Help setting some old home set tracks - Eldon, Atlas, and Strombecker
Posted 19 May 2009 - 10:50 PM
Posted 20 May 2009 - 06:16 AM
Check out the magazine Model Car Racing by Robert Schleicher, and his books too: he's got a lot of track plans in there, and often includes plans for old track, especially Revell; Strombecker probably isn't too different from this, but Eldon would be fairly different, and I'm not sure about Atlas.
He also does a lot of plans for tracks about this size, or for a 5x9 ping-pong table.
Posted 20 May 2009 - 01:38 PM
thanks
mitch
Posted 20 May 2009 - 02:02 PM
Strombecker and Eldon is the same width as Scalextric and SCX for layout
Revell and Monogram are the same width as Ninco.
Revell and Strombecker 1/24 track is similar to Carrera
I have raced on layouts that have used all of the above. I hope to try all of the others.
Carrera is the best overall of the ones that I have tried with the deepest slot that is compatible with all vintages of cars and flags without modification. Of the older track, I prefer : 1) Monogram; 2) Revell (new kits available from REH Distributing).
Strombecker and Eldon both have very shallow slots requiring modified flags and much reduced cornering ability.
racing around Chicago-land
Posted 20 May 2009 - 02:50 PM
Posted 20 May 2009 - 03:33 PM
I have a lot of race sets from eldon, strombecker and atlas. I'd like to set up one of the tracks and am wondering if there is a source for track plans that fit on a 4x8 sheet of plywood. I plan on racing my old 1/24 and 1/32 scale cars. I was gonna use the atlas tracks unless the other brands are better. Any help would be great.
There is an auction on ebay for layouts. Put Carrera track in the search bar. I can't copy the link here.
Chris
Chris Orlando
Posted 20 May 2009 - 06:12 PM
I don't think so, unless you make special adapter track pieces.
FWIW Eldon sets used 6 volt transformers. Revell, Strombecker, Monogram and Sears Marx sets used 12 Volt transformers.
Posted 20 May 2009 - 09:00 PM
The books I have are:
The Complete book of Model Raceways and Roadways by Louis Hertz - an awesome book
Model Car Handbook by Paul Plecan
Slot Car Racing by Braverman and Neuman
A Guide to Model Car Racing by Irwin Stambler
I know I have more, I just have to find them.
What do most people do for a 12 volt power supply, can I use the 12 volt brick from an old computer? or will it get too hot. Is the amp draw a lot for slot cars?
Posted 20 May 2009 - 11:23 PM
Computers have switching power supplies. I don't know, but maybe someone has used one.
I just tested a new Scalextric car on my power supply at 5 volts and it drew .12 amps. One of my 16D cars draws about .67 amps at 5 volts.
Posted 21 May 2009 - 01:01 PM
The cheap solution to power is the Radio Shack 3am 12 volt, filtered, regulated hobby power supply. I HAD an old revell and MRC, but both burned up about 20 years ago! Been using the Radio Shack as my bench supply since then.
Fate
3/6/48-1/1/12
Posted 22 May 2009 - 02:51 PM
POWER SUPPLIES: Depends on what you want to run...amp draw limits best performance. Most home set modern systems for analog (non digital) cars use a "12 volt DC" power pack that usually measures from 13 to 15 Volts DC with only about a maximum of 3 -5 amps. Those of us that set up more permanent tables for club racing use a minimum of 5 amps PER LANE with a variable output voltage from about 9 - 15 volts. It is USUALLY tuned to the 12-14 volt range. For commercial slot car applications, a TEN amp per lane standard is needed for most of the quiker cars. The fastest slot cars can draw over FORTY amps - for an instant. An old or new car or sump pump battery works well if you do not mind having it in the house.
I like to use the Pyramid brand CB Radio power supply for club racing. 25 amp variable output for under $140. Commercial units such as a Bulldog (RV industry) can cost three times as much and not be adjustable output.
Posted 23 May 2009 - 09:50 AM
Posted 23 May 2009 - 11:58 AM
you want modern controllers. And you want the Professor Motor controllers.
Unilke most, I never stopped racing. For 30 odd years, my garage track was THE local track. To run the ordinary variety of anctient atlas and modern Ninco cars, I needed a LOT of controllers. As a club, we used 45, 35, 25, 15, 10, 7 and 4 ohm controllers on various cars.
All replaced with the single Professor Motor.
Fate
3/6/48-1/1/12
Posted 23 May 2009 - 12:16 PM
Posted 28 May 2009 - 05:18 PM
#16
Posted 02 June 2009 - 09:48 AM
