Mike Katz chassis builds
83 replies to this topic
#1 slotcarone
  • 3,993 posts
Posted 02 January 2012 - 11:49 PM
:) I figured it was about time I started a post with my chassis builds. The first one is the new FSF chassis kit that I built as a floppy pan design. The brass shines up real nice - I purposely put a reflection of the camera in two of the pictures. Comments welcomed.
  • Lou E and C. J. Bupgoo like this
#2 Mopar Rob
Mopar Rob
    Retro Snob as of 1/12/2011
  • 3,445 posts
Posted 03 January 2012 - 12:36 AM
Mike:
Clean build
Rob Hanson
Rob was right!
#3 slotcarone
  • 3,993 posts
Posted 03 January 2012 - 12:43 AM
:) Thanks, Rob. I am planning on racing this chassis next Saturday at Slots-A-Lot in the GT Coupe class. I seems to handle well but of course the real test is in a race.
#4 Gator Bob
  • 13,391 posts
Posted 03 January 2012 - 12:59 AM
Sano build, Mike. :good:
Two questions...
Does the motor contact the center brass? Hard to judge from the pics.
Is the left front wing damaged or is this some secret speed trick?
Oh... one more. What are your thoughts on the front up-rights?
#5 slotcarone
  • 3,993 posts
Posted 03 January 2012 - 01:05 AM
:) Bob,
The motor goes in with plenty of room to spare although in the pictures in doesn't appear that way.
The marks on the wing were in the brass I guess from the original cutting.
I used the front uprights since these come with the kit. I was going to make piano wire supports but decided to use these supplied ones instead.
#6 Gator Bob
  • 13,391 posts
Posted 03 January 2012 - 01:19 AM
The uprights look strong... are they heavy-ish, easy to work with alignment, come pre-bent?
Would this be a low bite/low flex design with the four rails and the center pan?
Thanks.
#7 One_Track_Mind
One_Track_Mind
  • 2,966 posts
Posted 03 January 2012 - 04:30 AM
Are the main rails twin .055"?
My next one on the chassis jig is just like this one, I'm doing a .078" single rail with the other style front axle uprights.
Was wondering on how to attach the pans? And now I know! :)
Great-looking build, Mike! Thanks for sharing.
Oh yeah, is the motor bracket the 1.4" width?
Slots-4-Ever
Brian McPherson
REM Raceway
#8 slotcarone
  • 3,993 posts
Posted 03 January 2012 - 06:49 AM
The uprights i guess are on the heavy side but should be plenty strong. They are flat and you have to bend them but are pre-notched and very easy to bend. There is nothing to align them but the jig lets you put them in the correct spot.
This chassis has a very smooth flex to it, more than an .063" single rail but less than an .078" rail.
#9 slotcarone
  • 3,993 posts
Posted 03 January 2012 - 06:51 AM
The bracket is the 1.4" width and I found that I have to use narrow tires to clear the .055" chassis rail that is next to it. The rails are both .055".
#10 tonyp
  • 15,325 posts
Posted 03 January 2012 - 08:42 AM
I guess Mike got a camera for Xmas.
#11 Noose
Noose
  • 23,312 posts
Posted 03 January 2012 - 09:18 AM
Nice build, Mike!
Glad to see you are finally showing some of your fine work. Mike is a great builder and gets that shine without a tumbler. He does it the old fashioned way - Comet and a brush. LOL.
Now you need to take some pics of your winning frames - the Tripod and the Stock Car.
#12 Brian
Brian
  • 1,659 posts
Posted 03 January 2012 - 09:41 AM
Very nice, Mike!
Looking forward to seeing it assembled. The 1.4" motor brackets actually measure 1.370 and the 1.46" measures 1.440". The only time that we ran into trouble with a wide motor bracket is when the 1.46" measured 1.467".
The Pro Can-Am kit actually comes with a 1.3" motor bracket that measures 1.281". I was out when I sent out chassis for building, that's why you have the 1.4".
I believe we wrapped the inner .055" under the bracket and the outer came up the corner.
There should still be .020" per/side of clearance for the tire. That's if you have your tires rubber faced off flush with the hub.
Just an observation...
Professional Garage Guru
Brian Cox
#13 JerseyJohn
  • 4,204 posts
Posted 03 January 2012 - 10:05 AM
Great job, Mike. Brian also sent me a kit. Thanks for the ideas...
John Chas Molnar
Jerseyjohnchassis
#14 Chris Radisich
Chris Radisich
  • 144 posts
Posted 03 January 2012 - 01:28 PM
Great-looking chassis, Mike. I look forward to racing against them.
#15 Dominator
Dominator
  • 2,955 posts
Posted 04 January 2012 - 12:22 AM
Great-looking chassis, Mike!
Dominic Luongo
NERR photos from 2016 to now
#16 slotcarone
  • 3,993 posts
Posted 04 January 2012 - 12:29 AM
:) Thanks for the compliments!!! Will find out how it races Saturday but since it is a GT Coupe race I will be at the mercy of the FK motor gods. I will have to add some weight as it still only weighs 106.7 grams RTR.
#17 Gator Bob
  • 13,391 posts
Posted 04 January 2012 - 01:14 AM
"May the force be with you." :ph34r:
#18 Chris Barnes
Chris Barnes
  • 556 posts
Posted 04 January 2012 - 08:02 AM
Hey Mike,
Good-looking chassis. Where did you get the steel guide piece? Did it come with the chassis?
Chris
#19 Dominator
Dominator
  • 2,955 posts
Posted 04 January 2012 - 11:02 AM
I believe the guide tongue is the one Brian includes in the kit.
Dominic Luongo
#20 One_Track_Mind
One_Track_Mind
  • 2,966 posts
Posted 04 January 2012 - 11:03 AM
Correct, Dom.
Slots-4-Ever
Brian McPherson
REM Raceway
#21 Noose
Noose
  • 23,312 posts
Posted 09 January 2012 - 02:40 PM
He won't tell but I will. This frame in it's maiden voyage win this weekend when Mike used it in our GTC-FK Class race. Here are the pics of the whole car. He kicked but with it on the King.
  • C. J. Bupgoo likes this
#22 Brian
Brian
  • 1,659 posts
Posted 09 January 2012 - 04:24 PM
I just want to say "Thank you" Mike,
I appreciate you taking time to put one of these kits together & the BIG plus is you won with it!
I believe this the second win for FSF in the Retro East series, Johnny VW took one awhile back with a Z2CA tripod.
Looking forward to seeing more "Katz" builds,
Brian Cox
#23 Michael Rigsby
Michael Rigsby
    SRT Motorsports
  • 1,914 posts
Posted 09 January 2012 - 05:08 PM
Nice looking kit. I need to get one to build to do a comparison or two since I'm getting back into building. Good clean work and the design is straight forward.
MR
#24 slotcarone
  • 3,993 posts
Posted 31 October 2012 - 02:43 PM
#25 slotcarone
  • 3,993 posts
Posted 31 October 2012 - 03:06 PM
