Slick/slimey tires after 2-3 heats
18 replies to this topic
#1 studentdriver
studentdriver
  • 99 posts
Posted 12 January 2025 - 08:22 PM
I'll try to sum up everything I'm aware of to start
1) fish or soft wonder, doesn't seem to matter, same thing happens
2) usually a prepped track where it was cleaned and fresh glue put down
3) around .650 to .660 outside diameter with like .400 to .470 hubs
4) tires are assembled by me (various different donuts and plastic/carbon rims).
5) I do use trinity tire tweek. I apply and let sit depending on how soft I want them and then wipe it off. I will occasionally re-apply to clean but not during the race at any point
I clean the tires to start and they usually feel fairly grippy.. they are flat and trimmed up nicely. I use 3m spray adhesive (the 80 for rubber a foam).. I spray into a small lid and then apply with plastic stick to the hubs and tires. Trim them with hudy.. everything seems fine. Then when I race after anywhere from like 30 to 60 laps the tires themselves (not the track) seems to be VERY slick.. almost like a very fine gel or slime coating on them. Makes the car very loose even with fish tires..
I have a few questions
1) What is happening in this specific situation? I've asked a few seasoned folks and they are aware of it happening but no one can tell me why. Is the glue getting too hot on the tires or something? No one seems to have the answer. It's freaking glue so how can it become worse than the actual glue?? Very weird, hoping to understand what's going on
2) I've been told to clean the tires, maybe with something like lighter fluid or something similar. I rather avoid this as I'm already usually running behind between heats LOL... and dang it I'm not getting any younger. I have been able to clean the tires but I'm worried that after like 6 heats they get worse faster? Maybe if I understood what was happening I could try to avoid versus cleaning.
Anyways, this is a weird one that's driving me nuts (pun intended).
thanks,
Mike
Mike Ciccarelli
- Enjoy tinkering
- Like going fast!
#2 MSwiss
  • 26,012 posts
Posted 12 January 2025 - 09:04 PM
Try not using the Tire Tweek.
  • nicky 65, Danny Zona and Eddie Fleming like this
#3 glueside
glueside
  • 434 posts
Posted 13 January 2025 - 07:00 AM
Just like Swiss says - STOP using Tire Tweek.
Jeff Strause
#4 studentdriver
studentdriver
  • 99 posts
Posted 13 January 2025 - 10:12 AM
Sure thanks... tire tweek is handy to soften tires a bit (say for soft wonder).. get something down to like 30 or 35 on o scale durometer. I guess I could potentially only use it to soften and then use lighter fluid to clean them to get rid of the tweek?
thanks,
Mike
Mike Ciccarelli
- Enjoy tinkering
- Like going fast!
#5 MSwiss
  • 26,012 posts
Posted 13 January 2025 - 11:09 AM
Sounds like you can't stop tweeking.
  • Danny Zona and studentdriver like this
#6 Eddie Fleming
  • 2,981 posts
Posted 13 January 2025 - 11:13 AM
Once you put Tire Tweek on tires you can never say I got it all out of the rubber.
Try just two sets of tires with no tweek at all, To see if the problem goes away.
If you have the problem with the tires you glue up and not with bought tires that would point to the rubber or the procedures you are using.
  • JerseyJohn and studentdriver like this
#7 studentdriver
studentdriver
  • 99 posts
Posted 13 January 2025 - 11:34 AM
LOL, this did make me chuckle... thanks :)
So I can explain why I like to tweek... the 1 track I go to typically only reglues before a major event (maybe once every other month or longer). The tweek seems to "bring the glue back to life" that's already on the track. 3-5 laps and i'm like .5 faster.. I could try glue on tires instead but then the old glue on track + new glue on tires = not the best :( I'm open to suggestions here. Track reglue is kind of out of my hands.
Mike
Mike Ciccarelli
- Enjoy tinkering
- Like going fast!
#8 MSwiss
  • 26,012 posts
Posted 13 January 2025 - 11:43 AM
Is the issue only happening to you?
#9 studentdriver
studentdriver
  • 99 posts
Posted 13 January 2025 - 11:48 AM
Sure, not a bad idea! and I can test this.
My overall concern I guess is I need to find tires (specifically donuts) that work for me and I'm kind of out of options. The main options are Mid America and JK as far as I know. Mid America has limited options for donuts :( I would need to buy the tires already assembled. They only offer the .450 Internal diameter for soft wonder donuts :( This is NOT a beef with any 1 company or anything like that at all... just saying that donut options are very, very limited.. A lot of tires seemed to be geared towards
1) 1/8 axle based sizes, > .800
2) retro type racing where minimal tire size is like > .800
this leaves LMP or GTP type classes which usually like running smaller sized tires to be limited (hub size around .400, give or take) unless you want to only run fish.
Mike
Mike Ciccarelli
- Enjoy tinkering
- Like going fast!
#10 studentdriver
studentdriver
  • 99 posts
Posted 13 January 2025 - 12:20 PM
Most folks are running fish and do not need to soften or treat. Potentially I need to tweek a lot less (or try to find a solution to replace it completely) when the track is not prepped for testing. That said the dude who always wins runs wonder that have been softened via tweek...
1) run fish and hope you have enough straight line speed because the tires are soft
2) run some sort of soft wonder and try to maybe treat only a bit (1 time only to soften)... options are limited for donuts
3) run treated which my options for donuts is pretty much JK only as far as I know..  options are limited for donuts
So yes, I need to kick my tweeker habits I guess but alternatives are very limited.
thanks,
Mike
Mike Ciccarelli
- Enjoy tinkering
- Like going fast!
