Hi Folks,
I've just come across a tamiya boom chassis that appears to have been designed for a 26d. All the boom chassis I've seen in the past had a cast hole in the end sized for a 36D or 16D gimbal bearing housing. An adapter plate was used to fit dirrerent motors. This new one has a cast hole sized for a 26D endbell. It has strengthening around the back corners near the rear body mount. Check the picture below. Is it possible that this is a repro chassis or did Tamiya adapt the cast rear section of their boom chassis for 26Ds?
Regards
Steve C
