Power supply problems
12 replies to this topic
#1 Mr. BB
Mr. BB
  • 61 posts
Posted 04 April 2009 - 01:42 PM
I have a Koford power supply that when you plug it in with the switch off it has full power. I have changed out the voltage regulator and nothing changed. Any suggestions?
John Batson
#2 Gary Mayeda
Gary Mayeda
  • 77 posts
Posted 04 April 2009 - 05:07 PM
Send your power supply back to Koford and they should fix it for you.
Gary
3/17/53-4/21/16
#3 Dooner
Dooner
  • 655 posts
Posted 04 April 2009 - 07:16 PM
Could be a bad Single Pole/Single Throw switch. If you replace it you may void the warranty.
Tom Backes
#4 Mac
Mac
  • 256 posts
Posted 04 April 2009 - 11:27 PM
Buy a new WrightWay??
Eddy "Mac" MacDonald
Sprays By Mac
#5 Mr. BB
Mr. BB
  • 61 posts
Posted 05 April 2009 - 01:38 AM
Mac, I think I've seen that somewhere else. LOL
John Batson
#6 Les
Les
  • 66 posts
Posted 05 April 2009 - 07:15 AM
:) Thank you Mac. :)
Mr BB, I am sure that if you return it to Koford it will be repaired. (even if you did open it up.)
Stuart is like most of us, he wants his product used.
Les
Les Wright
#7 havlicek
  • 10,593 posts
Posted 05 April 2009 - 07:18 AM
From the description, I wouldn't have thought it was anything besides the switch...but I'm a carpenter :) In any case, I would also guess that the manufacturer would simply repair it as a gesture of goodwill unless it has been obviously abused. Some will even repair it free if it HAS been abused, it's still worth it just for the PR benefits.
#8 Jeff Van Scoter
Jeff Van Scoter
  • 5 posts
Posted 06 February 2018 - 09:05 AM
Hi guys. I purchased a Wright Way power supply a few months ago. New not used. It hasn't seen much use. I recently hooked up an old 26D motor to see if it still worked. When I gave it some juice the power supply went dead. I heard a brief hum and it went dead. I replaced the fuse with the correct replacement fuse and nothing. The same thing happened to my 30 + year old Slick 7. I chalked it up to it's age so I bought a Wright Way and I just blew this one. Can anyone give me direction as to where I can get the Wright Way repaired? And why wouldn't the fuse protect the power supply from frying? Any help would be greatly appreciated.
#9 zipper
zipper
  • 725 posts
Posted 06 February 2018 - 09:46 AM
Best to ask Les! http://slotblog.net/user/1012-les/
Pekka Sippola
#10 old & gray
old & gray
  • 576 posts
Try messaging Les from post #6 above. My luck with a Wright Way supply is a little different, 20 years old and still working fine.
Bob Schlain
#11 smichslot
smichslot
  • 88 posts
Posted 08 February 2018 - 04:22 AM
Most power-supplies die when too much current is pulled from them. The Korford-supply that gives max voltage when switched on is for sure the regulating transistor (-s) (controlled by a voltage Regulator) that ended it's life due to too much current. Get a new transistor of the exact same type.
Or let Koford fix it.
Steen
  • Rob Voska likes this
Steen Michaelsen
#12 Jeff Van Scoter
Jeff Van Scoter
  • 5 posts
Posted 12 February 2018 - 02:44 PM
Thanks for the help everyone! I contacted Les and sent him the power supply on a Tuesday and had it back on Saturday good as new. Les was outstanding to deal with. Les......you da man!!!! Thanks again!
#13 zipper
zipper
  • 725 posts
Posted 12 February 2018 - 03:04 PM
Yes he is!!
Pekka Sippola
