The first thing I wanted to do with this car was to lower the car to a better stance. In order to that you have to cut the interior down (check photos) along with the posts. The good news about dropping the interior is that the wires from the motor fit better under the interior. I'm not using the original headlights so I have filled in the holes. I'll use a more realistic set of lights. I also fitted the black wrap for the windows. These will be fitted with rivets later. The body is not done yet but half way there. More details will be added. The chassis will be sand blasted along with the wheels. This car should look pretty good when it's done.
