Sidewinder Gears
26 replies to this topic
#1 havlicek
Posted 10 October 2008 - 10:19 AM
I'm looking at doing a full-sidewinder and one of the problems here is coming up with gears large enough at an over 4:1 ratio to cover the distance between a modern C-can shaft and the rear axle. Of course, the spur gear diameter will also affect the size of the rear tires. So:
1) What's the deal with so-called "drag spurs"? Are these simply larger spur gears that are as durable as any other by the same manufacturer? I see tooth counts that go way up there on these.
2) Is there a resource online somewhere that gives approximate diameters of spur gears so I can figure out what size rear tire would be necessary to keep the spur gear clearance? Having to go to a huge rear tire is also going to mean even higher gear ratios.
Thanks in advance.
#2 Don Weaver
Don Weaver
  • 1,855 posts
Posted 10 October 2008 - 10:27 AM
John,
I have a bunch of the old Weldon (?) sidewinder gears with taper-locks from the '60s... if you can put me in the ballpark on ratio and diameter I'll see what I have.
Don Weaver
Don Weaver
L.H. Lapham
it will starve to death...
#3 Prof. Fate
Prof. Fate
  • 6,580 posts
Posted 10 October 2008 - 10:59 AM
Hi,
John, no reason for a full sidewinder in the first place.
In the second place, you can do the sums yourself.
48 pitch gears mean 48 teeth on a 1" gear. 64 means 64 teeth, 72...
You get the idea.
Fate
Rocky Russo
3/6/48-1/1/12
#4 JohnnySlotcar
JohnnySlotcar
  • 2,036 posts
Posted 10 October 2008 - 11:00 AM
I have a bunch of Fass and Sonic 41-44 tooth 64 pitch gears that should work.
Email me at bigpedo@aol.com if interested.
John Austin
#5 havlicek
Posted 10 October 2008 - 12:22 PM
Thanks, Don and John. I may just take you guys up on your generous offers!
Hi Rocky,
But I don't get your answer!? Of course there's a "reason" to do a sidewinder. Aside from the mechanical advantage, it's an "old form" that's not often done anymore. There's no "reason" to do jail-door inlines either... or for that matter floppy-pan inlines :)
Ah... I thought those designations were the number of teeth per inch on a straight line (so a 48 pitch gear would have teeth 1/48 of an inch) and didn't realize they meant the number of teeth on a 1" diameter gear!
#6 Jairus
  • 10,174 posts
Posted 10 October 2008 - 01:00 PM
I didn't either... that is a good piece of trivia to know! B)
#7 havlicek
Posted 10 October 2008 - 01:13 PM
Weird, I have a 39 tooth 64 pitch gear that measures .625". If a 64 pitch gear with 64 teeth = 1" diameter, then 39/64 of an inch should be .609".
Oh well... I guess it's close enough for rock and roll!?
#8 Cheater
  • 25,658 posts
Posted 10 October 2008 - 01:20 PM
John,
Google on "pitch diameter" and see what you find.
IIRC the pitch diameter and the overall diameter differ.
#9 Noose
Noose
  • 23,278 posts
Posted 10 October 2008 - 01:37 PM
Here ya go:
Explanation Of Gear Pitch
#10 Tex
  • 9,243 posts
Posted 10 October 2008 - 01:48 PM
Mongo no read. Teeth-per-inch good enough for Mongo. Mongo sleep now.
#11 team burrito
team burrito
  • 2,197 posts
Posted 10 October 2008 - 02:09 PM
Go here instead:
PIC Design
In general, 46t is .750" OD, 48t is .781" OD, and 50t is .813" OD. It doesn't show a 52t gear, so your guess is as good as mine. Hope this helps.
Russ Toy (not Troy)
#12 idare2bdul
idare2bdul
  • 5,799 posts
Posted 10 October 2008 - 02:23 PM
Companies that make gears often make more then one tooth count gear on the same size blank. There is an optimum size and then there is the "how many teeth can we get on this little sucker" size. Mostly this is done for clearance reasons but it also cuts down on inventory for blanks.
Drag gears are often aluminum and don't like too much horsepower for applications other than drag racing. An FK or stock 16D is usually OK. Above that level gear life can be short.
Mike Boemker
#13 Foamy
Foamy
  • 1,583 posts
Posted 10 October 2008 - 04:31 PM
Hi,
You get the idea.
Fate
Ummmm, no. Not so much. In 64 pitch, a 1"diameter is going to be 62 teeth.
Quickie formula to find teeth/diameter is. . .
1 divided by tooth pitch, multiply by number of teeth plus 2.
46 example. . .1divided by 64=0.015625". Multiply by 48=.750".
Mike is correct about compressing/expanding teeth to fit a specific diameter. Functions ok a couple teeth on either side of optimum.
Drag gears are good on low HP motors as they are only .040"-ish wide aliminum. For Vintage style big HP rewinds I would try to find Welduns or else use Cox gears.