#11 Jay Guard
  • 2,937 posts
Posted 13 January 2025 - 03:14 PM
If you are talking about testing on a track that hasn't been glued in a while it sounds like the track may just be dusty (often you won't actually see this but it's there) or a bit dry.   I would use lighter fluid to clean the tires, do an in-place "burn-out", wipe the excess off the track, and run a few cautious laps, then repeat as many times as necessary until the traction comes up.  Unless the track is really dirty, or has super old rubber, clean fresh fish rubber tires should hook up at least fairly well after multiple cleanings.
One other tire "hack" is to rub a very small amount of suntan lotion, yep suntan lotion, into your tires, wait just a few minutes, then wipe off and run laps.  This really does work because the glycerin in the lotion will soften almost any tire.  Also it doesn't seem to leave the tires with a hardened surface (after a few days) like I've found Tire Tweak to do.  I've seen world class racers do this to quickly break in their tires.
If just nothing works and you're really desperate try this.  I knew a guy that made a weak glue & lighter fluid mixture and soaked his tires overnight in it and  then cleaned them before getting on the track.  I honestly don't know if this really worked but he swore it did, I never tried it so can't say for sure.
BTW... To get the best straight line speed you generally want to use the hardest tire that grips up and doesn't spin under acceleration.
Hope this helps!
  • Steve Deiters and JerseyJohn like this
#12 Kim Lander
Kim Lander
  • 606 posts
Posted 13 January 2025 - 06:29 PM
The tire tweek will loosen the glue you use to seat the rubber....if you must use the tweek let tires sit at least over night....try it and see.
#13 studentdriver
studentdriver
  • 99 posts
Posted 14 January 2025 - 11:23 AM
Yes, this is a valid point.
I think the overall issue might be that yes, I was abusing the tweek a bit... I was adding it to help bring back the track glue AND I was using it to just clean the tires... I didn't think putting on to clean tires was causing an issue but I think it was... I will be switching to lint roller to clean with occasional maybe lighter fluid clean (tho I'm worried that it might break the glue down as well if used too often).
Long story short is, I'm going to leave the tweek at home. I might still attempt to use it just on wonder based tires only BUT only at home to soften slightly.
The big issue is I can't find wonder donuts with smaller inside diameter... this leads me to run 470 hub when I'd prefer 400 or 440.
Mike
Mike Ciccarelli
- Enjoy tinkering
- Like going fast!
#14 Mike Patterson
  • 2,600 posts
Posted 15 January 2025 - 10:33 AM
Don't worry, ain't gonna happen. I cleaned tires w/lighter fluid my whole career, and no issues.
#15 studentdriver
studentdriver
  • 99 posts
Posted 28 January 2025 - 10:43 AM
I went this past weekend, tweekless to practice and I ended up trying all different things like
1) multiple applications of lighter fluid on tires
2) resorting to applying some glue to tires (not track)
3) trying different tires
Ultimately once I added a bit of glue that seemed to help a little but couldn't get the traction and quicker results like I could with tweek. The tweek would seem to bring the existing glue back to life that was on the track.
Not sure what else to try and I'm open to suggestions. One might ask why bother? I want to be able to test things and have the conditions/speeds as close to as when the track is prepped without it being prepped... I don't like to make guesses at what might work.
thanks,
Mike
Mike Ciccarelli
- Enjoy tinkering
- Like going fast!
#16 Eddie Fleming
  • 2,981 posts
Posted 28 January 2025 - 03:06 PM
I knew a racer a few years ago that cleaned his tires with alcohol between heats. I tried it and it did seem to have a grippy effect.
I don't Know what or why but it did seem to have an effect on that track at that time.
  • studentdriver likes this
#17 studentdriver
studentdriver
  • 99 posts
Posted 28 January 2025 - 03:09 PM
I can give it a shot! Ultimately the issue is not with my tires... I was able to treat my tires to bring the glue on track back.. I don't know if there is an alternative but I can definitely try rubbing alcohol.
thanks,
Mike
Mike Ciccarelli
- Enjoy tinkering
- Like going fast!
#18 Jay Guard
  • 2,937 posts
Posted 28 January 2025 - 05:48 PM
Here is a long shot idea...  Maybe some (or many) others are using Kelly Bulldog tires.  It has been some racers experience that Bulldog tires tend to leave some kind of film (possibly silicone related) on the track which then makes virtually any other type of tire very loose.  I guess it might be possible that your newly cut  (or freshly tweaked) tires work for a few heats until they get a film on them and then they stop working.  This is just a WAG so take it for what it's worth, less than $0.02 for sure.
Here's another thought... Are you oiling, or maybe over oiling your car every heat?  I'm sure you've seen the oil spray that gets on the bottom of your car body, well an equal amount is getting on the track and thus on your tires which will of course make them very loose.  I don't mean to be Captain Obvious here but I see way too many racers over oiling their cars.  Hardly necessary with ball bearings and with Slick 7 type bronze bushings use a slightly thicker oil and as little as possible.
  • John Luongo likes this
#19 Mike Patterson
  • 2,600 posts
Posted 29 January 2025 - 10:53 AM
Here's a thought: When your car gets all slippy and slidey, let a fellow racer (preferably one of the fast guys) drive it. See if he agrees with your assessment. Or, just run fish rubber. You stated that's what the majority uses, and there's probably a good reason for that, i.e. they work.
I guess it boils down to: do you want to be competitive if/when you race, or do you just want to tinker? If it's the latter, carry on!
