As I may have mentioned before, I race with a bunch of old timers down at the local hobby shop on a fair-sized four lane Scalextric Sport track. The track is on a layout of approximately 10' x 20' with four straightaways (approx. 16', 12,' 8' & 6' with a variety of connecting curves).
Many, if not all, of the cars are modified to one extent or another.
I have very successfully built a Scalextric Porsche 997 GT3 with Scalextric hop-up parts and I now have a Slot.it car to which I'd like to do the same.
It seems that the Slot.it car is a more technically built car and I don't want to error in my selection of parts.
I have a series of modifications I would like to do and have questions around these mods I am hoping that can be answered.
The car being used is a Slot.it SICA18b Ford GT40 with an Evo6 chassis/ sidewinder engine configuration.
1.) The engine selected is a 29K Slot.it motor. Does this chassis use the "S" can V12/29K plastic end bell type motor?
2.) Slot.it Rear tire (P6) designated for Scalextric track surfaces in a 19x10 size.....SIPT24s..?????
3.) This chassis shows provisions for the placement of two bar style magnets in the center of the chassis between the front axle and the motor. They appear to be a snap-in type like Scalextric and I understand their could be an additional provision for another magnet behind the engine. I see that the chassis is supplied with one magnet.
Can any one tell me by the Slot.it part number which is a matching magnet for the one supplied. And with two magnets, where on the chassis would be the preferred spots for placement????
4.)Lastly, gear ratios. The base set-up is an 11 tooth pinion/32 tooth spur. If I am running a motor with a wider and higher RPM band and range, can I gain more acceleration, with all other factors remaining the same by reducing the pinion diameter...say to 10t....? I can only suspect that top end speed would be reduced...?
Looking for some help here....thanks
