Finished July 2013:
Here's where it all started:
Not sure what car I'll put this in yet.
I've been experimenting with ways to install BB's. The can was easy, a 5mm using a 5mm drill bit.
But these doggone Champion endbells I don't know what oddball bushing they were designed for, but they are a challenge. I think I found a method that works for me. .250 OD brass tubing fits perfectly inside the bushing housing of the EB. So I cut a piece about 3mm long. Then I discovered a 5mm BB fits perfectly tight inside .220 OD brass tubing if it is reamed a little, then press the BB in with a vice. Then solder the tubes together, and JB Weld the entire assembly to the EB.
