2nd NY Car Model 1968-04
10 replies to this topic
#1 Steve Okeefe
Steve Okeefe
  • 1,139 posts
Posted 28 February 2013 - 11:01 AM
2nd New York Car Model
April 27, 1968 - Hamilton Raceway, Brooklyn, N.Y.
The Anglewinder Revolution sweeps across the country in seven days
Car Model Race Report
"The start of the hot consy looks like a lineup of the coolest cats in the world."
Period-correct anglewinder F1 - Chassis by Rick Thigpen
Steve Okeefe
#2 Paul Jurczyszyn
Paul Jurczyszyn
  • 632 posts
Posted 21 November 2013 - 01:10 PM
Steve,
Any drawings for this car?
Paul
Humble student of the master slotters
#3 Steve Okeefe
Steve Okeefe
  • 1,139 posts
Posted 21 November 2013 - 06:07 PM
Paul,
No, not for the Sandy Gross Anglewinder F1, because I've never had the chassis in my hands to measure it.
Rick Thigpen was kind enough to put his anglewinder F1 chassis in my hands, so here's a drawing of it:
Wanting to design my own version, I worked out this drawing:
1968 Car Model rules did not anticpate the anglewinder drive, so there are no rules specifically addressing how the motor or gears must fit under the body in an anglewinder F1.  Body manufacturers did not anticpate anglewinder drive either, so F1 bodies were generally no wider than about 1-3/8".  They could be "stretched" to about 1-1/2" wide, but that's pretty much the limit.
Normally, an anglewinder motorbox is something like 1-5/8" wide, no problem in a sports car or coupe, but BIG problem in a F1.  Add to that the new (for then) plumber style F1 body mount, consisting of one additional 1/16" piano wire rail on each side, and now the chassis could be as much as 1-3/4" wide (depending on how you build it).  Clearly this isn't going to work: The whole chassis should be no wider than 1-1/2" including everything.
The designs of all the anglewinder drive cars in this May, 1968 race reflect this, and since you've read the race report, you're fully aware this is definitely a "pro" build.  Note the can must be shortened to .800" long to make everything fit.  In stock form, the Mabuchi FT-16D can is approximately .965" long, so it must be shortened by about .165" (just over 5/32").  This means you're going to have problems with both stock magnet and stock armature length.
In this design, the rail configuration around the motorbox is very important, but in the above drawing it is concealed by other parts (a pet peeve of mine regarding magazine chassis drawings of the period), so here's a detail drawing with the motor, bracket brace and waist strap removed.  Note the chassis, including everything, is 1-1/2" wide:
Have fun building this one... ;)
Steve Okeefe
#4 Pablo
  • 18,495 posts
Posted 21 November 2013 - 07:16 PM
Paul can do it, no problemo. :)
#5 NY Nick
NY Nick
  • 1,051 posts
Posted 21 November 2013 - 07:48 PM
Thanks for posting
Nick Cerulli
#6 SlotStox#53
  • 4,084 posts
Posted 21 November 2013 - 07:55 PM
Nice plan for a build, have you built one for yourself yet Steve?
#7 Paul Jurczyszyn
Paul Jurczyszyn
  • 632 posts
Posted 21 November 2013 - 08:07 PM
Got a nice truescale Honda for it.
Paul J
Thanks for posting the plans.
#8 loudspeaker
loudspeaker
  • 181 posts
Posted 23 November 2013 - 06:38 PM
Hi, As I recall this was a fun race on a very fast track that was basically straightaways and steeply banked turns. My car was very fast and, as I recall, had a Thorp armature. I believe I took this chassis and modified it to become a sports car. Sandy
Sandy Gross
#9 SlotStox#53
  • 4,084 posts
Posted 23 November 2013 - 07:05 PM
Hi Sandy :D Sounds like a really fast car you had , sure looks a sweet F1 in the magazine pictures :good: Do you still have the car?
#10 slotcarone
  • 4,031 posts
Posted 24 November 2013 - 09:27 AM
:) In the hot consi picture notice Greenaway with the famous cigar hanging in his mouth!! Looks like Von Ahrons sitting down yawning. Great picture!!
#11 Uncle Fred
Uncle Fred
  • 1,368 posts
Posted 06 December 2013 - 05:42 PM
I went to this race but had to leave early and did not run. Sandy's car was the first anglewinder I ever saw, we could not believe that you could angle the gears like that........
Fred Correnti
