Epoxy for controller resistors?
Posted 12 May 2007 - 02:17 PM
Posted 12 May 2007 - 02:33 PM
Hey, let me know how it goes!
Generally I coat the friction surface with a nice thick layer and let it cure for a day. then get some 220 and 400 grit wet/dry sand paper and slowly block sand the wiper surface with the 220 and then the 400 until it's baby butt smooth. That wiper action is sooooo nice!
Posted 12 May 2007 - 02:43 PM
Posted 12 May 2007 - 03:06 PM
When sanding a resistor, be careful to not take too much "wire" off as when you do, you will change the ohm's of the resistor.
Posted 12 May 2007 - 03:10 PM
Jim "Butch" Dunaway
Posted 12 May 2007 - 04:18 PM
Posted 12 May 2007 - 05:23 PM
Jim "Butch" Dunaway
Posted 12 May 2007 - 06:23 PM
I've used Super Glue. Works great.What type of epoxy can I use to coat the resistors on my Parma econo controllers. Even though they are working fine except for 1 that had the windings work loose I have 4 of them that I would l like to coat to prevent this.
Steve King
Posted 12 May 2007 - 11:46 PM
Posted 12 September 2010 - 04:46 PM
racing around Chicago-land
Posted 12 September 2010 - 05:30 PM
FACT of life: Resistor wires burn out at the top end and need repairs. You can usually repair a slotcar resistor three or four times.
Yeaaaaa, if you don't mind them working like a light switch
Posted 12 September 2010 - 06:45 PM
Posted 12 September 2010 - 06:53 PM
The wet wound resistors were exactly that....... wound while the epoxy was wet.
The resistor cores were coated with epoxy before the wire was wound on the cores. When dried, the wire was bonded to the core with a small film of epoxy between the core and wire. The epoxy "stuck" the wire to the core.
The sanding lowered any "high" bands due to excessive epoxy in spots along the core.
Unless you can get epoxy between the wire and core on a finished resistor.... I am afraid your wasting your time.
Normal resistors are wound then coated afterwards...... this is why wire lifts on them from time to time.
Posted 12 September 2010 - 07:24 PM
Remove all the colored ceramic coating you can, using a dremel or whatever. Then apply generous coats with a Popsicle stick, one side at a time. (let one side dry before coating the other.) When applying to the face that the wiper arm touches, scrape off much of the excess with your Popsicle stick. When dry, carefully skim the surface with a Dremel cut-off blade, until the bands are exposed for the wiper button. Finish off with 220 or 340 grit wet-or-dry sandpaper. Some wiper buttons have a tendency to stick if the surface is too smooth. Changes in resistance, due to JB Weld metal content is negligible.
Resistors refinished like this are smoother, easier to maintain, resist lots more heat and last much longer!
#15
Posted 12 September 2010 - 09:07 PM
#16
Posted 12 September 2010 - 09:25 PM
If you're going to do that, I recommend a belt sander (much faster).When dry, carefully skim the surface with a Dremel cut-off blade, until the bands are exposed for the wiper button.
