Square tube Retro Stock Car chassis
Posted 10 October 2009 - 08:46 PM
Posted 10 October 2009 - 11:55 PM
BTW, where are you going to install the JATO bottle?
1/24/48-2/18/16
Posted 11 October 2009 - 04:13 AM
Posted 11 October 2009 - 07:24 AM
Don Weaver
Don Weaver
L.H. Lapham
it will starve to death...
Posted 11 October 2009 - 08:43 AM
Mickey can DRIVE
Posted 11 October 2009 - 07:52 PM
Not a vintage work of art, just a racer.
Awaiting JK fronts from Chicagoland.
I went a little lighter and thinner on this one, more delicate. .032 tongue, .032 pan wires, .025 pans, JK F1 bracket,
no nose piece (so I could run the front as close to .050 clearance as possible).
Mickey is a good driver so he can keep it off the wall better than most
Posted 11 October 2009 - 08:59 PM
I like the "factory" mounted lead . What's that puppy weigh?
Posted 11 October 2009 - 09:25 PM
Posted 12 October 2009 - 06:18 AM
Don Weaver
Don Weaver
L.H. Lapham
Posted 12 October 2009 - 07:13 AM
What are your thoughts on using square tube for main rails instead of piano wire?
Don Weaver
Don,
I think that is an excellent question.
I'll be sitting here awaitng Pablo's answer as well.
Thanks for asking it.
Marty
1/24/48-2/18/16
Posted 12 October 2009 - 07:31 AM
2. Those are not simply square tubes, they are 055 wires with a tube jacket, soldered up as solid units. Thanks to silver solder paste and the minitorch.
3. The tubes are not perfectly flat - they have a channel on the middle of the outside edges that makes a perfect "nest" for wire pieces to lay alongside.
4. The result is a little stiffer than 063 wire and a little less than 078
5. Tubes lay flat and butt up against the bracket and brass chunks square. More surface area in contact. Plus the solder pools up in the channels.
As I add more pieces to the rails, I can hear the paste flakes continuing to pop and sputter inside the tubes as they melt, making it stronger and stronger
Posted 12 October 2009 - 10:12 AM
So this is what you built for your seven day no work stretch and done it in three?! You still have time to build another one.
Gotta the body clips...and everything else about your builds....
Slots-4-Ever
Brian McPherson
REM Raceway
Posted 12 October 2009 - 11:05 AM
and I will return to France never to return
Posted 13 October 2009 - 10:32 AM
Slots-4-Ever
Brian McPherson
REM Raceway
#15
Posted 13 October 2009 - 06:31 PM
ok....I your body!....
YA MISSED IT But thats OK... I hate body clips too........
PHIL I.
#16
Posted 13 October 2009 - 06:49 PM
Most people don't know how to properly set up clips for race cars, and they miss out on another tuning opportunity.
Jobiwan loves body clips
Posted 13 October 2009 - 06:55 PM
BTW I love body clips too! Not only can you tune, but it is so much quicker to mount and dismount a body.
Ralph Thorne
ralph@ralphthorneracing.com
RTR Facebook page
#18
Posted 13 October 2009 - 07:10 PM
Good luck at the SANO !!!
Looking forward to seeing you, and Jobiwan, I hope, in Warner Robins 24 Oct
Posted 13 October 2009 - 07:26 PM
#20
Posted 25 May 2016 - 06:08 PM
Was Russkit the first to use those style body clips on the stamped pan chassis ?
#21
Posted 25 May 2016 - 07:38 PM
The first I ever saw was on a Russkit Porsche Carrera I bought in the fall of 1967.
