Flying Slot Factory Can-Am chassis
46 replies to this topic
#1 One_Track_Mind
One_Track_Mind
  • 2,964 posts
Posted 02 January 2012 - 05:32 PM
4" wheelbase, 1" guide lead.
.062" main rails, .055" bite bar.
3/4" motor bracket.
My only mistake or oops was placing front axle uprights too far apart. Will need to use a narrow hub front wheel.
Thought they looked good flush with cutouts.
Still needs to go through the tumbler.
Slots-4-Ever
Brian McPherson
REM Raceway
#2 Brian
Brian
  • 1,659 posts
Posted 02 January 2012 - 07:11 PM
Nice build, Brian!
I should have told everybody that the "kit" uprights weren't designed to sit flush with the wheel cutouts.
The motor bracket looks bulletproof with all the bracing!
Looking forward to seeing it after the wash,
Professional Garage Guru
Brian Cox
#3 John Miller
John Miller
    This space for rent
  • 1,149 posts
Posted 02 January 2012 - 07:19 PM
Looks good, Brian.
#4 One_Track_Mind
One_Track_Mind
  • 2,964 posts
Posted 03 January 2012 - 03:32 AM
I took the liberty of using the good ole camera to get some better pictures. It's a little more time-consuming, but it's all worth it! :)
The bulletproof motor bracket, I did this becasue of using the axle tube and the 3/4" motor bracket. Completed with the patent pending wonky gear guard. :)
The bottom side, still haven't given it a good smooth wash through the tumbler. Waiting to get another one complete and then can do them back to back. Not at the same time!
64 grams as shown.
Over-all thought of building this chassis...
The brass was flat as a pancake,best I've ever worked with! (No I didn't get paid to say this!) :)
As the "other" Brian pointed out in his builds, a little filing around the sharp cut edges was all that was needed to make it nice and smooth.
You had to be very cautious when soldering on the guide flag with having the other piece underneath as the spacer, once it got hot it didn't take much to move it around.
The front axle uprights were set to the outside of the cutouts since the jig wheels held them nice and square. The afterthought was noticing the width being a little wide. DON'T do this if you're going to use bearing front wheels or a wide hub. They will need to be inset more onto the chassis plate.
I like the the fact you can place your body mount tubes anywhere on your pans,the easy way of course is the bent uprights, but why be like everyone else?!
Will scrounge up some parts and put this baby on the track to test.
Results will follow!
Thank you, FSF, for another great Retro kit!
Slots-4-Ever
Brian McPherson
REM Raceway
#5 One_Track_Mind
One_Track_Mind
  • 2,964 posts
Posted 08 January 2012 - 07:25 AM
Moving on with some more builds of the FSF Retro cars.
This one has the 1.3" motor bracket, .078" main rails, and a .062" floating bite bar
Still needs to be cleaned and tumbled.
Next up: something a little different with the FSF kits to show the versatlity of the pieces: an IRRA™ 4.5 Stock Car!
Stay tuned!
Slots-4-Ever
Brian McPherson
REM Raceway
#6 Brian
Brian
  • 1,659 posts
Posted 08 January 2012 - 10:24 AM
Very nice build, Brian!
Its really nice to see some different ideas.
If you notice, the holes in the motor bracket are larger than the bushings. This because the 3/4" and 1" motor brackets are sized for .218" bearing/bushing tubing. All other FSF motor brackets are sized for bearing/bushing only.
I also see you used the "tabbed" uprights, very cool!
Looking forward to seeing more,
Brian Cox
#7 One_Track_Mind
One_Track_Mind
  • 2,964 posts
Posted 14 January 2012 - 06:48 PM
4.5" wheelbase, .75" guide lead.
3.0" wide.
.078" main rails.
.062" bite bar.
1" wide motor bracket.
Slots-4-Ever
Brian McPherson
REM Raceway
#8 One_Track_Mind
One_Track_Mind
  • 2,964 posts
Posted 24 January 2012 - 04:39 AM
The Stock Car all dressed up, ready for the track test to begin.
Slots-4-Ever
Brian McPherson
REM Raceway
#9 Jay B.
Jay B.
  • 2 posts
Posted 24 January 2012 - 08:04 AM
What jig are you using to build these chassis?
Jay Batdorf
#10 MantaRay
MantaRay
  • 2,859 posts
Posted 24 January 2012 - 09:19 AM
Nice work, young man...
Ray Price
11/4/49-1/23/15
#11 One_Track_Mind
One_Track_Mind
  • 2,964 posts
Posted 24 January 2012 - 09:28 AM
I use an R-Geo jig.
