My first 3D attempt - the Neckcheese NWP2 chassis :-)
15 replies to this topic
#1 n.elmholt
n.elmholt
  • 1,115 posts
Posted 02 July 2012 - 11:38 AM
Since The German White Point company stopped producing their simple, but popular chassis, I have been making a small production of a carbon- and grp-reinforced resin chassis to keep the Danish WP CanAm class alive
Now it was time for something new:
So I made a new chassis in 3D and ordered it at an online rapid Prototyping company
I will receive the first prototype in 14 days, but you can follow the story on my new blog:
Niels, DK
Niels Elmholt Christensen, DK
Former Neckcheese Racing
#2 n.elmholt
n.elmholt
  • 1,115 posts
Posted 16 July 2012 - 12:30 PM
Received the first chassis today - apart from the motor holes need to be moved a bit upwards the result was perfect.
The material is very tough and seems perfect for this job. The surface is a bit rough, but not a problem in any way.
Holes are for 6mm bearings and the chassis is designed for the 18V 18D motors, like the Black Carrera and Plafit Bison. Basic measurements are the same as the original White Point chassis apart from the fixed WB and WP body mounts fits the chassis.
I moved the parts from one of my WP CanAm cars and all fitted perfect. With 23,5mm dia wheels the clearance is 1,5-2mm. It's designed for a low cut guide and has built in guide stops.
Also the body fitted perfectly:
The chassis is available from Shapeways: http://www.shapeways...r-wp-canam.html
Now for some intensive testing :-)
Niels, DK
#3 n.elmholt
n.elmholt
  • 1,115 posts
Posted 25 July 2012 - 09:21 PM
First on-track test of the new chassis went well - it has roughly the same characteristics as the resin chassis (with the same body/weight) - and that is not bad :-)
Looks promising - now I look forward to receive the 100mm wb chassis and the inserts for the variable wb's :-)
Niels, Dk
#4 n.elmholt
n.elmholt
  • 1,115 posts
Posted 03 August 2012 - 08:15 PM
This is really habit-forming and the possibilities are endless.......
look here for more info:
http://neckcheese.bl...-now-in-3d.html
http://neckcheese.bl...r-variable.html
http://neckcheese.bl...p2-chassis.html
Niels
#5 n.elmholt
n.elmholt
  • 1,115 posts
Posted 21 August 2012 - 09:37 PM
The variable wheelbase replacement chassis for White point cars is now available on Shapeways: Shapeways Shop
The front and rear is available as separate parts. There is two fronts - a "normal" one and one for very short nosed cars.
The parts have holes and slot and can be assembled with 2mm screws and nuts. Guide stop and motor wire holders are integrated in the design.
Wheelbase can be varied between 92-115mm without modification, but down to 80mm is possible with some shortening of the parts.
Recommended parts are 3mm axles/6mm bearings, 18D type motor (Black Carrera, Plafit Bison), low cut guide, min. 23,5mm wheel diam.
Guide stop - also shown behind is the holes for motor lead wires.
These are the 3 chassis currently available
Niels, DK
  • Big Durl likes this
#6 John Miller
John Miller
    This space for rent
  • 1,150 posts
Posted 21 August 2012 - 10:03 PM
Very cool.
#7 Tim Neja
  • 6,846 posts
Posted 22 August 2012 - 12:22 PM
Very nice--- a boon for the 1/32 crowd too!
#8 n.elmholt
n.elmholt
  • 1,115 posts
Posted 30 August 2012 - 06:33 PM
tested the long wheelbase chassis with a ferrari 350 CanAm body tonight and came within 1/10 of my track record with this "out-of-the-box" car :-) - great!!!
Added weight in front of the chassis and two brass strips on the side grp wings
Niels, DK
#9 tossedman
tossedman
  • 97 posts
Posted 30 August 2012 - 09:00 PM
That's cool Niels, what software did you use to design the chassis? What format did you have to send it to Shapeways in?
