My normal hudy tire truer was in need of some help, it seems the bearings on the drum were worn out.
Yesterday, I was able to remove them. They appeared to be glued in. Not knowing what kind of glue was used, I used a little acetone, and that seemed to work enough to get them loose.
So my question is this - when you replace the bearings, are they SUPPOSED to be glued in, or are they just a snug snap fit?
If they ARE supposed to be glued in, what is the correct glue to use?
I had figured to use loctite CA glue, but would like some suggestions if anyone has experience with this.
Thanks!!
