Mr. M
Mr. M
  • 585 posts
Posted 11 August 2024 - 07:34 PM
The Camen 5 coil with the half bend putting the spring brush contact right in the middle was Camen genious. Seems no one else knows how to do this and Joel is not telling!
  • team burrito and NSwanberg like this
Chris McCarty
#9 Dave_12
Dave_12
  • 111 posts
Posted 12 August 2024 - 12:05 AM
team burrito  always use shunts and insulation  on all Can motors .
David Rees
#10 Bill Seitz
  • 582 posts
Posted 12 August 2024 - 01:17 PM
Yes, the half-bend on the Camen 5-coils was a neat feature. The bent wire pillow blocks on the Camen Snapper chassis is some even fancier wire bending. 3-coil springs don't need the half-bend. If they're oriented properly with the long arm down against the hardware, the short end is in the middle where it needs to be.
#11 Jason Holmes
Jason Holmes
  • 1,263 posts
Posted 13 August 2024 - 02:01 PM
Dave
If you can Find Camen Lite's 5 coil if not Cahoza 160's 5 coil work fine
Jason
