Asp and Super Asp Dimensions
Posted 07 May 2009 - 04:29 PM
- wheel base
- front track
- rear track
- front tire diameter & width
- rear tire diameter & width
- distance from front axle to guide
- distance from nose of the body to front axle
Any other information that you may feel would be helpful would also be welcome.
Posted 07 May 2009 - 04:43 PM
I will be at the museum Sunday and will make the measurements for you unless someone else posts them first.
Posted 07 May 2009 - 05:03 PM
Posted 14 May 2009 - 02:13 PM
Thanks again in advance.
Posted 14 May 2009 - 02:20 PM
Posted 14 May 2009 - 02:25 PM
Posted 14 May 2009 - 02:28 PM
BTW, I think that's an interesting project. The shape of the Asp should lend itself to a real cool-looking scratchbuilt chassis.
Posted 14 May 2009 - 04:35 PM
- front track: 2-11/16"
- rear track: a shade over 2-3/8"
- front tire diameter & width: 3/4" X 7/32"
- rear tire diameter & width: 15/16" X 1/2"
- distance from front axle to guide: 7/16"
- distance from nose of the body to front axle: 1-9/16"
I have pictures on file and will post them later.
OK, I goofed, these are the dimension for the Dynamic Super Bandit, sorry, my mistake (age does that). Steve, I will get the dimensions for the Asp ASAP (OK, now that's even more confusing!)
Posted 15 May 2009 - 07:33 AM
I just mentioned this post to MantaRay (Ray Price). He said he would post the dimensions for both the Asp & Competition Asp when he gets home tonight.
In the immortal words of Steve Martin.........I Forgot.
I will defer to the Master. I'm sure he will be measuring one out of the box
11/4/49-1/23/15
Posted 15 May 2009 - 07:46 AM
I think a chassis build under these bodies with contemporary motors, tires, guides, and most importantly a jig built chassis combined with the next to nothing frontal areas of these bodies should make for some very interesting results . Maybe like little sticks of dynamite! We'll see. Thanks again.
Posted 15 May 2009 - 09:56 AM
Steve,Thanks to all. Don't forget I'm looking for dimensions for both the Asp and the Super Asp. I'm expecting them to be totally different since one of these "thingies" would be classified very loosely I guess since there is no scale involved as "1/32"-the Asp. And the Super Asp again very loosely descrbed as "1/24".
Both Asp and Competition Asp (there is nothing such as "Super Asp") have almost the same wheelbase, track and guide lead, within 1/16". Both are in the "1/24 scale" whatever that means. However there is a kit of parts inside the box to make a 1/32 scale Maserati 250F.
The main differences between the Asp and the Competition Asp are a modified, stepped chassis tongue on the Comp Asp to fit the FT26D, can-side drive motor (a bit shorter than the FT16D, meaning a bit shorter wheelbase), sponge tires instead of molded silicone rubber and a longer body with a rear spoiler.
Posted 15 May 2009 - 10:20 AM
11/4/49-1/23/15
Posted 15 May 2009 - 10:26 AM
I always thought these cars were eye catchers, but were hobbled by parts that were dated at best when the cars came out. Now that these bodies are available it will be interesting to see what that they can do with contemporary parts, motors, and especially tires. My plan is to use the TSR spec motor in them which I think should fit nicely inside these compact bodies. All in all it should be a fun low dollar exercise.
As always thanks for your help.
