Motor temperature
Posted 10 December 2010 - 01:11 PM
S16D ?
Super Wasp?
Contender?
Group 12?
Group 15?
Group 20?
Cobalt 27 ?
Cobalt 7 ?
And eurosport ?
I would like to know this to help me tune my cars.
Thanks
Dallas
Posted 10 December 2010 - 01:24 PM
I don't think theirs an answer to your question. Every motor built will run different depending on how it's set up. Timing of the arms used, magnets, magnet gaping, power used, gearing, ect,ect. To many things will change each motors performance and temps.
Another reason why no two motors will run exactly alike .
Vic
Posted 10 December 2010 - 01:33 PM
when we drowe this 3 min test heat with our can we pumpt the gas much so the engine had to pull all the way thro the curvs like as we over dosed the small inbrake on every lap so the engine had more work ...than just to go om full gas with max rpm....
if you race the firsth 2 lapps on full power in timeq to final is ofen the fastest laps after 5-9 laps it starts to drop time just a llittel bit...
and it allso werry big diffrent betwen engins ...
i found my ir temp now.......and i will temp all of my cars too se what kind of heat they produce g27 and g7 open is BIG heat monsters...
we allso plan too set up air noislers ...cant spell... and build a airsysten with like 10mm copper pipes in our club ...realy easy too cool the engine down between heats ..just give it a qick blowjobb ....and then back to the racing ...with full power.........LOL
- Dave_12 likes this
Joakim Forsman
Posted 10 December 2010 - 01:52 PM
http://www.coolmagne...om/magstren.htm
Posted 10 December 2010 - 04:17 PM
Lower temp ==> Lower electric resistance ==> more power.
Higher temp ==> Weaker magnets ==> Less torque.
Because light travels faster than sound, some people appear to be bright until we hear them speaking.
Posted 10 December 2010 - 04:51 PM
We are not talking about internal combustion engines. In electric motors, the cooler the better, without going to extremes. I'm talking about room temperatures, not about dipping the motor in liquid nitrogen.
hi ....good reply..
the intresting thing is howe they work in 20-150 degrees c...or under nomal conditions when we drive...
i think the best is too hawe like 30-60 degrees ...as normal and nott newer go higer then100 degrees c
a thing thats like 90 or 100 degrees hot you dont stick you finger too so long ..its hot its a big diffrent to like 60-70 degrees..
Joakim Forsman
Posted 10 December 2010 - 07:18 PM
What is the max temperature of these motors?
parma sealed S16D
Contender
Super Wasp
Group 12
Group 20
Group 27
Group 7
I know the chemicals that are used in magnet wire and I know if you are running a ML its max point is 220 celcius but if they use Polyurethane then it is only 155 celcieus. I am only asking for and educated guess so whomever feels like Mr Spoke out there and can give me that guess it will be appreciated.
Dallas
Posted 10 December 2010 - 09:22 PM
Dallas, I am in no way an expert about this but I was just starting to work with this temp thing when my son quit Group 7 racing, so I left it be. You are saying 220C for magnet wire which is 428F. From my testing, an open arm will withstand just under 300F and stay alive, over 300F they begin to die rather quickly. I think, if IIRC, red arm dye will begin to discolor at about 180F? I am sure some real motor guru will support or knock that number down. It would be a real shot in the dark and a pure guess but I would think any small wire motor(29 gauge/30 gauge/32 gauge) would probably take 190-200F and lose it at 200+F????OK I have more specifics I want to know.
parma sealed S16D
Contender
Super Wasp
Group 12
Group 20
Group 27
Group 7
Dallas
Although the coating may withstand 220C the wire size will also come into play, I would think. You know bigger wire carrying more amps than smaller wire etc. Too much heat you are probably lugging the arm and asking it to pull more amps than it can handle and poofta!
Rick Bennardo
"Professional Tinkerer"
scrgeo@comcast.net
R-Geo Products
Lead! The easy equalizer...
Posted 10 December 2010 - 09:34 PM
Cobalt motors we looked at the arm dye and the comm.... never took temps on them. The temps can be all over the place on cobalt motors depending on how much or how little choke you run.
A Parma or asian made arm will cook a lot faster than a American made arm in 16-D's Super 16'D. The asian arms are made with lower temp wire and the magnets are not as good/strong as the ones used in the C-can motors.
Some X-12 arms are made with ML and some are not. Depending on if the wire used is American 29 Ga or Metric. The Metric wire used on some X-12 arms is NOT ML...... it has a rating of only 200C.... but if it runs 180 F or higher change it just as you would with 29 ga ML wire.
