Are you using any thing to soften it?
Trinity sells a product, Sticky Fingers, which is normally used to soften tires. It should help.
People use a router to clean old glue off all the time. You use the same bit you use to cut the recess.
On a flat track, it's fairly easy to a good job.
On a banked track where the track isn't flat, you need a small router base and someone who really knows what he is doing.
I've seen tracks butchered by guys who supposedly did know what they were doing and obviously didn't.
I personally thinks it's better to gut it out removing it without a router. At least you'll save the time of repainting the recess.
You definitely don't want to glue to bare MDF.
