Mid-America controller parts
7 replies to this topic
#1 crazyphysicsteacher
crazyphysicsteacher
  • 369 posts
Posted 21 September 2024 - 08:28 PM
Alright folks, the Mid-America controller has been out for awhile now and a buddy of mine has broken his. Seems that he needs a brake pot. I have tried matching the numbers on the back of the pot but have no luck. My only info seems to be that it is a 1k pot.
So before I try emailing Roger to get info, does anyone have a line on replacement parts?
Chris Wendel
Silver Side Down Racing
Silver Side Down Graphics
#2 Dave_12
Dave_12
  • 117 posts
Posted 21 September 2024 - 08:51 PM
Measure the resistance of the old brake pot with a multimeter then you will know what resistance rheostat you need.
For most controllers, either the Difalco DD807 3 ohms or the DD836 5 ohms does the job.
have you cleaned the brake contacts? Dirty contacts often causes problems.
David Rees
#3 Tim Neja
  • 6,846 posts
Posted 21 September 2024 - 09:20 PM
Why not check with Roger?    :shok:
  • glueside likes this
#4 crazyphysicsteacher
crazyphysicsteacher
  • 369 posts
Posted 21 September 2024 - 10:20 PM
It is Saturday night and if someone had a lead I might buy a bunch to keep in personal stock.
Chris Wendel
#5 Bill Seitz
  • 598 posts
Posted 23 September 2024 - 06:12 PM
The low value pots, typically around 5 ohms, that David mentions are for the pure resistive brake circuit that Difalco and some others have used. Some of the newer digital controllers like the M-A and Third Eye use some sort of electronic brake circuit, and 1K would be more likely. As David mentioned, if you have an ohmmeter, measure it. However, if you're familiar with one of the electronics distributors, you know there's quite a selection in 1K pots which will take some effort to select. As has been already suggested, try M-A and see if they have a replacement or can suggest one.
  • SpeedyNH likes this
#6 SpeedyNH
SpeedyNH
    Old Engineer
  • 769 posts
Posted 24 September 2024 - 07:12 AM
if you can read it, sometimes you can tell from the part no. (e.g. 102 = 1k) or google it if it's just a mfr's. p/n with no relation to value.  if part of it's fried, you can usually make a pretty good guess by turning it up halfway and reading the side that's sill good.
Steve Lang
#7 crazyphysicsteacher
crazyphysicsteacher
  • 369 posts
Posted 24 September 2024 - 08:47 AM
In the process as we speak.
Chris Wendel
#8 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 2,628 posts
Posted 24 September 2024 - 12:16 PM
Note that the MidAm pots are much smaller than DiFalco's and likely a different value as well, thus  they are not interchangeable,
Cheers
Faster then, wiser now.
