Re: Braiding track - how to apply glue?
11 replies to this topic
#1 David Rees
David Rees
  • 114 posts
Posted 30 March 2013 - 12:50 AM
When re braiding a track what is the best way to apply the contact adhesive to the braid and to the track reccess  ?
#2 Rick
Rick
  • 8,844 posts
Posted 30 March 2013 - 01:15 AM
Well David, I used to use a sqeeze ketchup bottle with an angled slice on the end to apply the glue in the channel and then use a roller on the braid laid out on craft paper on two or three tables..............If you try to use the braid wound around a bucket or something, if you are not careful, it will kink when you stop and you have to be careful to removed the kink when you lay the braid down......................
  • David Rees likes this
Rick Bennardo
"Professional Tinkerer"
scrgeo@comcast.net
R-Geo Products
Lead! The easy equalizer...
#3 Zippity
Zippity
  • 5,278 posts
Posted 30 March 2013 - 04:29 AM
Better still, forget using Elephant snot and use 3M Transfer Tape instead :)
It is much easier and cleaner to apply.
Ron Thornton
#4 Chevpower454
Chevpower454
  • 26 posts
Posted 30 March 2013 - 07:20 AM
I agree with Zippity. Forget about the contact cement. Use the 2 sided tape. I used it on my wood oval with great results. No mess or fumes either. Just make sure the tape gets pushed down good. I think I used a screwdriver handle to rub the tape down.
Tim Hearne
#5 Paul Jurczyszyn
Paul Jurczyszyn
  • 632 posts
Posted 30 March 2013 - 07:37 AM
Transfer tape come up if you apply track spray glue. I used it on my trioval and it worked ok till I sprayed my traction glue down.
Ketchup bottle it the way to go trust me.
Paul
Humble student of the master slotters
#6 Zippity
Zippity
  • 5,278 posts
Posted 30 March 2013 - 09:48 AM
Paul
Paul,
You must have done something wrong when you laid the tape the first time :(
Transfer Tape is highly resistant to most thinners and glues. Or else you used the wrong tape.
The new braid has to be meticulously cleaned before being laid the first time to remove all traces of machine oil that it contains from its original manufacture stages.
Ron
Ron Thornton
#7 David Rees
David Rees
  • 114 posts
Posted 30 March 2013 - 07:13 PM
Re - transfer tap ?   If the track recess is in some places not 100% smooth wouldn't this cause a bonding problem ?
If so i am thinking the contact  adhesive would be better in this situation .
#8 Paul Jurczyszyn
Paul Jurczyszyn
  • 632 posts
Posted 30 March 2013 - 08:26 PM
All brade was clean and laid according to the directions, were lifting occurred was in ever turn. The straights held.
Paul
#9 Wizard Of Iz
Wizard Of Iz
    Slot Parrothead
  • 1,864 posts
Posted 30 March 2013 - 10:04 PM
Stay with Original Wellwood Contact Cement. Clean the braid with lacquer thinner.
We used a Glue-Bot to apply the glue. I'd post a picture if I wasn't on my iPhone
Rollin Isbell
#10 Paul Jurczyszyn
Paul Jurczyszyn
  • 632 posts
Posted 31 March 2013 - 09:04 AM
I agree.
#11 Wizard Of Iz
Wizard Of Iz
    Slot Parrothead
  • 1,864 posts
Posted 31 March 2013 - 11:02 AM
Make sure that the Weldwood is the original version, not the gel version.
Here's a picture of a glu-bot.  Very handy for putting down a nice bead of glue the exact width of the braid bed.
Rollin Isbell
#12 CruzinBob
CruzinBob
  • 1,549 posts
Posted 02 April 2013 - 12:20 PM
Here are some tips.
Slot Car Corner can help with their tools and how to articles.  http://www.slotcarcorner.com/ .
I learned to build mostly from Hasse Nilsson but Monty Ohren showed me quite alot also.  Thank you Monty and Bonnie and may you both be cradled in His arms :)
Here's a braid roller barrel constructed by Monty maybe 15+ years ago.  He gave it to me when he decided to give up track building and go full bore motor building.
Sometime in the 90's Monty made a glue applicator for applying contact cement to both sides of the slot.  At the same time it smoothed the glue creating an even flow.  He let me borrow it a few times and WOW!  He lent it to someone and never got it back - wasn't me!  A close racing buddy here made these for me about 3 months ago.  These are for 5/8" wide braid stance that I use mostly on 1/32 & 1/43 tracks.  Standard commercial is 3/4".
And here's a tool a 1:1 drag racing chassis builder in Chandler, AZ made for me in 1994.  It's worked on about 150 tracks ;)
Bob Scott
