Building a single transistor controller
10 replies to this topic
#1 Tmas
Tmas
  • 8 posts
Posted 06 April 2025 - 09:26 AM
I found an old article about building a controller & would like to do so. I have verry basic knowledge of circuits. I have a few questions about this one.
https://www.e-slotca...tcontroller.pdf
1. In the parts list it lists two miniature resistors 2R & 3R3 what are the values of these resistors?  (Funny the wiring diagram shows different R22 & R3 not sure what happened there.)
2.  In the parts list it also lists a miniature resistor 30R, but it does not show it in the wiring diagram??
3. What motors will this controller handle all up to group 27 & 7
I will be using the Parma 35 ohm. resistor any help would be apparated.
  • Rob Voska likes this
Tom Mascialino
#2 Johnny
Johnny
  • 262 posts
Posted 06 April 2025 - 11:07 AM
The value is in the description, 2R is 2 ohm, and 3R3 is 3.3 ohm.
There is updated description on this Controller. Contact Andy at ABSlotsport. https://abslotsport.biz
and tell him I sent You.
There is no 2R or 3R3 on the new chematic, but a 3 ohm that is connected to one of the pins on the Transistor..
the 3.3 ohm might be for protection of the fan if not using a fan board.
We are using this Controller for ISRA P24 (box12 motors), G27 and G7 I don't know, You might ask Andy about that.
I'm not any good at electronics either, but has build a couple of these that work nicely.
Best Regards,
Johnny Andersen
Oslo - Norway
Asker Mini Racing Club
#3 Tmas
Tmas
  • 8 posts
Posted 06 April 2025 - 01:41 PM
I have but but he didn't answer all my questions leaving me more confused. Would you have the up dated info?
Tom Mascialino
#4 Johnny
Johnny
  • 262 posts
Posted 06 April 2025 - 02:14 PM
I do, but I have to sort them out. They are PDF's
These are only pictures but easy to follow to build a controller.
I also have the old schematics where You can see the resistor used for the Fan.
I will contact You trough the message board to get emails etc
Best Regards,
Johnny Andersen
Oslo - Norway
#5 Tmas
Tmas
  • 8 posts
Posted 06 April 2025 - 03:02 PM
Ok
Tom Mascialino
#6 Bill Seitz
  • 627 posts
Posted 06 April 2025 - 05:18 PM
This controller article shows using a MJ14003 PNP transistor which is obsolete and no longer manufactured. This transistor, if you can find one, is 60 amp and capable of powering anything through open motors. A still actively available 2N5684 50-amp PNP transistor would be a suitable direct replacement also capable of powering anything through open motors.
#7 Johnny
Johnny
  • 262 posts
Posted 06 April 2025 - 05:37 PM
In the latest revised instructions the Transistor is changed to a 2N5684.
(Sorry Bill, I didn't read all of Your reply)
Best Regards,
Johnny Andersen
Oslo - Norway
#8 Tmas
Tmas
  • 8 posts
Posted 06 April 2025 - 06:03 PM
Thank you Bill I actually have located one. 👍
Tom Mascialino
#9 Rob Voska
Rob Voska
  • 1,133 posts
Posted 07 April 2025 - 05:19 AM
I ran one for years.  I used a 45 ohm because I liked it better.  Spend some time making sure the resistor you use is flat / smooth.  I ended up using JB weld and sanding it smooth.  (not easy)
Also info here but slightly different.
https://www.slotcarr...ntrol/index.htm
It's a fun project.  By the end you will either be :crazy: or have a better understanding of the basic controller :victory: .
#10 Tmas
Tmas
  • 8 posts
Posted 07 April 2025 - 10:16 AM
Thanks Rob some good information!
Tom Mascialino
#11 Rob Voska
Rob Voska
  • 1,133 posts
Posted 07 April 2025 - 04:36 PM
Also the first one I built I sourced everything through Andy at AB Slotsport.  Second I built and made my own box like a carsteen.