Dennis Hill
#14 havlicek
Posted 10 October 2008 - 04:46 PM
Thanks for all the replies!
Foamy, that makes sense and I'll look into those. Noose's link explained the difference I saw as they measure the pitch diameter about half-way out the length of the tooth.
#15 Horsepower
Horsepower
    **Numb Thumbs**
  • 4,343 posts
Posted 10 October 2008 - 05:16 PM
Hey John! If you need sidewinder gears I have 'em up to the keister so feel free to ask! :D
Gary Stelter
#16 Horsepower
Horsepower
    **Numb Thumbs**
  • 4,343 posts
Posted 10 October 2008 - 05:17 PM
I think I'm gonna shoot him!
Gary Stelter
#17 rdmac
rdmac
  • 645 posts
Posted 10 October 2008 - 06:50 PM
Hi John
In a nutshell, Outside Diameter = (Number of teeth +2) / Pitch
Example: Find the OD for a 37 tooth 48 pitch gear...
(37+2) / 48 = 39/48 = .8125
Example: Find the OD for a 69 tooth 64 pitch gear...
(69+2) / 64 = 71/64 = 1.109375
Example: Find the OD for a 52 tooth 72 pitch gear...
(52+2) / 72 = 54/72 = .750
More Info Here... Spur Gear Terms & Calculations
Stock Drive Products
On the above link click > Gears > Spur Gears > Metal
2024 Aluminum
48, 64, 72, 80 Pitch
With Hub / Set Screw
Face Width = .125
Bore Size = .125
At approx $13 each they are a little pricey, but available.
Also Here... W.M. Berg
Bob McCurdy
3/2/54-10/22/12
#18 Tex
  • 9,243 posts
Posted 10 October 2008 - 10:03 PM
That's why Mongo no read.
Mongo look at clouds.
Better.
#19 Bill from NH
  • 14,733 posts
Posted 11 October 2008 - 10:21 AM
Bob, would this be Walter Berg, the long-time International 15 racer? :)
#20 Horsepower
Horsepower
    **Numb Thumbs**
  • 4,343 posts
Posted 11 October 2008 - 04:33 PM
Better.
Wouldn't want to shoot Mongo. It would just make him mad... :blink: :rolleyes: :laugh2:
Gary Stelter
#21 'Slots of Fun'
'Slots of Fun'
  • 794 posts
Posted 11 October 2008 - 08:39 PM
Revran! :laugh2:
V/R,
Don Berni
#22 havlicek
Posted 12 October 2008 - 06:54 AM
Thanks again, everyone, for all the information. The above is a nice simple formula (me mongo, too) I can easily use. Thanks, Bob :shok:
#23 stevefzr
stevefzr
  • 598 posts
Posted 12 October 2008 - 09:34 PM
Hi John
So, can I use this to sort out my 48 pitch and 50 pitch (metric) pinions? It's easy to pick the metric crown and spur gears as they have a 3mm axle hole instead of 1/8", but the pinions are all designed for the same armature shafts. I could never see what the teeth on a pinion all had to be the same length, so I didn't think I could just measure the diameter to sort the metric from the imperial.
Anyway, if your formula still holds for pinions, then a 10t 48 pinion would have an outside diameter of:
(10+2)/48 = 1/4" = .25"
and the metric (approx 50p) would be (10+2)/50 = .24"
I was just last night thinking I needed an 11t metric pinion for a Tamiya. Can I use this formula to find one?
Regards,
Steve C
Stephen Corneille
#24 rdmac
rdmac
  • 645 posts
Posted 13 October 2008 - 01:16 PM
WARNING - WARNING - WARNING
Mongo + Metric = Cranium Cavity Explosion ( Head Go Boom-Boom )
Mongo Watch Whirlie Thingie, Mongo Go Sleep...
Mongo See More Whirlie Thingie Here...
Bathsheba Sculpture
Do Not Pass Go, Do Not Collect $200
WARNING --- Mongo No Read Next Post --- WARNING
Bob McCurdy
3/2/54-10/22/12
#25 rdmac
rdmac
  • 645 posts
Posted 13 October 2008 - 01:17 PM
...Anyway, if your formula still holds for pinions, then a 10t 48 pinion would have an outside diameter of:
Hi Steve
Quick Answer... Yes the same formula will work.
I am assuming that the "approx 50 pitch" gears are actually a 0.5 millimeter "module" gear. (see attached picture for description of metric "module")
A 0.5 millimeter "module" gear would have an equivalent "pitch" of 50.8 teeth per inch ( 25.4 / 0.5 = 50.8 )
Therefore using your example for a 10 tooth pinion: (10+2) / 50.8 = 12 / 50.8 = .2362 inches
If you know the gears module you can use the formula in the pic marked in Red.
D = (N+2) x M
D = (10+2) X 0.5
D = 12 X 0.5
D = 6 mm = 6 / 25.4 = .2362 inches
Hope this helps...
Bob McCurdy
3/2/54-10/22/12