Thanks, Ray! :)
Slots-4-Ever
Brian McPherson
REM Raceway
#12 Brian
Brian
  • 1,659 posts
Posted 24 January 2012 - 09:29 AM
Very nice, Brian!
You're the first to build a Stock Car out of the Pro CA. Johnny VW was going to build one out of a Z2CA but not sure if he finished it.
Brian Cox
#13 One_Track_Mind
One_Track_Mind
  • 2,964 posts
Posted 27 January 2012 - 05:28 PM
Pelimanry test run on the stockcar is great!
Will know more on sunday!
Car weight shown is 119.8 grams,just a tad bit of lead maybe on the pan for full punch of the doughnut! :laugh2:
Slots-4-Ever
Brian McPherson
REM Raceway
#14 Brian
Brian
  • 1,659 posts
Posted 27 January 2012 - 09:08 PM
Keep us updated Brian,
Really liking your results so far!
Brian Cox
#15 Precision-Slotcars
Precision-Slotcars
  • 233 posts
Posted 03 February 2012 - 12:39 PM
Here's my first FSF Can Am build. I'll test it this weekend.
Dave Mountz
Built to win! ALL PSC race team members build exclusively with Precision Slot Car products!
Build with Precision - pslotcar.com
Buy 'em here - Precision Slot Cars store
See it all - Precision Slot Cars on Facebook
All designs, products, and trademarks are the sole property of Precision Slot Cars™ © 2014
#16 One_Track_Mind
One_Track_Mind
  • 2,964 posts
Posted 04 February 2012 - 05:12 AM
Now that B&W is pure Retro! :)
Nice build Dave,
thanks for sharing
Slots-4-Ever
Brian McPherson
REM Raceway
#17 Brian
Brian
  • 1,659 posts
Posted 04 February 2012 - 09:14 PM
Dave,
I like the build/pic. also!
How did your test go?
I found my car to tight today at the P-O event at REM in Mentor, Oh by the time my main came around. I'm finding out I'm liking cutting tires. Reminds me of Rt.93 back in the day running GTPs & 12s!
Brian Cox
#18 Brian
Brian
  • 1,659 posts
Posted 04 February 2012 - 09:25 PM
Congrats Brian on your 5th today at the P-O!
5th. place,, four laps from first, unheard of in Stock Car!
Big comp. at REM today!
Thanks for GOOD TIMES!
Great Success today for FSF! Brian is the first to build a Stock Car out of an FSF 1.3 Pro CA Kit!
GREAT JOB!
Brian Cox
#19 One_Track_Mind
One_Track_Mind
  • 2,964 posts
Posted 20 February 2012 - 05:47 AM
Built another one for my friend Jay Sabala,same specs as all previous ones,just added a couple more braces here and there,very sublte changes.
Still needs to go thru the tumbler for a smooth clean,finish.
Slots-4-Ever
Brian McPherson
REM Raceway
#20 Pablo
  • 13,167 posts
Posted 20 February 2012 - 09:19 AM
That's not wonky, it looks real strong :D WTG, Brian. :victory:
#21 Brian
Brian
  • 1,659 posts
Posted 20 February 2012 - 11:39 AM
Another very nice build from Northern Ohio!
Brian Cox
#22 Mad Mexican
Mad Mexican
    Safer Barrier Tester!
  • 1,265 posts
Posted 20 February 2012 - 12:55 PM
Yes Amigos,
That little beauty is gonna to be mine on Sunday! :heart: I cannot wait to test it out. :D
Thank you Brian and Brian for the chassis concept and for the cool build. :good:
Adios Amigos
Javier Zavala
In loving memory of my mother Francisca Escalante Zavala
March 24, 1927 - April 5, 2011
Vaya Con Dios
#23 One_Track_Mind
One_Track_Mind
  • 2,964 posts
Posted 20 February 2012 - 01:13 PM
It is going round and round right now getting all purdy for ya, Amigo.
The Wonky is still in the gear guard, Pablo! Patent pending trademark built into every chassis.
Thanks FSF originator :)
(null)
Slots-4-Ever
Brian McPherson
REM Raceway
#24 Brian
Brian
  • 1,659 posts
Posted 20 February 2012 - 04:42 PM
Thank you Brian,
R.E.M. of Mentor, Oh carries FSF Products,
Brian Cox
#25 Mad Mexican
Mad Mexican
  • 1,265 posts
Posted 22 February 2012 - 03:45 PM
Amigos,
Brought the little chassis home today. I should have it race ready by Sunday.
Adios Amigos
Javier Zavala
Vaya Con Dios
