TSR (1/24) motor specs
11 replies to this topic
#1 James Robertson
James Robertson
  • 15 posts
Posted 13 July 2011 - 01:48 PM
I have a TSR 1/24 scale chassis and I don't know the specs of the motor that came with it. It looks like the motors on the TSR website but I can't find the info there either.
I am lacking brakes and had thought it maybe a low torque motor?
I have fairly short gearing so would doubt it would be the overall ratio - that is why I am interested in the torque figure of the motor - before I think about replacing it.
Thanks
Jim
#2 Jacob Shiplet
Jacob Shiplet
  • 3,156 posts
Posted 13 July 2011 - 02:07 PM
I think that's the T2415 motor correct? Thats the 43K RPM motor (advertised). Not sure what you mean by no brakes?
Do you know the difference between education and experience? Education is when you read the fine print; experience is what you get when you don't.
#3 Cheater
  • 25,696 posts
Posted 13 July 2011 - 02:14 PM
Jim,
Not every motor maker publishes torque specs; in fact, most don't.
This list may help:
Slot Car New Motor List
Since the list is alphabetical, you'll have to scroll down a bit for the TSRF/TSR motor specs.
#4 James Robertson
James Robertson
  • 15 posts
Posted 13 July 2011 - 04:18 PM
Thanks.
Jacob, I'm referring to the motor had poor brakes in that it doesn't slow the car down very well.
#5 Victor Poulin
Victor Poulin
  • 2,097 posts
Posted 13 July 2011 - 06:07 PM
James,
What are you using for a controller? The reason I ask is that sometimes the type of controller can make a huge difference on brakes.
Vic
Alright, who cut the cheese?
#6 James Robertson
James Robertson
  • 15 posts
Posted 14 July 2011 - 01:16 AM
It is a homemade adjustable thing - it has diode adjustment on the brakes.
It was designed primarily for 1/32 hardbody racing, but I have used it successfully with 1/32 brass cars with Super Wasp motors.
It's just the TSR that seems to lack any brakes!
I want to add some lead to it but that will just make it not want to slow down even more!
#7 TSR
  • 42,299 posts
Posted 14 July 2011 - 01:42 AM
You may have a dud motor... it can happen.
#8 James Robertson
James Robertson
  • 15 posts
Posted 15 July 2011 - 02:45 AM
In defence of TSR I didn't buy the chassis new, so I don't know the history of the use that the motor has had.
I had a go with the car last night and it is definitely losing power now too, so maybe the motor is on its way out!
#9 TSR
  • 42,299 posts
Posted 15 July 2011 - 03:20 AM
What kind of track is this used on? Depending on it, I can make some recommendations. These are primarily designed to run on Carrera plastic track with mild magnet traction, with plastic kit bodies. There are two motors available.
#10 James Robertson
James Robertson
  • 15 posts
Posted 15 July 2011 - 10:47 AM
A reasonably-sized gloss track. No spray glue. Car batteries and a charger.
I'm not sure which motor I have to be honest!
And I am using a plastic kit body ~(quite heavy).
#11 TSR
  • 42,299 posts
Posted 15 July 2011 - 11:24 AM
I suggest a TSR D3 motor that will have the torque to carry a very heavy body as well as supplying decent brakes.
#12 James Robertson
James Robertson
  • 15 posts
Posted 15 July 2011 - 04:26 PM
Cheers for your advice!
