Vertical vs. horizontal brushes
Posted 12 February 2025 - 07:53 PM
Posted 13 February 2025 - 10:33 AM
Yes.
Posted 13 February 2025 - 12:19 PM
If I understand it correctly, the standard brush is not square, so the horizontal brush gives a wider, less arc contact point with the comm, whereas the vertical brush contact point is narrower but touches a larger arc on the comm. Does it make a difference? More precise timing, maybe?
Posted 13 February 2025 - 12:25 PM
No it is the other way around Chris The illustration is backwards.
- MSwiss likes this
Posted 13 February 2025 - 01:42 PM
Posted 13 February 2025 - 02:07 PM
I lifted this illustration from another thread discussing brush orientation. They talk about how the brushes can short across the comm segments. The drawing is not easy to decipher, so I re-drew some of it to make it more understandable. What is important here is to know that the comm is a large enough diameter that the brush can't create a direct short by bridging the undercuts and creating an electrical path through the comm segment. In the view on the right, the power has to travel through the windings on the poles. It can't bypass them.
- John Luongo likes this
Posted 13 February 2025 - 03:11 PM
Posted 13 February 2025 - 03:14 PM
I know I have dyslexia but, what part did I get basakwards?
Taller ones, height wise, are horizontal and what would be in old school Mura motors.
Vertical, also occasionally referred to as laydown, were first marketed by Koford in the early 80's.
Not reading what Dave posted, with less wrap around, you have less of a chance of a high time motor needing a pushstart.
After much resistance from non-Koford racers, they eventually became the standard for G7 motors as the comm will run cooler with them.
Posted 13 February 2025 - 03:39 PM
Posted 13 March 2025 - 11:31 PM
Having found the box of Koford brushes that initiated my inquiry, I'll continue with some photos and comparisons to the size of the brushes later today. I've done this before with excellent results so I'd like you to review it and comment.
Posted 14 March 2025 - 07:12 AM
we used to just take bigfoots, turn em around and recut the curved end and make a new spring/shunt slot. i had a couple different dia. brush hones and a dedicated endbell & can to hone the end of the brushes.
Steve Lang
Posted 14 March 2025 - 09:25 AM