Todd
Todd Austman
#10 n.elmholt
n.elmholt
  • 1,115 posts
Posted 31 August 2012 - 04:05 AM
Todd,
I use the rather simple software from www.emachineshop.com and export it in .stl format.
It has its limitations, but is ok for my limited brain capacity and the simplicity of the chassis design :-)
Niels
#11 Slotmanmoss
Slotmanmoss
  • 54 posts
Posted 21 September 2012 - 06:46 PM
Niels,
Is the Black Carrera motor the same size as the current carrera 1/24th motors?
Have you done anything yet on the 13D motor chassis?
Are your body mounting tabs threaded or is there a nut on the fasten to the top to hold them on the chassis?
Thanks,
Alan
Alan E. Moss
#12 n.elmholt
n.elmholt
  • 1,115 posts
Posted 21 September 2012 - 08:06 PM
Hi Alan,
If you choose the 1:24 motors, It looks so and from the specifications they are VERY close relatives and should fit in the chassis :-)
http://www.electricd...18v-p-3974.html
Even they are big and heavy, I like these motor as they are very very similar in performance and they can go for hour and hours. I have had motors that I used a full race season + a 10 hours race without any loss of performance.
Re the 13D, I havent got time yet, but the project is not forgotten, and hopefully next week, i'll have some time to do it.
The body mounts are made in 1,5 grp plate and i tread the holes. The grp is very dense and strong enought for this purpose. Another option is to drill a 4,5mm hole and press and glue the nut into the plate.
I have made some changes to the chassis to reduce material in order to reduce price as they are calculated per cm³ - i have received the test shots and i'm happy with them.
I also received 8 NWP2-962 chassis that will be used for club and rental car in our club. I am currently waiting for my delayed order for bodies from Truescale :-(
Niels, DK
#13 Slotmanmoss
Slotmanmoss
  • 54 posts
Posted 11 October 2012 - 05:14 PM
Neils;
Reference your post above, Have the changes to chassis to reduce materials been made and in your shop? I am getting ready to order a couple of them and want the latest version. Also, am still extremely interested in the 13D version as (we tend to run 12v vs 20 over here) when it comes out. Will use the current adjustable chassis with big carrera motor to set up a Ferrari 458 using model kit to run against my other 1/24th carrera's.
Thanks,
Alan
Alan E. Moss
#14 n.elmholt
n.elmholt
  • 1,115 posts
Posted 11 October 2012 - 05:59 PM
Alan,
the chassis on Shapeways are the latest weight/money saving versions :-)
- just drove one of them today in preparation for sundays' 4th and last round of the Danish CanAm Championship and it worked superbly :-)
The 13D chassis has been delayed due to multiple factors, but I will try to do something about it in a few days :-)
Niels, DK
#15 n.elmholt
n.elmholt
  • 1,115 posts
Posted 08 November 2012 - 09:55 PM
The feedbacks on the new chassis has been extremely positive and my team Nechcheese Racing will be using one of these below this nice Howmet TX (from HowmetTX) for a 6-hours WP race on Nov. 18th
The body has been used for a similar race before, but are nice enough for one more outing :-)
Body: HowmetTX from John Dillworth AKA HowmetTX
Decals: home made
Silver: bare metal foil
Chassis: NWP2 3D-printed chassis from Shapeways with 18v Black carrera motor and foam tires
Niels, DK
#16 n.elmholt
n.elmholt
  • 1,115 posts
Posted 06 February 2013 - 07:41 PM
Latest version has some inprovements added - here is the first prototype print from Shapeways:
The latest version has body mounting wings integrated in the design - just cut off and use. Also the rear end has been strengthened with upper cross bar.
The mounting holes are now countersounk which allows the screw head to lay flush with the surface.
Add a little superglue to the hole, position the 2mm nut and press
http://www.shapeways...hops/neckcheese
