Adjusting voltage on power supply?
Posted 09 July 2012 - 11:44 AM
Right now the voltage measured at the braid is 14.7 volts.
What does the voltage setting in SRT program change?
Thank You!
Slots-4-Ever
Brian McPherson
REM Raceway
Posted 09 July 2012 - 11:56 AM
Best to allow someone that is familiar with the inside of a switcher to do the adjusting, they can kill you...
Rick Bennardo
"Professional Tinkerer"
scrgeo@comcast.net
R-Geo Products
Lead! The easy equalizer...
Posted 09 July 2012 - 12:04 PM
In reviewing the Rivergate website, there not even listing a RDC-70 so I'm guessing it's an older unit?
So the SRT portion doesn't change any voltage unless your jumping these wires inside the unit itself??
Thanks
Slots-4-Ever
Brian McPherson
REM Raceway
Posted 09 July 2012 - 12:22 PM
Does your old unit have a little metal thing on the back attached with 2 screws? If it does, loosen the screws, take the tab off of one and then screw back down. It should drop the voltage?
Most units have a pot close to the final that you can adjust. Probably need an insulated screwdriver to get in there to it.
Is this a new addition? the last time I raced at REM the power was not near that high?
Rick Bennardo
scrgeo@comcast.net
R-Geo Products
Posted 09 July 2012 - 12:40 PM
Has nothing to do with REM power! That's all good!
It's for my friend that has an oval track, and they have been burning up motors left and right, and I finally got them to check there Voltage, and this is the result.
Slots-4-Ever
Brian McPherson
REM Raceway
Posted 09 July 2012 - 12:57 PM
Ever want to run low voltage caution laps????
racing around Chicago-land
Posted 09 July 2012 - 01:06 PM
Can this be done with one trim pot? Or one for each lane??
Sorta like a rheostat? Connected after voltage output from power supply?
Thank You
Slots-4-Ever
Brian McPherson
REM Raceway
Posted 09 July 2012 - 01:20 PM
11/6/54-2/13/18
Posted 09 July 2012 - 04:20 PM
Barney Poynor
12/26/51-1/31/22
Posted 09 July 2012 - 04:39 PM
It works just fine and dandy,just need to lower it a bit to get more reliabilty to the motors and drivability to the cars.
How would you go about hooking up an external??
Newbiew here! so keep that in mind!
Slots-4-Ever
Brian McPherson
REM Raceway
Posted 09 July 2012 - 08:56 PM
Barney Poynor
12/26/51-1/31/22
Posted 09 July 2012 - 09:55 PM
11/6/54-2/13/18
Posted 10 July 2012 - 06:18 AM
It's thru the right hand fan for the potentiometer pot.
Still curious though as to what is actually being changed when using the SRT program? OR, nothing is changed unless its wired for it?
Thank you All!
Slots-4-Ever
Brian McPherson
REM Raceway
Posted 10 July 2012 - 11:04 AM
Rick Bennardo
scrgeo@comcast.net
R-Geo Products
#15
Posted 12 July 2012 - 11:10 AM
#16
Posted 12 July 2012 - 11:16 AM
Using the Bulldog internal pot is another separate modification that can be done.
