Motor install, soldering tips
Posted 23 March 2012 - 12:58 PM
Thanks, and any other tips for motor install, soldering, etc. would be more than willing to pick up. I am just getting back in after many years out of it, as we just had a new track open up here with some of the old guys I used to race with!!
Travis
Posted 23 March 2012 - 01:06 PM
To remove motor, while heating the joints, pry using an old Xacto knife. A little at a time is called for when you have it soldered in 3 places. Just keep heating joints and prying and it will come out.
Then take your Soder-Wick and press it against the unwanted solder blobs, and push like a scraping motion.
Lots of guys use used, old braid to do this.
Posted 23 March 2012 - 01:10 PM
John Warren
Posted 23 March 2012 - 01:16 PM
Posted 23 March 2012 - 01:18 PM
Use inertia.
Hold the car about 8" up in the air. Melt one joint. Then swing the chassis down like you're gonna hit the table, but stop just short, reversing the direction. Much of the molten solder will continue in the downward direction, and splatter on the table. You can also do this over a trash can to catch the solder. A little solder will remain. That's OK. If your motor is soldered in 3 places, repeat the previous step with the 2nd joint. Then use Pablos method on the last joint to finish removing the motor
Posted 23 March 2012 - 01:26 PM
I bet that really makes the track owner happy.I heat the solder up real good and then while holding the chassi tightly, quickly sling your arm towards the floor and stop quickly, It will sling the solder to the floor. Repeat for each solder joint.
Posted 23 March 2012 - 01:33 PM
Posted 23 March 2012 - 01:45 PM
Seems like the heat and sling method over the table seems the easiest, then wick it away after to clean up for install. Thanks!!
Travis
Posted 23 March 2012 - 02:33 PM
Good Luck.
P.S Lots of practice helps
Posted 23 March 2012 - 08:53 PM
Posted 23 March 2012 - 09:14 PM
I never solder the motor directly to the chassis in more than one location. I use a small piece of 3/32" brass tubing on the back of the motor, soldered to the chassis and the motor. Then I solder the motor to the top of the motor bracket. To remove the motor, heat up the tubing, and get it out of the way using whatever method you are comfortable with. Then unsolder the can from the bracket. This worked for me when I raced flexis.
One of the best methods I ever found!
Posted 23 March 2012 - 09:24 PM
Sounds, great. But now alowed by most USRA rules.
"now" or "not"???
The statement is unclear
Posted 23 March 2012 - 09:50 PM
Posted 23 March 2012 - 10:18 PM
"now" or "not"???
Woops....Finger slip
NOT
I'd like to be allowed to run my "superbrace" too
#15
Posted 23 March 2012 - 10:19 PM
#16
Posted 24 March 2012 - 05:16 AM
Buzz-A-Rama forever in our hearts
RIP... Buzzy and Dolores
#17
Posted 24 March 2012 - 05:49 AM
That's how I do it!
TIP: Make sure your wearing shoes, hot solder on top of your feet is bad !
Support your local track and keep the sport alive!
#18
Posted 25 March 2012 - 08:39 PM
Here is a photo of my mounting method:
This is in a Turbo-Flex chassis. The tubing bridges the gap between the motor can and the chassis. Also notice the solder joint along the top of the bracket.
#19
Posted 25 March 2012 - 09:40 PM
#20
Posted 26 March 2012 - 06:21 AM
and I also run some piano wire from motor mount tab
to the oil lite to stop the pinion and spur being forced apart.
#21
Posted 26 March 2012 - 08:27 AM
#22
Posted 26 March 2012 - 04:52 PM
Dave, what classes are you running the Flexi 1(Flex Kar) in? I have a couple, but recently I have seen a bunch of new ones on ebay. Your idea of bracing the motor mount plate to the left rear upright is a good one on this particular chassis. I bought one of the Slick 7 steel motor braces but have not used it because I like the 3/32 tube arrangement better.
3/32 tube works well and is easier to install/remove, I did find the Slick 7 one a bit fiddly to use but works well.
My local track runs ute racing (with 5sec break out rule), having been out of racing for about 16yrs this
and "Retro's" was a great fun way to get my driving up to speed!
#23
Posted 26 March 2012 - 06:31 PM
When I tried the Kelly/Speed FX two piece chassis, I used the tubing at the front and rear and tacked the top of the motor to the bracket. Again, very easy to get the motor out without putting a lot of heat on the can.
#25
Posted 20 July 2012 - 08:24 PM
Toadsucker Racing
