Photobucket problems
17 replies to this topic
#1 Cheater
  • 25,825 posts
Posted 27 December 2012 - 03:36 AM
I've received serveral PMs about problems that have cropped up recently in posting links to images stored at Photobucket and got a little time early this morning to do some testing. Here's what I think is occurring.
When you go to your Photobucket library to grab a link to a picture stored there to post at Slotblog, you should see this little control panel.
You click on the code line for the "IMG code" and that code is copied to your computer's hidden clipboard. Then you "paste" that copied code into a post text block at Slotblog.
Sometimes what gets pasted there is parsed incorrectly by IP.Board's editor and that seems to be the problem.
What should be pasted there is a link to your stored image enclosed by an {IMG} tag and followed by a {/IMG}. Sometimes your pasted link gets parsed into a format that will generate the error folks are seeing.
This is the correct format (with curly brackets substituted for square brackets throughout this post so the code won't activate; the correct code format uses square brackets, like this: [ ]):
{IMG}link-to-image{/IMG}
If your pasted link appears in this format:
{img=link-to-image}
It will probably generate the "You are not allowed to use that image extension on this community" and you will need to edit the line to have a leading {IMG} tage and a closing {/IMG} tag.
In my testing, it doesn't happen all the time and I haven't been able to determine a pattern.
IPS is having some issues with the text editor in the new IP.Board version and I believe that's the root cause of this problem. They have been issuing patches every day or so (I actually installed an updated patch about 30 mins ago) and I feel this problem will eventually go away.
#2 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,694 posts
Posted 27 December 2012 - 04:27 AM
Test to see what happens.
This code line had the square brackets as cut/pasted from PhotoBucket.
[IMG]http://img.photobuck...10-12a.jpg[/IMG]
edit
Nope, didn't work and I got that error msg the first time, but the "Post" button still appeared and still returned the error trying it a second time.
Swapped the square brackets for curlys to show code line trying to add.
:huh:
Steve King
#3 Cheater
  • 25,825 posts
Posted 27 December 2012 - 04:33 AM
#4 Cheater
  • 25,825 posts
Posted 27 December 2012 - 04:35 AM
Steve,
I was able to post your image in the previous post by simply copying the image link from your post (while in edit mode) and formatting the link as above.
Maserati 250F, is it?
#5 don.siegel
  • 5,895 posts
Posted 27 December 2012 - 11:52 AM
Greg,
I haven't been having any problems with Photobucket, but I've always used the "direct link" line and that works. Is there any advantage to using the img code?
#6 Noose
Noose
  • 23,349 posts
Posted 27 December 2012 - 12:06 PM
Just testing
#7 Noose
Noose
  • 23,349 posts
Posted 27 December 2012 - 12:07 PM
OK, now what I saw when I just copied the img link and pasted it here was the following message:
You are not allowed to use that image extension on this community.
BUT... it still posted.
#8 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,694 posts
Posted 27 December 2012 - 03:51 PM
Testing again.
Hitting Ctrl F5 before entering.
Using the "IMG Code" with square brackets.
{IMG}http://img.photobuck...0-12b.jpg{/IMG}
Using Don's "Direct Link" method.
http://img.photobuck.../tr2010-12c.jpg
edit 1.
Didn't work.
Square brackets swapped for curlys.
edit 2.
Using "Direct Link" doesn't show the image in the post, but does link to it.
Don, when you use the Direct Link, do you just cut/paste it into the post?
Steve King
#9 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,694 posts
Posted 27 December 2012 - 04:13 PM
That's what I'm getting when I post to a forum thread, but it won't post for me.
Dumb thing is, when I post in the messenger, it works fine.
:huh:
Steve King
#10 don.siegel
  • 5,895 posts
Posted 27 December 2012 - 04:34 PM
Steve,
No, I still click on the image icon in the reply field (middle of bottom line) and paste it in there....
Hmm, let me try here:
#11 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,694 posts
Posted 27 December 2012 - 04:41 PM
Hmmm, that's another problem for me.  Thought that's what you might do.
When I click on that icon, my screen grays out, and I don't get anywhere to enter the link.
Steve King
#12 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,694 posts
Posted 27 December 2012 - 04:45 PM
Sorry Greg, I missed your question.
Yes 250F, taken at Eastern Creek, Sydney during 'Tasman Revival' meeting.
Steve King
#13 Cheater
  • 25,825 posts
Posted 28 December 2012 - 06:37 AM
Steve,
Try posting another Photobucket image. IPS tested this and didn't have a problem.
And pasting the Photobucket image code is working for me now as well. See above.
#14 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,694 posts
Posted 28 December 2012 - 07:38 AM
OK, giving this one another go.
Steve King
#15 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,694 posts
Posted 28 December 2012 - 07:41 AM
Hip ray... hip ray... it works.
Here's the other one for good luck.
Thanks, Greg.
Steve King
#16 Cheater
  • 25,825 posts
Posted 28 December 2012 - 07:55 AM
You're welcome, Steve.
#17 don.siegel
  • 5,895 posts
Posted 28 December 2012 - 08:19 AM
... and thanks for the very sexy Maserati pictures, Steve!
#18 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,694 posts
Posted 28 December 2012 - 04:34 PM
Don, you're welcome.
That thing sounded awesome idling to the dummy grid, then the hairs on the back of my neck stood when it went down the main straight under full steam.
:wub:
Last one for good measure.
Steve King
