First Fiddlestick adventure
Posted 17 February 2012 - 07:09 PM
So, I tested springs on a S16C I recently built, and both sides measure about 1.3
My question is, is that all there is to it ? Or are there some tricks ?
Thanks !
Posted 17 February 2012 - 07:32 PM
Posted 17 February 2012 - 07:43 PM
IIRC, you had to push it a fairly precise angle off of the spring hook.
Maybe the spring hooks are shaped a little more optimum than they were back then.
I quickly realized I was spending too much time obsessing over something I didn't feel
I was getting accurate results with and quit using it almost immediately.
I just put my springs on stock and ran them that way my whole Pro career.
The only time I deviated was at the 90 Nat's in the Pro Main.
I had Stu grab a motor I had already used and told him to reduce the tension because the power seemed real low.
After he did it, I put the motor back in, and while I'm not sure it ran any better, it ran well enough for me to win the race.
Posted 17 February 2012 - 07:44 PM
Posted 17 February 2012 - 08:01 PM
Mike Swiss, my Fiddlestick is an old brass one sold to me by John Thorp in the early 70's. I've not experienced the problems you stated. I usually bend my own spring hooks as shown by Messrs. Boyington & Labree. Maybe the newer Fiddlesticks are manufactured differently by Sonic.
Posted 17 February 2012 - 08:39 PM
Yeah, I knew I was in trouble when I took it apart and looked at the spring with a microscope
and it had a tiny "666" engraved on the end of the coil.
Posted 18 February 2012 - 02:33 AM
I believe the fiddelstick has been discontinued by Sonic.
Mike Boemker
Posted 18 February 2012 - 07:21 AM
Mike, I noticed Sonic's advertising banner just happen to be at the top of this page when I was reading this thread, so I clicked on it. Yes, indeed, they still make fiddlesticks.
"You want it when?"
Posted 18 February 2012 - 10:15 AM
I bought a new fiddle stick 5 or 6ys ago, and only used it a couple times. I use Champ lights most of the time, and find they are usually very close right out of the bag. I also have had simular results with the newer Proslots.
Vic
Posted 18 February 2012 - 11:01 AM
Posted 18 February 2012 - 11:06 AM
Posted 18 February 2012 - 11:48 AM
I tried to order a Fiddlestick from my main dist., Eagle, and was told they are disc.I noticed Sonic's advertising banner just happen to be at the top of this page when I was reading this thread, so I clicked on it. Yes, indeed, they still make fiddlesticks.
I have a feeling the Sonic website is not up to date.
Posted 18 February 2012 - 11:51 AM
#50-1 The Fiddlestick $17.50 / ea. *DISCONTINUED – LIMITED TO STOCK ON HAND
Posted 18 February 2012 - 11:56 AM
Just the opposite is usually the case, they get faster.
#15
Posted 18 February 2012 - 12:02 PM
#16
Posted 18 February 2012 - 12:07 PM
Could be a "must have" tool for someone who quickly assembles a lot of motors without care, as a final check.
Posted 18 February 2012 - 11:18 PM
May be worth looking into further.
