UHP Toronado drive system
Posted 03 August 2012 - 03:32 PM
After looking at some stuff on the net I realized it's actually a UHP factory made car Anyway, since no wheels or axles are present can someone show a closeup of the front " differential " as they called it. I will try to duplicate it if possible. Thanks
Joe Lupo
Posted 03 August 2012 - 06:30 PM
PS: can't seem to get a link up, will try again...
Look at the end of this thread:
http://slotblog.net/..._+uhp +toronado
The image icon still isn't responding...
Posted 04 August 2012 - 07:53 AM
Posted 04 August 2012 - 08:06 AM
1. Do all those parts go just as they are laid out? For some reason in my mind I pictured the parts would be next to the crown.
2. Is it only on the left front or both sides?
3. On the right front, the hub extends out of the back of the tire. Is this the actual wheel or something else or the washers and junk like the left side.
4. Do you know if this had AMT tires all around? If so, are they marked AMT ( rarer version ) or just DM ?
5. Knock offs on front only ?
Thanks for your time.
Joe Lupo
Posted 04 August 2012 - 09:48 AM
Glad to help - this is such an odd car, but very fascinating! Mine seemed to be new when I got it, but without the box, so am not sure if all were original parts.
Yes, as shown: nut next to the plastic bearing, then the fairly thick aluminum disk, about 1/16" I'd say, then the wheel, which is plain, not threaded, then the spring, washer and knock-off. The wheel is held by pressure between the disk and the spring, which is what I guess gives it that "limited slip differential"!
Both sides
That's the thick aluminum disk.
Can't read for sure, but it seems to be marked AMT on one set and Buzco on the other - I don't know if these were the original tires. Car came like this.
No, seem to be for both front and rear, but I had removed the rear knock-offs for some reason.
Posted 10 August 2012 - 01:56 AM
Posted 09 May 2014 - 12:49 PM
Just looking around for info on differentials and found this, the original patent for the above system as filed in early 1966 by William T Donofrio.
http://www.google.co...tents/US3304652
Interesting in that it shows a different chassis from the back-to-front AMT used by UHP - all the other bits appear similar though.
Nice big drawings if you click on "original image", a good write up on the thinking behind it also.
Posted 09 May 2014 - 04:55 PM
Thanks GB, excellent find.
In fact, the chassis in the patent looks a lot like a Rannalli, with the long drop arm... Maybe the inventor tested his idea on that, and then got a deal on a bunch of AMT chassis!
Posted 01 February 2015 - 05:28 PM
Seem inconsistent that so much effort was made to create front wheels that spun at different speeds and no effort was made to make independently rotating rear wheels. Essentially the faster spinning inner wheel will force the outside wheel to slip, causing fishtailing which is a known problem with these chassis.
Posted 02 February 2015 - 09:46 PM
Yep, good point Gary - a bit of weight and grip at the back to help keep things in line also perhaps.
i'd love to play with one of these - any chance you could put yours in your box for our next night out ?
Posted 03 February 2015 - 03:32 AM
I was just making some new friction discs for the front, and new tires, freshened up the rear, didn't make them freewheeling though. I hope to bring it out soon to see how it compares to the AMT hardbody originals.
Posted 07 September 2016 - 07:53 PM
HotRodBob
Anyone can restore a classic car, but it takes a true Hot Rodder to cut one up and make it cool
Bob Beck Motorsports Announcing
Posted 08 September 2016 - 06:36 AM
Great stuff Bob. do you remember how it ran?
Also, how is your body attached? Mine has aluminum angle brackets attached to the chassis, with the body rather crudely screwed into those... figured it was factory, but now I have some doubts.
Posted 12 September 2016 - 02:26 AM
Sounds like the factory body mount to me. After I made new tires and new friction discs the UHP kept up with the AMT version. I cut the new discs out of the same foam that I use for tires.