The American made 16-D's, S-16-D's, Wasp and Contenders may or may not be ML wire and are probably rated at 180- 200 C.
The old school way to check..... put some spit on the stack and if it sizzles.... change it. Water boils at 220 F
Posted 10 December 2010 - 09:50 PM
Sometimes changing the pinion by one tooth can make a difference if a motor is a one heat wonder or a all day player.
Posted 11 December 2010 - 01:33 AM
thanks for the input. I am trying to figure out optimum heat so as I test motors I can change gearing and such to hit the sweet spot. I just Bought a infared laser heat gun. New toy for slot cars.......
Posted 11 December 2010 - 03:30 AM
Hello All,
hi esyest way is too go as cool as you can the engine will last longer ,,,
like the others say geearing,mag gap,arm degrees,power,bruches etc is making diffrent so its not a easy
anser ..
but try too hawe a open can so you pump a lot of air throo the can and engine its cooling
the old mura engine is werry gratful to mod i hawe opend upp 3 of then now and they ar looking like new engins and runns cooler than before
and try to adjust the arm degrees so you dont run to hot arms 38-40 i think is normal...
and air gap is allso important byt if its too big you loose power....
Joakim Forsman
Posted 11 December 2010 - 09:02 AM
.....i think it looks like the c-can engins dont go so warm
That's completely untrue. The C-can can run anywhere between "cool" and meltdown hot... it depends on the arm, timing, airgap, choke, magnets, track power, the weight of the car it's being asked to push and the gearing ("lugging" will cause a motor to draw more current and could make it burn up...on the other extreme, having a car wind-out less than half way down the longest straight could also do harm), poor setup or sloppy bushings or bearings can also make a motor run hot, binding of the gears etc.. A C-can is only a setup and any setup can run cool or hot.
- stoo23 and Kim Lander like this
Posted 11 December 2010 - 11:11 AM
Today we build motors for a particular class that may allow air control or glue or both and that loads the motor and creates heat. At times the fast way to go is also the way to short motor life. You either accept that or go slower. As Ron pointed out a lot of the time a change to gearing that allows the motor to rev will greatly improve motor life. Peaking halfway down the straight as John pointed out means you have gone too far the other direction.
Like reading a sparkplug on a car the slot car armature can tell you a lot about how the motor has been running. Between the arm dye changing color and what the com track looks like and the color of the com, you get a lot of information to make changes.
Rule of thumb, start with the set up that the fast guys are using for gearing, brushes, springs and airgap. If you are new have an experienced racer check your car to see if it is bound up. Over tight gear mesh or tight axle spacing is great at creating heat and slowing your car.
After doing that, gaining experience and racing for 20 or so year get used to saying, "Now why did it do that?" Then try to figure it out and hopefully solve it.
Mike Boemker
#15
Posted 11 December 2010 - 02:26 PM
Asking you guys a question is like asking my wife. I get lots of answers but am still puzzled afterward about what to do. AHAHAHAHAHAHAHA
Thanks
Dallas
#16
Posted 11 December 2010 - 02:33 PM
Man!!!!!!
Asking you guys a question is like asking my wife. I get lots of answers but am still puzzled afterward about what to do. AHAHAHAHAHAHAHA![]()
Thanks
Dallas
haha God point...LOL
but try too keep it cool its the best way...
Joakim Forsman
#17
Posted 12 December 2010 - 04:59 PM
up date .. to night i ran my G7 car 13 volt and full Cocke 3 min time and nott so much glue on the track with small tiers ...temp after aprox 3 min drive and 40-50 lapps
145-150 deg c ...
nott funny i think with less chocke and more glue andbigger tires this suucker engine will easy come upp too 200 deg C .. its a g7 engine with 459 arm and a hot vind it runns werry good byt sorry to say ...werry hot too
Joakim Forsman
#18
Posted 13 December 2010 - 01:48 PM
If you let the smoke out, it is too hot!
Fate
3/6/48-1/1/12
Posted 13 December 2010 - 03:04 PM
Hi
Fate
allreddy tested ... like the g7 engine blow up....10 or 12 laps...
not fun..
Joakim Forsman
#20
Posted 13 April 2025 - 04:17 AM
Put the motor into a wing car and do 15 laps then check the lap time and the arm temperature with a infra red thermometer.
What you want is no more than 110 degrees Celsius .
This is a good measure that the motor will go the distance in a race.
