Masking tape recommendation?
12 replies to this topic
#1 Dave_12
Dave_12
  • 139 posts
Posted 19 August 2024 - 05:18 AM
What kind of masking tape do you recommend that won't allow wet paint to soak underneath and give a clean line when removed?
David Rees
  • 14,994 posts
Posted 19 August 2024 - 06:11 AM
Use something that you cut a new edge on & then burnish the edges down well. I cut new edges with a straight edge & a hobby knife with a new blade on a piece of glass. Factory tape edges depend more on how you keep the tape stored than what you actually purchase. I keep my rolls store in individual plastic bags until I use them. I also cut vinyl shelf paper on glass, but you asked about tape. If you were only spraying acrylics, I would recommend "Frog tape", if you could find it. It has a "paint-block" in the adhesive that's activated by moisture in latex & acrylic paints.
Paper tapes that have given me good results are 3M tan tapes in various widths & the yellow Tamiya.
  • Dave_12 likes this
#3 Pablo
  • 18,495 posts
Posted 19 August 2024 - 06:45 AM
Yellow Tamiya, me too.
  • Wizard Of Iz and Tim Neja like this
#4 Mike Patterson
  • 2,601 posts
Posted 19 August 2024 - 09:26 AM
I've used Scotch #471 plastic tape for years. I bought it at an automotive paint store.
#5 Tim Neja
  • 6,848 posts
Posted 19 August 2024 - 10:50 AM
I use the Tamiya tape also.  Get it at the local hobby shop. Works great.
  • Wizard Of Iz and Dave_12 like this
#6 Wizard Of Iz
Wizard Of Iz
    Slot Parrothead
  • 1,900 posts
Posted 19 August 2024 - 07:42 PM
Yes!  It's easily the best tape I've ever used.
Rollin Isbell
#7 Dave_12
Dave_12
  • 139 posts
Posted 19 August 2024 - 07:44 PM
Thankyou everyone i an going to get the Tamiya  masking tap.  I don't want this happening again .
I found that when using Fastkolor paint standard masking tape works just fine but when using Tamiya paint this is what happens
David Rees
#8 Wizard Of Iz
Wizard Of Iz
    Slot Parrothead
  • 1,900 posts
Posted 20 August 2024 - 04:40 PM
That's so much bleed-through that it almost looks like you were going for a "cat scratch" look.
Rollin Isbell
#9 Bill from NH
  • 14,994 posts
Posted 20 August 2024 - 04:50 PM
Looks to me like you have to improve your burnishing skills. The wooden cuticle sticks found in the nail polish departments of stores make a great burnishing tool. A cut dowel works too.
#10 Mad Mark
Mad Mark
  • 869 posts
Posted 20 August 2024 - 07:32 PM
Yeah really need to take something like a fingernail and really stick the edge of tape down. also double check before painting as it will lift up as your masking other areas.
Mark Haas
#11 Dave_12
Dave_12
  • 139 posts
Posted 21 August 2024 - 04:36 AM
I prefer the Faskolor paint but it is becoming increasing hard to find .  Is Faskolor paint still made .  ?????
David Rees
#12 Wizard Of Iz
Wizard Of Iz
    Slot Parrothead
  • 1,900 posts
Posted 21 August 2024 - 06:13 AM
I believe that Roger Schmitt has resumed offering Faskolor paints through his relaunch of Parma.
I'm pretty sure that Faskolor is re-badged Createx Airbrush Colors.  There's usually a decent selection at Hobby Lobby.  For even more colors, check out Blickart.com. Good prices, too.
Rollin Isbell
#13 Bill from NH
  • 14,994 posts
Posted 21 August 2024 - 07:04 AM
Faskolor is made by Createx in CT. Most colors are available under both labels. In the past, some of the solid colors of Faskolor seemed to have slightly more pigment than the same color labeled Createx. Many acrylic craft paints can be airbrushed too when properly thinned. Delta Ceramcoat & Liquitex are two that stick to lexan like a gorilla when dry. Polly S was another.
