Do brushless motor bearings need oil?
Posted 29 September 2024 - 07:59 AM
Posted 29 September 2024 - 10:46 AM
- Dave_12 likes this
Posted 29 September 2024 - 11:53 AM
This YouTuber has a video "Does an RC Brushless Motor require Lubrication or Oiling?"
Hope it helps.
Posted 30 September 2024 - 12:47 PM
Shielded bearings aren't sealed, and even "sealed" bearings will usually take a light oil. Shielded bearings will keep large grunge out, but they can still get fine particles in them. Whether one lubricates them or not depends on how long you'd like the bearing to last. My preferred lubricant for any small bearings is synthetic ATF. In addition to lubricating, the oil can also help wash out any fine particles that get passed the shields.
In some applications, the user just lets the motor go until it fails for whatever reason including failed bearings, then replaces it. In competition, motors are probably replaced well before the bearings seize.
- dalek and Dave_12 like this
Posted 30 September 2024 - 02:24 PM
The guy on the video pretty much lost me when he referred to WD40 as oil.
I like and use WD40 but if I am going to oil something I do not grab WD.
I am not doing brushless yet, but if it has bearings or bushings, I am probably going to put a little oil on it from time to time.
- dalek, Samiam and Hot Slots like this
Posted 02 October 2024 - 01:34 PM
On topic, if you attempt to oil bearings on the KC Racing BLDCs you are asking for issues. The bearings are GREASE filled.
Regarding WD-40, this product is made as a rust remover and to displace water. WD = Water Displacement, it took 40 iterations for it to be perfected thus the 40. Used to remove grease; a bath of WD-40 in a brushless motor will only shorten the bearing life by removing the grease. The product has no lasting lubricating properties.
More on topic of WD40 in bearings - https://www.machiner...aring-lubricant
- team burrito, Tim Neja and dalek like this
Pioneering Brushless Technology for Slot Cars
