MAC McLaren M20 body slot car
8 replies to this topic
#1 Slot Car Rod
Slot Car Rod
  • 783 posts
Posted 07 October 2024 - 01:18 PM
I rebuilt/reassembled my MAC McLaren M20 slot car that I originally built in 1974.  The car was only run a couple of times back in 1974.  Soon after, the local raceway (Oakland Speedway) moved to another city.  Also, the relocated raceway only lasted a few months.
The car originally had smaller diameter Aguirre brand tires (13/16" rears and 5/8" fronts).  I rebuilt the car with Associated 7/8" rears and 3/4" fronts for a better look. The new rear tires are Mid-America brand soft compound tires.
I sanded the rust off of the Mura C-can and re-painted it black.  Another motor end-bell replaced the acid-eaten one.  The long Mura magnets were reused along with the Mura machine-wound armature (probably 25 single wind).
The chassis main rails were sanded down a little to increase chassis flex and decrease understeer.  The axle tubes were adjusted for the larger tires.  A brass pinion and Cox spur gear replaced the worn Faas gears.
The MAC body was painted back in 1974 with acrylic paints.  The wraparound rear spoiler is made of .010 Lexan sheet.  The driver/interior is a modern replacement.  I always thought this slot car body had very little resemblance to a real McLaren M20.
The car is nice to drive and power from the Mura motor is good.  As Eric pointed out, these cars were designed to be run with lots of track glue and orange rear tires.  The new soft black tires help the car handle modern spray glue tracks.
I will add a motor brace after the new gears are run in.
I found this LASCM picture of a clear MAC-V09 McLaren Mk20 body.
  • dc-65x, Jencar17, vfr750 and 3 others like this
Rodney Chew
#2 MG Brown
  • 8,001 posts
Posted 07 October 2024 - 02:07 PM
It's not THAT far off other than the AWOL rear wing:
I re-livered this 1/32 Carrera M20 a few years back in rememberance of Peter Revson's birthday.
A former neighbor had an M20 until he needed the garage space.
  • Jencar17 likes this
#3 Slot Car Rod
Slot Car Rod
  • 783 posts
Posted 07 October 2024 - 02:28 PM
Built this one years ago.
  • Pablo, Jencar17, Tex and 2 others like this
Rodney Chew
#4 dc-65x
  • 7,075 posts
Posted 07 October 2024 - 04:24 PM
Nice looking cars Rodney. It's great you've hung on to your cars from back in the day and can bring them back to life to "see them move" again.   :good:
  • Slot Car Rod and Paul Menkens like this
#5 spudboy
spudboy
  • 903 posts
Posted 07 October 2024 - 06:27 PM
I think it more closely resembles a McLaren M8...F?
Very nice none the less.
Nate "spudboy" Bemis
#6 Dave Crevie
  • 4,877 posts
Posted 08 October 2024 - 08:14 AM
"I think it more closely resembles a McLaren M8...F?
Very nice none the less."
I was thinking the same thing. The M20 has side inlets for the radiators, the M8 has NACA inlets. But the M8F also has step at side pods. Regardless, it's a cool car. Can't go wrong with Can-Am as far as I'm concerned.
Others to consider;
M8B. No big wing;
M8D. Big wing, but no full length fences. Also, NACA inlets on top;
  • Tex likes this
#7 Slot Car Rod
Slot Car Rod
  • 783 posts
Posted 08 October 2024 - 12:00 PM
More McLarens.
  • Jencar17 and Tex like this
Rodney Chew
#8 Dave Crevie
  • 4,877 posts
Posted 08 October 2024 - 01:42 PM
Excellent.
#9 wizardgm
wizardgm
  • 8 posts
Posted 08 October 2024 - 05:19 PM
You cant have enough McLarens....
Dennis Miller
