Cox Pro controller resistors
14 replies to this topic
#1 Lone Wolf
Lone Wolf
  • 2,287 posts
Posted 27 January 2012 - 03:34 PM
I have a couple Cox pro controllers. I also have some resistors new in the package and some loose ones too. As you may or may not know these are quick change resistors, not standard type. My question is, How do I Ohm them out to check value on the loose ones? Easier to do in the handle or loose? Thanks.
Joe Lupo
#2 HarV Wallbanger III
HarV Wallbanger III
    Racing inta OLD age!
  • 6,023 posts
Posted 27 January 2012 - 06:54 PM
Hey Joe would you have any old COX 25 or higher resistors. I will trade a 12/15 ohm? (can't remember so I will check) for one.... Also OHM check on the tabs with a cheap Radio Shack meter. You can do it in the handle but it will include the wires resistance so just open it and again check on the tabs. Make sure your are on measrue across the first band to the end band and not the brake band.
Barney Poynor
"BRONCO" BARNEY
Team CORT!
Hello my name is Barney and I was... I am addicted to glue, magnets, and wings... I have been clean and sober years now... NOW I'm hooked on 1/32 club track racing! Dang!
"Even if you're on the Right Track, you'll get run over if you just sit there!"
If you remember
screw-on braid, motors that look like padlocks, that dang fuse wire in Cox controllers, "hand" painted bodies, the very first can motors from Mabuchi, and the smell of wintergreen then you are OLD!... like me!
Enjoy life! Race Slot Cars and read SlotBlog!
#3 Lone Wolf
Lone Wolf
  • 2,287 posts
Posted 27 January 2012 - 07:20 PM
Barn, Are you talking about a standard Cox resistor? These ones for the "Pro" controller are different from the standard. I am going to post a pic of the resistor tomorrow so someone can tell me exactly where to put the probes. And by the way I still have my Fluke meter from my tech days. Don't say Radio Shack to me when doing such technical work :laugh2:
Joe Lupo
#4 HarV Wallbanger III
HarV Wallbanger III
  • 6,023 posts
Posted 27 January 2012 - 08:56 PM
HA!
Barney Poynor
"BRONCO" BARNEY
Team CORT!
If you remember
#5 Lone Wolf
Lone Wolf
  • 2,287 posts
Posted 30 January 2012 - 11:20 AM
Here is a pic of the Pro resistors. How do I check the value of the loose ones. Stangely, Cox did not print the value on these.
Can someone also tell me about the standard Cox resistors so I can see if I have something for Barn,Thanks.
Joe Lupo
#6 HarV Wallbanger III
HarV Wallbanger III
  • 6,023 posts
Posted 30 January 2012 - 01:17 PM
The ones out of the package look to be the same Joe. I'll show you one in a few thanks. I would like to find in 25 OHm if I can.
Barney Poynor
"BRONCO" BARNEY
Team CORT!
If you remember
#7 HarV Wallbanger III
HarV Wallbanger III
  • 6,023 posts
Posted 30 January 2012 - 01:42 PM
This is the old style Joe. This is what to look for on yours to check. Brake band will not be in the circuit... it's a dead band.
  • Frank The Tank likes this
Barney Poynor
"BRONCO" BARNEY
Team CORT!
If you remember
#8 Lone Wolf
Lone Wolf
  • 2,287 posts
Posted 30 January 2012 - 03:30 PM
Barn, Great info and graphics,Thanks. PM sent on the 25'er.
Joe Lupo
#9 HarV Wallbanger III
HarV Wallbanger III
  • 6,023 posts
Posted 30 January 2012 - 06:30 PM
Thanks Joe check your PM's
Barney Poynor
"BRONCO" BARNEY
Team CORT!
If you remember
#10 Robert Blaschke
Robert Blaschke
  • 94 posts
Posted 11 March 2012 - 08:54 AM
Are Cox controllers wired differently than MRC plunger or Parma/ Russkit controllers?
#11 Lone Wolf
Lone Wolf
  • 2,287 posts
Posted 11 March 2012 - 02:44 PM
Robert, Can't say on the Parma's but I read somewhere that the hook up wires ( black and white ) should be reversed when you use an MRC controller. What say the experts?
Joe Lupo
#12 Frank The Tank
Frank The Tank
    I'm Just Saying
  • 110 posts
Posted 31 May 2018 - 06:53 AM
trying to rewire and old one like in the pic, red and black were attached to the screws but the white was loose. Where should it be connected to? thanks I know this is an old post but hoping someone will see it.
Frank Giordano
#13 old & gray
old & gray
  • 590 posts
Posted 31 May 2018 - 07:32 AM
Looks like it would be connected to the wiper. If I remember correctly these controllers were wired with the black wire as power.
Bob Schlain
#14 Ramcatlarry
  • 2,216 posts
Posted 31 May 2018 - 09:56 AM
Early Cox and MRC are consistently backwards.  RED brake wire always goes to brake band;  BLACK wire always goes to wiper arm.  White/in-power always goes to full ON band...in modern track wiring of commercial tracks.
I cannot say I have ever seen the 'Pro" Cox controller, but I doubt if more than the one ohm value resistor was ever made for it.  Too bad the wattage value is so low.
Host 2006 ISRA/USA Nats
#15 Allan Feldman
Allan Feldman
  • 230 posts
Posted 07 June 2018 - 10:22 AM
Just for info from the other side of the pond. I have the Pro Cox controller and the similar spare 7.5ohm resistor MIP. However, the instructions that came with the controller under Replacement Resistors are as follows:-
4746 2.5 Ohm Resistor       $1.50
4747 7.5 Ohm Resistor       $1.50
4763 5.0 Ohm Resistor       $1.50
From the writing on the Box lid and the inside tray of the box it would appear the Pro controller was fitted with a 5 Ohm Resistor as standard
Regards Allan
  • Ramcatlarry likes this
