TSP1 guide
5 replies to this topic
#1 Slot_it_Bob
Slot_it_Bob
  • 23 posts
Posted 25 February 2013 - 12:13 PM
PDL I ordered a couple of your guides and decided to retrofit on into one of my Slot.it GT1's which is a new release.
I noted that even on this car the guide wobbled 360 degrees.
I followed the instructions on your website and about 20 minutes later I now have the smoothest play free guide I have ever seen a plastic car.
I did use a thinner 3 mm washer and I am looking to replace the provided 6-32 nut with a more compact unit to fit under some cars.
I wish I had bought some of these sooner.
Thanks,
Bob
Bob Belluomini
#2 gascarnut
gascarnut
  • 3,938 posts
Posted 25 February 2013 - 12:26 PM
Bob, you can also cut off the extra post that protrudes above the brass tube and use a 2-56 screw and washer:
Dennis Samson
Scratchbuilding is life
Life is scratchbuilt
Samson Classics
#3 TSR
Posted 25 February 2013 - 02:29 PM
The TSP1 is a very versatile guide and can be used on many different slot cars in various scales. It is also very strong.
#4 Slot_it_Bob
Slot_it_Bob
  • 23 posts
Posted 25 February 2013 - 02:55 PM
Dennis I thought about that too. I was not sure if a screw would expand the post enough to cause a bind.
I'll be doing a second car and I plan to trim the front of the guide back so I can leave the front of the chassis in place.
BTW I just read an article by you on the retro racing site regarding scratch building, beautiful work.
Bob Belluomini
#5 gascarnut
gascarnut
  • 3,938 posts
Posted 25 February 2013 - 02:59 PM
If you run a 2-56 tap into the hole in the guide post first, it will not expand much.
You could try a 2mm screw and washer if you can find them, they are a tiny bit smaller.
And thanks for the compliment - if you're talking about the article on the IRRA website, that's pretty old now. My frames look way better these days.
Dennis Samson
Samson Classics
#6 Slot_it_Bob
Slot_it_Bob
  • 23 posts
Posted 25 February 2013 - 07:59 PM
Everything you could ever want in fasteners
http://www.microfasteners.com/
Bob Belluomini
