How many amps does a typical motor draw?
17 replies to this topic
#1 JoshFink
JoshFink
  • 2 posts
Posted 28 January 2012 - 09:24 AM
Looking to build a test block so I can put the car on it and make sure it's running OK, break-in the motor, etc. I can get a 12 volt power supply to power it but I wanted to make sure I had the right amount of amps.
Thanks,
Josh
Josh Fink
#2 Cheater
  • 25,756 posts
Posted 28 January 2012 - 09:34 AM
Josh,
You're going to have to define "typical" for you.
Typical C-can or D-can motor as used in 1/24 commercial raceways?
Typical mini moor used in 1/32 Europlastic cars?
Typical strap or can motor used in wing car racing?
Without any additional info, 5 amps ought to work for most everything except the high end C-can and strap motors. For 1/32 cars, 2 or 3 amps should suffice.
#3 TSR
Posted 28 January 2012 - 11:44 AM
My swimming pool motor draws 20 amps at 220 volts.
My TSR motor in my Retro pile draws 0.8 amp at 12 volts, and 0.38 amp at 3 volts.
My Pro Slot 4002 X12 RetroPro motors draw between 2.8 to 4.3 amps (no idea why there is such a discrepancy as they go the same speed...) at 3 volts.
A TSRF T3215 home-racing motor draws 1/2 amp at 6 volts.
#4 gotboostedvr6
  • 2,321 posts
Posted 28 January 2012 - 12:21 PM
My F5b Hotliner motor draws 300 amps at 22 volts and climbs out of sight in 4 seconds. :)
David Parrotta
#5 James Wendel
James Wendel
  • 1,030 posts
Posted 28 January 2012 - 04:42 PM
Wow... a motorized swimming pool.
Doesn't it, like slosh over, when you go around corners? :huh:
#6 James Grandi
James Grandi
  • 473 posts
Posted 28 January 2012 - 04:52 PM
My .560 16D arms draw 1.3-1.8 Amps at 5 volts, my .560 S16D arms draw 1.5-2 amps at 5 volts
James Grandi
obSCEne Chassis
HVR BB Fronts
Bodies by Weaver
#7 Guy Spaulding
Guy Spaulding
    Unintentional Instigator
  • 1,922 posts
Posted 28 January 2012 - 05:34 PM
Typically, if any slot car motor draws more than 5 Amps at 5 Volts under no-load conditions, there's something wrong. Even my G7 motors from the '80s drew no more than 4.5 Amps.
But you want to go overkill with the power supply you choose. I recommend a capacity of 7-10 Amps.
A cheap way to go is an old PC power supply. It may not be variable, but you often have outputs of 3V, 5V, & 12V, with adequate amperage from each output.
#8 Horsepower
Horsepower
    **Numb Thumbs**
  • 4,343 posts
Posted 28 January 2012 - 05:47 PM
:laugh2: :laugh2: :laugh2:
Gary Stelter
#9 Dan Ruddock
Dan Ruddock
  • 356 posts
Posted 28 January 2012 - 06:31 PM
I put a amp clamp on the white wire as a G7 was making laps and the average draw was twenty amps.
Dan
Dan Ruddock
#10 JoshFink
JoshFink
  • 2 posts
Posted 28 January 2012 - 07:45 PM
Great... Thanks for all the replies...
Just to answer the above question, I'm interested in typical C-can or D-can motor as used in 1/24 commercial raceways?
Josh Fink
#11 Cheater
  • 25,756 posts
Posted 28 January 2012 - 07:52 PM
At least 5 amps IMO.
#12 Hworth08
Hworth08
  • 3,563 posts
Posted 28 January 2012 - 09:32 PM
Philippe,
I'd be leary of swimming while the swimming pool motor is running. 220 volts won't hurt a thing, 20 amps will roast your bones.
It would be best to move the motor to a location OUT of the pool.
Don Hollingsworth
11/6/54-2/13/18
#13 Guy Spaulding
Guy Spaulding
  • 1,922 posts
Posted 28 January 2012 - 10:03 PM
But if your pool was filled with distilled water, it wouldnt hurt a thing.
#14 Phil Irvin
Phil Irvin
  • 1,764 posts
Posted 28 January 2012 - 11:59 PM
Add ceramic media and you will be polished when you get out...
OLPHRT
PHIL I.
#15 Guy Spaulding
Guy Spaulding
  • 1,922 posts
Posted 29 January 2012 - 07:58 AM
Drat! I meant to pick up some of that for my new tumbler while I was out yesterday. Does Hobby Lobby carry it?
#16 DOCinCanton
DOCinCanton
  • 2,887 posts
Posted 29 January 2012 - 10:20 AM
As you can imagine, the amp draw is all over the place. And what is a typical motor?
At 6 volts, no load on the motor, a Falcon 7, Hawk 7, and TSR draw about 0.3 to 0.6 amps. My Pro Slot PDs draw from 2.5 to 4.5 amps. My Pro Slot S16Ds which I race in Florida's My Series races draw about 4.5 to 6.0 amps.
Doc Dougherty
#17 Hworth08
Hworth08
  • 3,563 posts
Posted 29 January 2012 - 10:38 AM
I never got what I considered good results from amp draw. In therory the more amps, the more current, the more power. But.
At some point how efficient a motor is probably has an effect. A Super 16C pulls about four amps, a Falcon 7 about one, but a Super 16 is only a little faster on the track.
Don Hollingsworth
11/6/54-2/13/18
#18 Phil Irvin
Phil Irvin
  • 1,764 posts
Posted 30 January 2012 - 06:27 PM
GUY,
I got mine from www.riogrande.com jewlery supply from Albequerque New Mexico, Ordered it about 5:30 PM Florida time.. Went out the next day. Got it 2 days later.. They have it from Kinda Course to Super Fine. I asked for what would work on medium soft brass the best and got it. I don't remember which one it was and the box is long gone..Also got .007 thick Dremil type discs. Just a little too thin.. :dash2:
OLPHRT
PHIL I
