Chenowth Indianapolis 500 car
40 replies to this topic
#1 Regis4446
Regis4446
  • 441 posts
Posted 12 June 2013 - 04:00 PM
Since this year's theme at Bordeaux is Indianapolis 500 through 1968 inclusive, I decided to present and run a wooden car.
As there are no plans available for this body, I'll have to settle for photos on the web.
After determining the size of the car would be 1/24, I started gluing up pieces of wood to form the body.
  • endbelldrive and Bruce Wayne like this
Regis Baron
#2 don.siegel
  • 5,836 posts
Posted 12 June 2013 - 04:11 PM
I just saw Régis' car this weekend, and it's a thing of beauty! The chassis is just as nice....
And good choice, Régis! A very interesting car that was never made as a slot, as far as I know...
#3 SlotStox#53
  • 4,084 posts
Posted 12 June 2013 - 04:17 PM
Awesome start! What wood do you use to make the bodies, Régis?
#4 Tex
  • 9,243 posts
Posted 12 June 2013 - 04:18 PM
I like watching you true model-makers build up a new car!
#5 Regis4446
Regis4446
  • 441 posts
Posted 12 June 2013 - 11:04 PM
Thank you, friends.
This was the first Chevy V8 in history to attempt a qualifying run at the Indianapolis Motor Speedway.
I use obeche wood (another name: ayous or samba). The same wood was used to make the bodies for the cars below.
  • endbelldrive likes this
Regis Baron
#6 Regis4446
Regis4446
  • 441 posts
Posted 13 June 2013 - 11:27 PM
Regis Baron
#7 Jairus
  • 10,174 posts
Posted 14 June 2013 - 12:02 AM
Régis is one of the best scratchbuilders I have ever had the pleasure to know. Watching updates as they are posted.  :good:
#8 Regis4446
Regis4446
  • 441 posts
Posted 15 June 2013 - 01:06 AM
Thank you, Jairus.
But it is very exaggerated; there are better than me on the web.
I try to make my cars beautiful above and below.
Regis Baron
#9 Dennis David
Dennis David
  • 3,424 posts
Posted 15 June 2013 - 01:42 AM
It's like some kind of magic trick watching this come together.
Dennis David
#10 Regis4446
Regis4446
  • 441 posts
Posted 16 June 2013 - 01:27 AM
Making the two aluminum caps for oil and gas reservoirs.
The intake pipes were purchased from Jens Scale Racing and mounted on a small aluminum plate.
 It is very nice site, there are parts and a beautiful gallery (1/24 only).
  • endbelldrive, S.O. Watt and Bruce Wayne like this
Regis Baron
#11 Regis4446
Regis4446
  • 441 posts
Posted 16 June 2013 - 11:14 PM
Making the four openings for eight intake funnels.
The body weighs 18 grams.
  • Jairus and Bruce Wayne like this
Regis Baron
#12 dc-65x
  • 6,972 posts
Posted 17 June 2013 - 10:22 AM
Hi Régis,
Another greatl project!
What a wonderful gift you have. Anything you see you can create (truly form "scratch") into a beautiful work of art.
Thanks for sharing!
#13 Regis4446
Regis4446
  • 441 posts
Posted 18 June 2013 - 02:45 AM
Here is the finished chassis; in fact it is not really a frame.
 It is very simple and made of brass rod of 2.5 and 2mm plus sheet 1mm thick.
 Held to the body only by the rear axle, the front axle passes through a tube.
Regis Baron
#14 munter
munter
  • 1,049 posts
Posted 18 June 2013 - 11:55 PM
 ... that is impressive.
John Warren
#15 Regis4446
Regis4446
  • 441 posts
Posted 19 June 2013 - 12:18 PM
Thank you, friends.  :hi:
Here is the exhaust, made ​​of brass.
  • MSwiss and Bruce Wayne like this
Regis Baron
#16 Cheater
  • 25,663 posts
Posted 19 June 2013 - 12:25 PM
It is so enjotable watching a master modeler perform his craft!
#17 Tex
  • 9,243 posts
Posted 19 June 2013 - 02:21 PM
MMmm... brass pretty.
#18 Regis4446
Regis4446
  • 441 posts
Posted 20 June 2013 - 11:43 AM
I made 14 louvers  on the right side in a small aluminum plate.
  • Bruce Wayne likes this
Regis Baron
#19 SlotStox#53
  • 4,084 posts
Posted 20 June 2013 - 12:30 PM
Wow Régis that is really coming along nicely!! Love the aluminum panel ,beautiful work.
What filler do you use on the wood?
#20 Regis4446
Regis4446
  • 441 posts
Posted 21 June 2013 - 08:48 AM
 I use the primer Gunze, then the Gunze paint and varnish after installing decals Indicals.
This does not conform to the original, but I like the gold color with red numbers of the body.
  • miko and Bruce Wayne like this
Regis Baron
#21 Regis4446
Regis4446
  • 441 posts
Posted 21 June 2013 - 09:03 AM
This does not conform to the original, but I like the gold color numbers  with red of the body.
Regis Baron
#22 SlotStox#53
  • 4,084 posts
Posted 21 June 2013 - 10:29 AM
That is looking really good !!! Can't wait to see it all bolted together & ready to roll :D
#23 Regis4446
Regis4446
  • 441 posts
Posted 22 June 2013 - 12:08 AM
 Some details were mounted on the car, but not too much, this is not a static model
Regis Baron
#24 Tex
  • 9,243 posts
Posted 22 June 2013 - 06:01 AM
Great stuff, Regis! Somebody should make a hardbound book of slot car pics from great builders like you, Rick Thigpen, Steve O'Keefe, Jairus Watson, etc.  I'd buy that book!
#25 munter
munter
  • 1,049 posts
Posted 22 June 2013 - 06:21 AM
I continue to enjoy this thread....I spy cast urethane tires?
John Warren
